http://www.giantshark.co.uk/xyh3536-...-p-403279.html The 2220/10 should be much the same.... my first flights were with a 2215/20 which I thought should have been ok, but this didnt match the plane at all and the model flew very poorly.. Going to the bigger prop setup, with more power and thrust, really transformed the model... The KFm2 makes the regal float along, as there is lots of lift from those wings... But I was thinking it may be improved by having a kfm2 on the top wing and a KFm1 on the bottom wing... will I try that? unlikely as its good just as it is... kfm2 pterosaur ... another good flyer from Thomas... I just love those more unusual shaped models..It looks like a candidate for a sloper as well, perhaps with a better gliding section... |
USA, ME, Ellsworth
Joined May 2008
Interesting flight for sure.
I guess power systems are a matter of taste... That is a 40" FPV platform with a 2200 Kv motor and a 6.5 x 5 prop if I have the power system details right. That makes it about an 18,000 RPM system with a pitch speed of about 94 MPH. And that probably translates to a over the ground speed in the 60 to 70 MPH range. Yikes! The winds there were probably pushing 25-30 MPH and he was able to control it well. I guess it is a testimonial to his skills. Jack (a self-admitted old geezer)
I would recommend to build the Mauersegler with a spar if you want to do some aerobatics. I use 4x1mm carbon, simply glued vertically behind the step. My brother used 5x5mm wood; I never used bamboo but I guess it will work fine, too. Best wishes Thomas |
USA, ME, Ellsworth
Joined May 2008
Not sure if the intent there is to put that CF spar in the corner formed by the step of not. But it is generally not a good idea to do anything there that changes the step from a clean, square, right angle corner. When things like that were tried in the past they reduced the effectiveness of the step as far as generating the vortex and making the KF miracle happen.
If you cut, route, or use a soldering iron to make a shallow groove in the bottom layer of foam a little ways in front of the step you can lay the CF spar in there. Use the foaming PU glue to fill around the spar and bond the step down on top of it. That will bond the spar and the two layers together and it will be as strong as it can get. Jack |
USA, ME, Ellsworth
Joined May 2008
But the embedded spars work well, the key seems to be to use the PU glues so that the foaming action get the layers and spar all well joined. Many materials have worked for that, CF, wood, bamboo skewers, etc. Jack |
Well, I have a new project for the KF as of this afternoon. After chasing my Coci down the hillside a half dozen times I decided to ashcan the original wing and build something less draggy. Since a bunch of you slope soaring jokers have had such good success with the KF on slopers I guess I'll try one on this Coci. Nothing could be as bad as the original foam core, built up wing, which is now in the recycle bin.
Is This your COCI.. http://www.rcgroups.com/forums/showthread.php?t=1029766
that should have sloped ok..so your lift must have been poor However try a KFm9 or 11... they are good gliding wings... |
Well, "it should have" and "it sucked out loud" are two very different things. I got sick of dragging that turd back up the hill all afternoon long when the poor performance resulted in a plane that couldn't climb its way back up a really nicely shaped slope despite 20-30KmH winds. I tried all kindsa weight and such, and the plane just wouldn't penetrate worth spit.
Heck, I even tried out my MS Composit Swift II combat wing out there today with a fresh nose repair and squared edges. It performed better than that crappy Coci, so what does that tell you? Anyway, I can whip some wings together to see if that plane will work at all. If not then I just strip it and ashcan it with the wing. Heh. |
| Thread Tools | |
| Idea 40" Depron Dynamite, Kline fogleman Depron build | dougmontgomery | Hand Launch | 626 | Aug 07, 2012 01:21 AM |
| Discussion ** Kline-Fogleman Airfoiled Flying Wing ** | Tony65x55 | Foamies (Scratchbuilt) | 3938 | Apr 08, 2012 06:07 PM |
| Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) | dougmontgomery | Foamies (Scratchbuilt) | 149 | Feb 16, 2011 12:12 AM |
| Video Kline Fogleman Airfoil on a flying wing | Tony65x55 | Electric Plane Talk | 3 | Jan 30, 2009 07:37 PM |
| Discussion Kline-Fogleman Airfoil on a flying wing | Tony65x55 | Modeling Science | 1 | Aug 20, 2006 11:14 AM |
