Go Back   RC Groups > Aircraft - Electric - Helis > Multi Rotor Helis
Old Oct 03, 2009, 02:40 AM   #31
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
OK i figured out what the pots are.
  • Name: Xaricraft X500-D aircraft board 002 c.jpg
G-unit is offline Find More Posts by G-unit   Reply With Quote
Old Oct 03, 2009, 05:14 AM   #32
G,
Not sure why they would have the boot loader as that should already be on the processor in a protected area. Maybe they mean flight firmware?
Can you post the .txt how to for us to check?
Cheers,
Jim
Originally Posted by G-unit
This is what is on the CD, what is the Bootloader?? I cant get that to do anything.
Thanks G
jesolins is offline Find More Posts by jesolins   Reply With Quote
Old Oct 03, 2009, 10:28 AM   #33
got decals?
Quad_Addict's Avatar
someone said this is a clone MK is it true? why pots?
Quad_Addict is offline Find More Posts by Quad_Addict   Reply With Quote
Old Oct 03, 2009, 11:02 AM   #34
Ken,
I suspect that they are using the pots because of the "lite" firmware they are using that is not capable of making PID adjusts. It is not a clone of the MK board. It is very different and I can see no place to mount a barometer from the photos, or the camera servo connetors. It appears to use the same ATMEGA644 processor as the MK and does have ISP pads for the processor.
Cheers,
Jim
Old Oct 03, 2009, 03:01 PM   #35
G-unit's Avatar
Originally Posted by jesolins
G,
Can you post the .txt how to for us to chenck?
Cheers,
Jim
Hi Jim,
I don't know if this is what u are asking for,but it just shows how to configure your radio.
  • Name: Xaricraft X500-D aircraft 011.jpg
Old Oct 03, 2009, 03:09 PM   #36
Yep, Just Tx/Rx setup info...
Cheers,
Jim
Old Oct 03, 2009, 03:11 PM   #37
G-unit's Avatar
Hey i forgot to mention that i made some adjustments with the pots and made a big difference,but it sucks because the wind is blowing 20Mph and gusting to 40Mph ,but the test flights in the house seem allot better
Old Oct 03, 2009, 03:15 PM   #38
They certainly should make a difference. Be careful and do a hand flight test after each adjust to make sure it does not go spastic on you. Good to hear it is flying better
Cheers,
Jim
Old Oct 03, 2009, 03:22 PM   #39
G-unit's Avatar
Yes it is a very small adjustments for a big difference
Old Oct 03, 2009, 03:41 PM   #40
got decals?
videos!
Old Oct 03, 2009, 03:55 PM   #41
G-unit's Avatar
I don't have any yet, and it is defiantly not as stable as in there videos,but i believe i have a out of balance prop,
hey do you use any of the radios trims to adjust the flying??
Thanks G
Old Oct 03, 2009, 05:16 PM   #42
Yes, you should trim so that applying power make it go straight up. Also put in -40 Expo for pitch and roll and 60% for the pitch and roll rates. Make sure you are using ACRO mode on your Tx.
Cheers,
Jim
Thanks G
Old Oct 03, 2009, 09:14 PM   #43
Ken,
Cheers,
Jim
Hi Jim, I can't located the developer's posted message on one of the Chinese Quad forum anymore. His posting apparently got deleted due to commercial contents. But I do recalled on one of his posting that he indicated the X500-D is support the native MK firmware.
kb6mcc is offline Find More Posts by kb6mcc   Reply With Quote
Old Oct 03, 2009, 09:35 PM   #44
Hi Ken,
That would be interesting. I suppose the NAVI board or a clone could come about too.. I wonder if www.quadroufo.com would be a shop that might carry just the boards...
So many quads..so little time...
Expect a UAVX release very soon. Very good release candidate flights today between rain showers
Cheers,
Jim
http://www.rcgroups.com/forums/showthread.php?t=1097355
Old Oct 04, 2009, 03:20 AM   #45
Hi Ken,
Cheers,
Jim
Hi Jim,
Thanks you for keeping the UAVx clean with all the water.
I'm more interested on the X500 i2c ESC then the FC. I'm sure they using the HOL type ESC too.
All my fingers are ready for the next UAVx release..
Bored? Want to fight?
Join the RCGroups clan!
