This thread is privately moderated by Sofa King, who may elect to delete unwanted replies.
Old Sep 25, 2009, 09:25 PM
Sofa King is offline
Find More Posts by Sofa King
Sofa King's Avatar
United States, AZ, Kingman
Joined Jun 2005
Build Log
The First R4 Coupe...THE BUILD IS ON !!!!
hours and hours of drawing and redrawing........back and forth to the laser cutters.......autocad2010 and corel X4.....lonestar AAA balsa....several trips to the print shop....revised 4 times(thats where the R4 comes from)and finally the 3 prototypes are done......i'll keep you posted with some pics and i hope a good build log.
i'll add pics as we go........
Sofa King is offline Find More Posts by Sofa King
Old Oct 11, 2009, 05:32 PM
Sofa King's Avatar
Joined Jun 2005
right wing started on the R4 Coupe.....i was missing a R2 rib...i may have miss counted and included it in one of the other 2 kits....i pulled a R3 rib and used it in place of the R2.....
the MSJ cut too wide......
.........some minor bugs to get worked out...still i think looking good.
the left wing half should go together a little quicker
Old Oct 16, 2009, 10:06 PM
Sofa King's Avatar
Joined Jun 2005
wing is about 90% done......it took a good deal of sanding to shape it all down.... i should be ready to start the fuse soon.......
the wing is pretty thin...i went looking for a servo in my pile and found i didn't have any...not one....they are since on the way......
......colors.....hmm....what color......i guess i still have a little time left to figure the color scheme out.....
Old Oct 19, 2009, 01:11 PM
Sofa King's Avatar
Joined Jun 2005
so far no major problems....
i think the cheeks are going to give me fits....they were cut /drawn wrong and will need allot of shaping where they meet the top firewall...
i had to order the landing gear from tower...i swear i had a set laying around somewhere.......
the battery and tank will have to go in after the holes for the gear are drilled...
i am gluing up some scrap to make servo rails....the way the parts were cut on the balsa leaves quite a bit of usable wood....
i also installed the tubes to take the pushrods...you cant hardly see them in the pics as they are clear.........
....colors.....hmmm....getting closer.....
Old Oct 23, 2009, 05:56 PM
Sofa King's Avatar
Joined Jun 2005
.........i was having such a great time on the build that i almost forgot a pictured update......the landing gear and push-rods made it today...and i found some wheels on a set of retracts i think i will use on this plane.....
.........colors....i have a scheme drawn up and so far it looks like red and black on the top........red and white for the bottom....we'll see as this color process usually changes several times and then again right at the last minute as its being applied
i had the plans copied today for the next project....60 sized Gull Wing ....it may be closer to the first of the year before we get a good look at that one...but today marks the start of the process
Old Nov 05, 2009, 09:23 PM
Sofa King's Avatar
Joined Jun 2005
sorry the updates are coming slow....i have covered the turtle deck 3-4 times....i'm still not too happy with the latest result........pics will be coming soon.....i hope
Old Nov 08, 2009, 06:59 PM
Sofa King's Avatar
Joined Jun 2005
i still need to hinge the tail feathers but they are at least covered.....the wing still needs servos installed and covered...the wing will(i hope) be covered the same as the elevator....not shaping up to bad....
i'm now not a fan of chrome covering....it shows everything underneath...also while shrinking if you get it too hot it will cloud over....i have two full rolls left ... i guess i have enough to trim out the wing....
Old Nov 13, 2009, 10:18 AM
Sofa King's Avatar
Joined Jun 2005
tail feathers hinged and installed.....#4 added to rudder..
..........i am covering the bottom wing today and hope to get the finished wing pics up soon
Old Nov 25, 2009, 06:58 AM
Sofa King's Avatar
Joined Jun 2005
Dan's RC has started his R4 Coupe and its looking great !!! http://www.rcgroups.com/forums/member.php?u=268223
wayne has completed his and weighs in at 3-1/2 lb AUW ... i need to get up there and get some pics....
i am still on the wing covering....should be done soon ...
Old Dec 04, 2009, 08:12 PM
Sofa King's Avatar
Joined Jun 2005
i have the ol' R4 covered....i'm not too happy with the pictures...between my flash an the camera and the chrome trim...in a low lit livingroom....not good
...........anyway here are a couple until i can get outside and get some better ones.....
..........looks like the bottom will be very easy to see and easy to tell which is the top vs. the bottom.....
i still need all the push-rods hooked up....install Rx....add 4-5 oz weight to the tail.......i should have went with the .25....naaah !!!!
Old Dec 10, 2009, 05:22 AM
Dan's RC is offline
Find More Posts by Dan's RC
Account Closed
Western NY
Joined Jun 2009
I am going to cheat!!
LOOKS GOOD. I have not had time to update my progress so I will cheet! Here is a pic. I am close to done. It is snowy now, so I may put her on skies. I will update as soon as I get a minute. The second pic is to show the stab of my next project. A 1\5 scale Cessna 182 Skylane Top Flit gold adition kit. My wife bought me the cokpit kit for x-mas. I will post the progress of that as well on my blog. One question: Why 4 servos in the wing. Did you do flaps? I thought about it myself.
Dan's RC is offline Find More Posts by Dan's RC
Old Dec 10, 2009, 05:48 AM
Sofa King's Avatar
Joined Jun 2005
wow...that is way over the top!!!! i love it !!!! ......thanks Dan
Old Dec 10, 2009, 07:12 AM
Dan's RC is offline
Account Closed
Western NY
Joined Jun 2009
Servos in your wing.
It looks like you have 4 servos in your wing? If so, why. Did you do flaps? I will try and get video of my first flight. Has your friend flown his yet? Is it on his blog? If so, can you give me his name so I can see his plane?
Old Dec 10, 2009, 07:18 AM
Sofa King's Avatar
Joined Jun 2005
4 servos was for plenty of torque and just in case i wanted to add flaps....they are 9gram el'cheapo's from hobby king......
wayne doesn't have a computer...he is 70+ years old and hasn't had the need for one...but he calls wanting me to look up kits and engines he sees in magazines....too funny i know
he had me order some 3s lipos from hobby king and as soon as they get here i'll drive up there and get some pics of his.....
yours looks great....both ours were nose heavy....did you find your to be as well?
