| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#676 |
WHEN IN DOUBT FLOOR IT!!!
I bet the noise is a vibration in you frame,,can u do a video of what is going on.
#677 | |
Sid,
If you cannot turn the prop on the motor shaft by hand to make it slip, then that is not the cause. If it is slipping, you will have to shim it to make it tight. Yes, motor/prop unbalance can cause different sounds at various throttle settings that hit the harmonics of the unbalanced condition. That can also cause your accelerometer and gyros to go into a state where they are giving garbage for angular information. Cheers, Jim Quote:
#678 | ||
Well disaster struck me too but not nearly as hard as I thought it was going to. Trying to get this totally crappy video from my Blackberry and hit my neighbors house at 10pm at night and he comes outside with a flashlight and boxers. Talk about embarrassed
![]() Only broke 2 props really so I took them all off. I did run it up without the blades on there and the noise was not there at full throttle, so the noise only came on when the blades were on there. Hopefully the 1045s won't have this same noise, otherwise I'm going to have to see what is up with each motor. Here is the video, the quality is horrible but at least you can see it turn right and you can clearly hear the noise it makes under high throttle. I did a few bounces so you could see me quickly stab the throttle and then showed how great it hovers in place at normal throttle.
#680 | |||
2 quads down in 1 week! that's just bad luck. I feel for you buddy.
#681 |
Sid,
Never run the motor without props at full throttle for any length of time unless you want to roll the dice on burning up your motor and or ESC's. Short blips without props are OK to test operation and rotation, but never go full throttle. A 10PM crash of a quad on a neighbors roof...lucky it was a flashlight in his hand..., but seeing him in those boxers must have been pretty scary too... ...![]() Cheers, Jim Last edited by jesolins; Nov 11, 2009 at 07:08 AM. Reason: spelling |
#682 |
#683 | |
#684 | |
Up flying and stable :)
Nevertheless, this could be a nice feature indeed, I'm sure George will take good note of it
#685 | |
this really puzzles me... why would a motor or ESC burn if driven full throttle with no load? It does not make too much sense to me since it seems RPM is controlled by the ESC isn't it? ![]() I'm not saying it was clever or anything, but I have frequently driven many motors full power for periods of time (I just did on 2 motors that needed new bearings one hour ago) without ever having any problem with them or the ESCs, no overheating, nothing abnormal really. Could you please tell me the reasons for this? Bob |
#686 | |
Do not run brushless ESC's and motors at high throttle without props! 101
Hi Bob,
Just as running too large or too small a prop can damage a brushless motor/ESC, running them without props at full throttle for more than a split second can do wiring/heat/magnet damage and is not recommended by several manufacturers. This damage might not show up immediately in that full throttle several second or more run, but the damage done would show up later as stuttering starts hot motors weak motors, etc. In other words, the minor damage done to overheated windings, bearings and magnets would progress over time. Remember that even a low Kv unloaded motor can reach speeds ten's of thousands of times its watt load Kv rating. The heat goes somewhere when that happens and it is not usually a good outcome. Will it damage a motor every time if you run it unloaded at full throttle? No, but why take the chance!? You don't need to ever run motors at full throttle to see if it is a working setup anyway...just simply blip the throttle if there is no prop on to determine functionality or rotation direction... Further, if an ESC miss-cues while at full throttle providing high current, it will run that current through one winding pair and eventually take out the motor, and the ESC if it wasn't already damaged. A brushless ESC has 3-12 or more FETs depending on the model and any one going bad either by itself or because of a processor timing error, can take out a motor, kind of a cascade effect of damage... Here is a good motor testing link: http://www.wattflyer.com/forums/show...62&postcount=1 A good explanation of heat effects on brushless motors and resultant damage: http://www.rcgroups.com/forums/showt...ps#post7157040 (touts Scorpion motors, but applies to all and well explained.) In my years of taking a survey asking folks who have had ESC's smoke and motors burn up on them, the common theme was that they had been doing extensive bench tests running the motors at full throttle without props and insufficient cooling. Not sure why someone would do that anyway? I do know that those that don't practice running their motors at full throttle with no props on for testing don't seem to find their motors and ESC's burning up at some later point... ![]() Cheers, Jim Quote:
#687 |
OK new issue now. Since that crash I put the new props on and went to fly it today and now the right motor only spins up from the initial turn on but when I throttle up, it stays at idle. Makes it a little difficult to fly with 3 motors, what do I need to check since it obviously is getting a signal because it starts and stops just fine but it simply won't do anything else even with gyro input from me tilting the quad or ail, elevator, rudder inputs.
#688 | |
![]() Try swapping ESC's to see if that one went bad
#689 | |
Thanks Jim,
very interesting indeed, I will be more careful about this from now on! Got some reading to do now, cheers ![]() Quote:
#690 |
I tried some night flying,here is a small video
http://www.youtube.com/watch?v=p1LoGHLHfoU Last edited by G-unit; Nov 12, 2009 at 09:16 AM. |
