Australia, NSW, Bungendore
Joined Jan 2005
Big 'Brisfit' by Peter Rake
Starting this thread is a bit premature as I'm not quite ready to start the build but since a nice box of bits arrived on the doorstep this morning from New Mexico, I thought I'd share it with someone
Peter had already produced a small Bristol Fighter (Bristol F2b - 'Brisfit') some years ago and he even built it himself :http://www.rcgroups.com/forums/showthread.php?t=423742 I remember asking Peter if he'd contemplate designing a bigger version but he was flat out on other projects at the time. Then Looooeeee started on an upsized Rake design but I'm not sure if that got started : http://www.rcgroups.com/forums/showthread.php?t=336963 A few months ago, it was mentioned in passing that a big Brisfit was on the board and I was immediately interested and after some pestering, got to having a box of bits on my bench Here is the kit contents from Manzano - about two dozen sheets of balsa, liteply, heavy ply and basswood. I've yet to verify the bits but that will be a pleasurable task one evening! Model details soon. Pat |
Joined Jan 2005
About the Brisfit....
Jeff - this model is big enough to incorporate whatever detail is desired - and the Brisfit has heaps of it! I've not yet decided how I'll approach it but Peter suggested it would be a good 'trainer' before I got the SPAD flying
The original F2b first saw service in 1917 but was not really a successful combat plane until the following year after which it was considered one the most effective fighter aircraft of the Great War. It was good enough to continue on with the RAF until about 1930 and was still in other forces at the outbreak of WW2! At about 39' span, it was not a small aircraft and Peter's design of 1:7 scale produces a model of 67" span and around 44" length. This is great as I believe it may JUST fit into my wagon assembled! After several months of studying everything Brisfit, I narrowed my choice of prototypes down to a couple - both post WWI and neither painted green! A replica flying with one of New Zealands big collection of old aircraft, and an RAF unit that served in India in the mid-1920s. Both are finished in between-the-wars silver dope and grey metalwork. The Indian unit was fitted with every concievable attachment incuding tropical radiator, spare wheel, Handley-Page slots, flares, message hooks, landing lights, HF antenna, wind generators etc etc......... just my cup of tea Fortunately the F2b is extremely well documented with three Datafiles and several other monographs plus masses of pictures and plans from the 'net. I also have a good collection of old AirEnthusiast and Areoplane magazines with good articles on the aircraft. I'm looking forward to starting the build - sometime soon Pat |
Latest blog entry: A Big Move.....
Joined Jan 2005
No guys - I wont be swayed
But there are some unusual schemes out there for those wanting something unique - from fish scale and shark mouths, checks and stripes, various all-over colours plus the bog-standard PC-10 with various white stripes. Unfortunately, that was the style that most of the aces flew. After the war, there were all the training squadrons, squadron 'hacks' and then the more-or-less standard silver dope with coloured ID stripes. I like the silver finish (I've several rolls of silver covering plus some silver Solartex for details and rib-tapes) so I'll leave the exotic, erotic schemes for you guys later Also, the Brisfit served with many forces following the Great War and no doubt had many other odd schemes applied.The model is similar in fuselage size to Pete's 54" SPAD and SE5 but with an extra foot or so of wing. I'd imagine the weight would be in the range of 6lb. The total wing area is around 8.3 sq ft which would mean a loading of around 11 oz/sq ft. At 5lb AUW, loading is 10 oz/ft while 7lb AUW gives 13 or so. So I'll aim for 6 lb and Pete has specified an AXI 4120 size motor which on one of my 4S 5000 LIPOs will mean a low kv motor with a fairly cool wind otherwise we'd have a rocket rather than a lumbering WW1 fighter Scale prop size is around 17" - that will also affect the motor choice as a 12X6 would look ridiculous! I may need to talk to Vinto about a laminated version. My prototypes used the two blade rather than 4.The model is fairly standard Peter Rake style, but with a bit of extra complication or 'beef' where deemed necessary because of size. Especially around the lower wing fixing which is of course, attached to the fuselage with struts and the UC passes through gaps in the CS. Much to be discussed - later Pat |
Joined Jan 2005
Pete - the basic fuselage is where I'll start on this one - partly to check out the slot-and-tab thing but also the dreaded lower centre-section and UC arrangements. And (big sigh from Peter..) I want to try an alternative (for me) securing of the rear CS struts to see if it possible to clear the cockpit area a little. I'll do the designed method first and then see if my mod is possible.
I also have ideas about a proper jigged assembly to get everything right - a big piece of 1/2" ply with various supports and jigs to ensure proper alignment. Big biplanes are a bit scary if left to 'eyeballing' this area! IF this model comes out at less than 5lb as Peter suggests, it may mean a rethink on the required power setup. Or just pile on a bit more paint and detail Pat (building a Be12a pilot) |
Joined Jan 2005
Charlie - my LHS sold me a sheet of 1/8 ply that turned out to be 5 ply and was 4.4mm thick! Wood sizes must make your life difficult esp. with full kits where it is reasonable to expect everything to fit together
Pat |
| Thread Tools | |
| Build Log 36" SPAD XIII - By Peter Rake | SKY KING | Scale Electric Planes | 387 | Oct 21, 2012 12:43 AM |
| Build Log Ryan's Daughter - a low-wing sport model by Peter Rake | Pat Lynch | Sport Planes | 147 | Apr 23, 2010 01:24 PM |
| Build Log Nieuport IV for IPS (designed by Peter Rake) | BaZsiX | Scale Electric Planes | 56 | Jun 24, 2007 03:00 PM |
| Fokker D VII by Peter Rake | Ian Easton | Scale Electric Planes | 158 | Dec 21, 2005 11:06 AM |
| Goupy Biplane by Peter Rake | pburress | Scale Electric Planes | 10 | Jan 15, 2005 02:08 AM |
