This thread is privately moderated by jackerbes, who may elect to delete unwanted replies.
Old Oct 10, 2012, 10:33 AM
nickchud is offline
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
Any recommendations for simple and free drawing software?
Google Sketchup is pretty good. I'd be interested to hear of any good competition.
nickchud is offline Find More Posts by nickchud
Old Oct 10, 2012, 10:39 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Some here have found the free (or at least free in the beginning) SketchUp app to be good enough for the simple drawings we usually need here. I am not an expert on or with it but there is some help here from guys that are darned good with it:
Using google Sketchup for modeling... With practical examples - http://www.rcgroups.com/forums/showthread.php?t=920416
How do I make plans using Google sketchup? - http://www.rcgroups.com/forums/showthread.php?t=1376826
Drawing, CAD drawing, welding, flying RC, being happily married, having obedient children, and well-trained dogs. What do all of those have in common?
The harder you work at them the better your results are!
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 10, 2012, 11:05 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Here's a short video of my depron KFm-4 Funbat "ultra" flown close in at 50% power then WOT. Super stable as you can see and has a really good glide. Main wing in 6mm and steps 3mm top and bottom
Radio control Funbat Ultra 10thOct12 (1 min 14 sec)
Andy
headlessagain is online now Find More Posts by headlessagain
Old Oct 10, 2012, 12:47 PM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
Looks like a nice one Andy, what are the mods you made to make this then?
rcjim11 is offline Find More Posts by rcjim11
Old Oct 10, 2012, 02:17 PM
Flyboy Steve is offline
Find More Posts by Flyboy Steve
Joined Nov 2007
Thomas, thanks for the info on the power train. Do you think this would fly well on a 2S system -- perhaps with a 7" prop? Or, do you need 3S and high speed?
Flyboy Steve is offline Find More Posts by Flyboy Steve
Old Oct 11, 2012, 12:40 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Sketchup is an easy program to use and its very clever..much neater than pencil and paper and quicker once you've played with the program for a while, you can do 2D lines very quickly , and go on to make a full 3D model if thats what you want..
All my drawings are done in sketchup...and in my previous post the sketchup file for my version of your radius is in the zip file..it took about 10-15 mins to draw up.
Try downloading sketchup and my zip file, then load up my drawing and correct it to suit your build..
having a problem to work on, like the changes will get you learning faster..
http://www.sketchup.com/intl/en/download/index.html the basic version is free.. the pro is time restricted...
My
You will realize I am just as much a sketchup fanatic as I am a KF fanatic... however, on using sketchup, although I can very quickly do basic line drawings, I have a long, long, way to go to make use of its full potential
Power for the radius... my setup is a 7x3.5 on a 800mAh 3 cell and a 1700kv motor.. this is drawing about 7-8A at full power and hovers at 1/2+ power...so my max speed is going to be less than Thomas, but it will go vertical just fine..
My AUW with an 800 3 cell is 9.5 oz.... total area 1.8sqft... so 5.3ozsqft..
When going to 2 cells use a fairly high kv motor and prop it to suit, but dont expect the same max speed as thomas unless you take the motor's kv well high..
Your choice of power setup obviously depends on what you want it to perform like, My site is a sport field at the bottom of a park,so I tend to restict my models in top speed so as not to scare the pedestrian trafic..
The funbat is another good simple to build model, it reminds me of the much earlier obilex sloper and its layout is similar again to the radius, like a lot of our models it uses similar ideas, with changes of shape to produce a nice new model.. It then just depends on whether you like straight lines or curves...
davereap is offline Find More Posts by davereap
Old Oct 11, 2012, 01:12 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Central fin and more streamlined fuse - see this post http://www.rcgroups.com/forums/showp...&postcount=912
Andy
Old Oct 11, 2012, 02:06 AM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
Cheers, what are you planning to use the funfighter motor in now?
Old Oct 11, 2012, 02:13 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
I might build a 800mm flying wing to run on 4s KFm-4 of course.
