Go Back   RC Groups > Aircraft - Electric - Helis > Multi Rotor Helis
Old Sep 25, 2009, 09:10 AM   #1
J.F. Sebastian
bas10an's Avatar
Xaircraft X500-D $300 ARF brushless quad from China
Xaircraft X500-D: http://www.helibest.net/rc/vh-product.asp?id=1198
http://www.cnchelicopter.com/servlet...ircraft/Detail
Videos: http://so.youku.com/search_video/type_tag_q_xaircraft
Main features:
- Using AVR +51 multi-MCU architecture to ensure stability and balance and control of real-time
- Built-in high-reliability three-axis gyro, three-axis accelerometer
- Built-in USB interface, the computer can be used to set flight parameters, the upgrade process
- Compatible remote control model aircraft used Futaba, JR, WFLY (72MHz/40MHz/35MHz/2.4GHz)
- 4 dedicated high-speed bus Brushless Motor ESC (6A)
- 4 high-performance brushless motor
- A key force components using high-precision CNC aluminum parts
Specifications:
Main rotor diameter: 203mm
Pitch: 500mm
Weight: 500g (without batteries)
Maximum Takeoff Weight: 1200g
Remote Control Distance: depending on the remote control and receiver may be
Battery requirements: 11.1V/2200mAh-2500mAh/15C
A X650-D with GPS is in the works as well:
http://item.taobao.com/auction/item_...4531e05d63.htm
And some nice and cheap quad frames: http://item.taobao.com/auction/item_...808693e703.htm
http://item.taobao.com/auction/item_...e277e0283e.htm
Expect a review sometime soon
Sebastian.
  • Name: x500db1b.jpg
  • Name: x50001.jpg
  • Name: x50002.jpg
  • Name: x50003.jpg
  • Name: x50004.jpg
  • Name: x50005.jpg
  • Name: x50006.jpg
  • Name: x50007.jpg
  • Name: x60001.jpg
  • Name: x60002.jpg
bas10an is offline Find More Posts by bas10an   Reply With Quote
Old Sep 26, 2009, 12:38 PM   #2
Wow That's Cool!
tend2it's Avatar
Main features:
Specifications:
Pitch: 500mm
Sebastian.
Wow ... nice find Sebastian ... found some translations and some videos ...
http://translate.googleusercontent.c...ioJT0cJeHz3FYw
http://translate.google.com/translat...23entry9371853
--Eric--
tend2it is offline Find More Posts by tend2it   Reply With Quote
Old Sep 27, 2009, 07:51 PM   #3
signguy's Avatar
Hey Sebastian
Did you stop buying gyros to save up for the quad!
That looks nice for the $$, looks like it might be a problem to go bigger, as the speed controls have some extra wires. Do you have the test unit yet? Have a friend that wants a tri, but with his skill level of building, this may be a better choice.
Can't wait to hear how it works..........
Bob D
signguy is online now Find More Posts by signguy   Reply With Quote
Old Sep 29, 2009, 12:32 AM   #4
got decals?
Quad_Addict's Avatar
interesting!
the dude was in quadpowered thread spamming this a few days ago..
Quad_Addict is offline Find More Posts by Quad_Addict   Reply With Quote
Old Sep 30, 2009, 09:52 PM   #5
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
Got mine in the mail today,I will start the build tomorrow.
Xaircraft X500-D (6 min 49 sec)
Xaircraft X500-D (4 min 50 sec)
http://www.vimeo.com/7136828
FILE0007 (0 min 59 sec)
Xaircraft X500-D (1 min 16 sec)
  • Name: Xaricraft X500-D aircraft 001.jpg
  • Name: Xaricraft X500-D aircraft 002.jpg
G-unit is offline Find More Posts by G-unit   Reply With Quote
Old Sep 30, 2009, 09:58 PM   #6
The first mod would be to get rid of the inefficient tri-props...
Cheers,
Jim
jesolins is offline Find More Posts by jesolins   Reply With Quote
Old Sep 30, 2009, 10:08 PM   #7
G-unit's Avatar
WOW i did not know that they are inefficient,will look in to it .
Thanks G
Old Sep 30, 2009, 10:59 PM   #8
got decals?
Originally Posted by jesolins
The first mod would be to get rid of the ineffiecint tri-props...
Cheers,
Jim
ditto, 2 probs with um, ugly and "ineffiecint" lol
some detail pics of the electronics would b good like the board. and
classic burned cd! cant beat the price though.
Old Sep 30, 2009, 11:01 PM   #9
Wow That's Cool!
tend2it's Avatar
Originally Posted by Quad_Addict
interesting!
jkantiques is notorious for spamming and bashing threads ... ... great to see some real HW for this thing ...
Old Sep 30, 2009, 11:12 PM   #10
got decals?
so any real info on The board for the price for everything could this just be like a bl UFO 5 conversion? Or does the board hold some real potential ?
Old Oct 01, 2009, 12:41 AM   #11
G-unit's Avatar
OK what props should i put on it???
The try blade are GWS HD 8040x3
Old Oct 01, 2009, 01:21 AM   #12
Wow That's Cool!
tend2it's Avatar
I would try put together the whole thing using stock stuff and do the RTF (Ready To Fly) out of box report first ... then do any improvements later (I do agree on the two bladed approach). That will give an unbiased comparison.
What was the turn-around time from order to receipt?
--Eric--
Old Oct 01, 2009, 02:24 AM   #13
Always like to see new quads on the scene.
Would also like to know if standard ESC could be used.
I kind of like the look of the three blade props but I'm surprised they choose them due to their performance as well. So how efficient is that one with the tri props stacked on top of each other
Look forward to the detailed build.
Xaircraft quads are based on Mikrokopter replica electronics that is supposed to be plug and play with all genuine MK parts, and runs genuine MK software...
How does the price of this one compare to a genuine MK with the same feature set? This one comes in a more, ready to fly, form than the genuine MK does?
I'm assuming programming on this board isn't disabled some how so we can't use it to play with genuino MK source code? If we can upload code to it and it's a clone of the genuine MK hardware, why would they need to discontinue their 500 model already if the board for the genuin MK hasn't changed?
Just curious is all. Thanks for all the info.
If they are going to change version numbers this quick I guess having "Xaircraft" in the title is good enough And thanks for adding that
RCvertt is offline Find More Posts by RCvertt   Reply With Quote
Old Oct 01, 2009, 03:49 AM   #14
J.F. Sebastian
bas10an's Avatar
Some facts:
The ESC's are I2C bus, the controller will not drive standard ESC's.
The X500-D is out of production already, Mazi is concentrating on development of the X650, he might take up production again after the X650 is launched.
Title changed
Sebastian.
Old Oct 01, 2009, 09:19 AM   #15
Sebastian,
Will the FCB be available by itself? It looks like the X500 has Murata gyros will the X600 have Mems gyros? Cost?
Cheers,
Jim
Some facts:
Title changed
Sebastian.
Bored? Want to fight?
Join the RCGroups clan!
