Go Back   RC Groups > Aircraft - Electric - Helis > Multi Rotor Helis
Old Oct 01, 2009, 09:38 AM   #16
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
Originally Posted by tend2it
I would try put together the whole thing using stock stuff and do the RTF (Ready To Fly) out of box report first ... then do any improvements later (I do agree on the two bladed approach). That will give an unbiased comparison.
What was the turn-around time from order to receipt?
--Eric--
hey Eric,
Yes that is what I'm going to do,but if someone can give me a idea on prop size i can get them ordered
Thanks G
G-unit is offline Find More Posts by G-unit   Reply With Quote
Old Oct 01, 2009, 10:15 AM   #17
G,
What size are the tri's? I guess about 6-7in? EPP845's or the Silverlit props are probably your options.
Cheers,
Jim
Originally Posted by G-unit
hey Eric,
Yes that is what I'm going to do,but if someone can give me a idea on prop size i can get then ordered
Thanks G
jesolins is online now Find More Posts by jesolins   Reply With Quote
Old Oct 01, 2009, 10:47 AM   #18
G-unit's Avatar
tri- blade are GWS HD 8040x3
Old Oct 01, 2009, 11:08 AM   #19
Hi,
The frames look nice...any idea where to get them...
thanks
Originally Posted by bas10an
And some nice and cheap quad frames: http://item.taobao.com/auction/item_...808693e703.htm
http://item.taobao.com/auction/item_...e277e0283e.htm
Expect a review sometime soon
Sebastian.
jtansoon is offline Find More Posts by jtansoon   Reply With Quote
Old Oct 02, 2009, 11:37 AM   #20
got decals?
Quad_Addict's Avatar
Got mine in the mail today,I will start the build tomorrow.
hows the build comming? when can we see detail pics of the board?
Quad_Addict is offline Find More Posts by Quad_Addict   Reply With Quote
Old Oct 02, 2009, 12:21 PM   #21
G-unit's Avatar
It is built,i didn't take any pics of the board but i can,
I seem to have some problems with it rotating to the right,it seems to be fine when i take off but once I'm in the air it stops rotation to the right don't know what to do to fix it
Old Oct 02, 2009, 12:37 PM   #22
G-unit's Avatar
Pics of the board
  • Name: Xaricraft X500-D aircraft board 001.jpg
  • Name: Xaricraft X500-D aircraft board 002.jpg
  • Name: Xaricraft X500-D aircraft board 003.jpg
Old Oct 02, 2009, 03:01 PM   #23
G,
Interesting that the board has trim pots. Does the disk have an application to adjust parameters? Can you post screen shots please.
Check to make sure your motors are not tilted and are perfectly level. Only a hair of tilt can screw up the quad's yaw capability, or improve it... The parameters if any and the trim pots for the gyros on the board are the next things to look into for tweaking your flight performance. Go easy on those pots, those type are notorious for falling apart. If you move the pots from where they are, first mark them for their location, then only move them a hair one way or the other and test, but no more than that.
If you haven't done so already, remove the tape from the beeper. It will be then be much louder...
Suggested replacement props are the EPP845's. Here: www.quadroufo.com
Cheers,
Jim
Pics of the board
Old Oct 02, 2009, 05:21 PM   #24
G-unit's Avatar
Originally Posted by jesolins
G,
Cheers,
Jim
Hi Jim,
Thanks for the info this is what i got for adjustment far as computer.
I will look at the motors and see if they need adjustment.
Thanks G
  • Name: Xaricraft X500-D aircraft.jpg
Old Oct 02, 2009, 05:24 PM   #25
G-unit's Avatar
Hey Jim,
Just looked at the motors and i defiantly have two motors at a angel,
I will get then straight and will let u know.
Thanks G
Old Oct 02, 2009, 05:36 PM   #26
G,
That app only is for the Tx setup. Is there no other app for PID for the gyros or accelerometer?
Cheers,
Jim
Hey Jim,
Thanks G
Old Oct 02, 2009, 06:06 PM   #27
G-unit's Avatar
I believe that is all it has.
Old Oct 02, 2009, 06:11 PM   #28
I think this X500 is just a MK clone..try using the MK tools
kb6mcc is offline Find More Posts by kb6mcc   Reply With Quote
Old Oct 02, 2009, 06:15 PM   #29
G-unit's Avatar
Hey ,can u tell me were to find them.
Thanks G
Old Oct 02, 2009, 07:48 PM   #30
G-unit's Avatar
This is what is on the CD, what is the Bootloader?? I cant get that to do anything.
Thanks G
  • Name: Xaricraft X500-D aircraft 003.jpg
Bored? Want to fight?
Join the RCGroups clan!
