Go Back   RC Groups > Aircraft - Electric - Helis > Multi Rotor Helis
Old Nov 04, 2009, 03:52 AM   #631
that thing flys smooth as hell! which do you like better, this or your quadpowered?
Originally Posted by G-unit View Post
One more,this was after the crash of my other QC.
Xaircraft X500-D (4 min 50 sec)
importon is online now Find More Posts by importon   Reply With Quote
Old Nov 04, 2009, 04:05 AM   #632
With 1500-2500 packs, one ESC suddenly dropping power happened to a few of us, occasionally (but destructively!).
I did some soak (=long) tests with a 4000 pack, 1045 blades, AUW 910g, just to stress things, and repeatedly got a dropout (on whatever side the CofG was towards) at 7-8 minutes in. The side (motor & ESC) it dipped to was noticeably hotter than the others. From this I deduced that the problem wasn't glitching or controller firmware, but ESC overheating.
I put little heatsinks on each ESC's output transistors both sides, outside the heatshrink 'cos I am superstitious , and then found I could empty a 4000 pack in a single 20 minute+ flight, at this 'over max spec' weight, without dropouts.
(This isn't the same as saying you won't get dropouts with heatsinks - just that it worked for me).
Others have also re-mounted the ESCs on the arms so they catch some of the downwash.
I am awaiting delivery of some 8045s (lost the original tri-blades in a dipping incident) to see if they are more efficient (= less likely to cause overheating) than the 1045s.
(In correspondance, Xaircraft agree that, over-weight, the ESCs might overheat, but so far they won't acknowledge that this happens occasionally (and destructively!) with normal packs and normal flying. Which tells me something important about their attitude to their customers.)
Doofer is offline Find More Posts by Doofer   Reply With Quote
Old Nov 04, 2009, 09:04 AM   #633
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
Originally Posted by Quad_Addict View Post
so what was the fix to the x500 with power dropping?
I don't use the 10x4 props and i don't have that problem no more
G-unit is offline Find More Posts by G-unit   Reply With Quote
Old Nov 04, 2009, 09:21 AM   #634
Sid3ways's Avatar
Send a message via AIM to Sid3ways
G
I'm wondering how you mounted the lipo and rx in the RCD frame. Ive got them together in the middle but the side with the RX closest to it is heavier on that side. Is it negligible to have that little imbalance or should I possibly suspend it underneath in the middle?
Sid3ways is offline Find More Posts by Sid3ways   Reply With Quote
Old Nov 04, 2009, 09:39 AM   #635
G-unit's Avatar
I put the battery on the bottom of the frame,i made a aluminum plate that bolt to the bottom and the use Velcro to hold the battery,I can make one for u ,just let me know.
G
Old Nov 04, 2009, 09:44 AM   #636
Sid3ways's Avatar
That would be sweet! Will there be enough room to still put on the camera mount?
Old Nov 04, 2009, 11:53 AM   #637
G-unit's Avatar
I will PM u tonight when i get home.
Old Nov 04, 2009, 10:46 PM   #638
G-unit's Avatar
Well they both have there place,so i like them the same
Old Nov 05, 2009, 12:57 AM   #639
common. they're not your children. you can pick a favorite.
Old Nov 05, 2009, 01:07 AM   #640
got decals?
Quad_Addict's Avatar
well i will admit i like the x500 as well for couple reasons, but think about what kind of addons you can get with any other custom quad, the QP has huge support and addon support as do other like TT and MK. that should help your deicsion. even though the x500 may be fun to fly. think outside the box :P
btw they may not be children but certainly his babies :P
Quad_Addict is offline Find More Posts by Quad_Addict   Reply With Quote
Old Nov 05, 2009, 01:28 AM   #641
Sid3ways's Avatar
He caught some heat last time he picked one....
Update: Well tried to mount all of my camera (FPV) gear tonight and had a set back. Well with all the extra cabling and crap added to the frame it wouldn't start. I'd get the beeps and everything was fine according to the board but it just wouldn't arm the motors. I'm thinking the blame lies on the OLD ass Futaba T8U that I'm using that I had to borrow. It seemed to reset itself and i spent all night trying to reprogram it with no luck getting it to start. The only way I could get it to start was wiggle a few wires one time and the motors started up under a failsafe mode or something, it was wierd. I couldn't get them to start by the radio but if I fiddled with a few wires, the motors would start up and run at a low idle but the TX still had no control over throttle??? I'm going to remove all the FPV stuff and check all my wires again.
Old Nov 05, 2009, 01:57 AM   #642
got decals?
i hate wiring issues. i feel for you, start from scratch with all connections and or solder joints. plus your radio just may be an issue like you said.
Old Nov 05, 2009, 07:42 AM   #643
G-unit's Avatar
One more from last night,and this one is my favorite it is flying right now.
Xaircraft X500-D (6 min 49 sec)
Old Nov 05, 2009, 07:57 AM   #644
Sid3ways's Avatar
Yeah I just wish my Aurora 9 would come in so I could rule out the radio. RCD did a supurb job on the wiring an soldering so I doubt it but will be going back over it completely today.
Edit: great vid, so stable for a cheap ass quad, gotta love it.
Old Nov 05, 2009, 09:01 AM   #645
damn! does it ever get windy where you live?
Bored? Want to fight?
Join the RCGroups clan!