Old Oct 11, 2012, 09:52 AM
Thomas B. is online now
Find More Posts by Thomas B.
scratchbuilder
Thomas B.'s Avatar
Germany, Nordrhein-Westfalen, Cologne
Joined Mar 2012
Steve, the Radius should fly well on 2s if you choose right motor/prop combination.
Thomas B. is online now Find More Posts by Thomas B.
Old Oct 11, 2012, 10:17 AM
nickchud is offline
nickchud's Avatar
Market Harborough
Joined Apr 2006
Dave
I don't know if I'm right, but it seems to me that the radius type of wing is incredibly tolerant and easy to fly, both slow and fast. I wonder what the drawback is and why it's not used for 3-D planes like Extra, Edge etc?
Nick
Old Oct 11, 2012, 12:23 PM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
I'd guess that the circular sweep gives it very nice stall behavior just like a delta wing has.
The disadvantage is lots and lots of drag at higher angles of attack, which makes it more difficult to carry energy through your maneuvers.
rdeis is offline Find More Posts by rdeis
Old Oct 12, 2012, 01:05 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Deltas and circles are very good fliers and will do most everything, with the exception that they are poor/difficult for easy knife edge.. conventional shapes like the extras and yaks etc are much easier...
I am not sure on the aerodynamics, but isn't sweep back often equated to dihedral.. so many degrees sweep = so much effective dihedral... and as effective dihedral works as stability to bring the model back on to level flight, it makes it difficult to keep a knife edge in flight..And when you use the rudder to hold the nose in Knife edge it will roll the model rather than just yaw it..
Circles and curved back leading edges work similar to sweep back.....
Ive tried both but as I am not a competent 3D flier I found it impossible to hold a knife edge for more than a few seconds.. I can however hold it with the conventional 3D models
It is I know possible to do and can be aided by mixing opposite aileron in with the rudder, but I have never been that bothered..Its far easier to use a conventional shape for 3D
Speed ranges..all our KFs have excellent speed ranges, it is one of our models flight characteristics that using the steps does improve... From a good top speed whizz, they can be slowed, going slower and slower with no bad tendencies till you get them stopped and go into that parachute maneuver....Ive found that true enough whatever the shape of the wing..
Old Oct 12, 2012, 04:29 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
After looking at the obelix I have decided to make my own sloper version in a KFm9 format..
One model hanging on my wall and one I am not using is a BIG V wing, It was ok but nothing special, and my newer mini gliders are well out performing it..
So the knife is coming out and the V will be converted into a close approximation of the Obelix but at 56" span ...
I took some measurements and did a quick sketchup drawing, working out where the mods will have to be made... and luckily it wont be a difficult remodeling job..
Old Oct 12, 2012, 12:51 PM
rdeis is offline
AMA 353531
rdeis's Avatar
Joined Aug 2003
Originally Posted by davereap View Post
I am not sure on the aerodynamics, but isn't sweep back often equated to dihedral.. so many degrees sweep = so much effective dihedral... ... ..And when you use the rudder to hold the nose in Knife edge it will roll the model rather than just yaw it..
Oh, I forgot about that!
You're exactly right, sweep will couple roll into the yaw.
It makes the airplane feel very well behaved for the sort of sporty cruising around and punching holes in the sky a lot of us tend to do (which is why so many of us like it), but I can see that making knife edge flight really tough.
Idea 40" Depron Dynamite, Kline fogleman Depron build dougmontgomery Hand Launch 690 Jun 06, 2016 12:49 PM
Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) dougmontgomery Foamies (Scratchbuilt) 151 Apr 21, 2014 09:08 AM
Discussion ** Kline-Fogleman Airfoiled Flying Wing ** Tony65x55 Foamies (Scratchbuilt) 3945 Apr 08, 2014 10:40 AM
Video Kline Fogleman Airfoil on a flying wing Tony65x55 Electric Plane Talk 3 Jan 30, 2009 07:37 PM
Discussion Kline-Fogleman Airfoil on a flying wing Tony65x55 Modeling Science 1 Aug 20, 2006 11:14 AM
