Old Sep 24, 2009, 11:08 PM
marc9129 is offline
Find More Posts by marc9129
Joined Dec 2007
Any 1/2 planes designed for water???
Any suggestions?
Marc
marc9129 is offline Find More Posts by marc9129
Old Sep 25, 2009, 12:35 AM
TLyttle is offline
Find More Posts by TLyttle
TLyttle's Avatar
Keremeos, BC Canada
Joined Mar 2004
Lots of them. There are kits out there that would be just fine for 049, and the magazine plan services list quite a few. I think the old "Lil Doozy" is still available; looks like a flying shoe, but it works fine.
TLyttle is offline Find More Posts by TLyttle
Old Sep 25, 2009, 09:06 AM
marc9129 is offline
Joined Dec 2007
Thanks T. Is there a particular site that you like to look for 1/2A's?
Old Sep 25, 2009, 12:22 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I remember putting floats on some 1/2a planes in the past. I would hand launch and then land in the water dead stick. No throttle, just aileron and elevator or rudder and elevator.
Is is about the closest one left around right now, but it uses a .10 engine.
http://www3.towerhobbies.com/cgi-bin...?&I=LXAGD2&P=0
now there are some electric float planes, and some of those may be convertable to 1/2a engines.
earlwb is offline Find More Posts by earlwb
Old Sep 25, 2009, 12:36 PM
marc9129 is offline
Joined Dec 2007
Thanks for the ideas! I found this one too! Looks real cool.
https://www.quicktechhobby.com/Airpl.../aqua_star.htm
Old Sep 25, 2009, 01:07 PM
lightthings is offline
Find More Posts by lightthings
Joined Oct 2008
You might look in the Sticky thread at the top of the 1/2A form called "1/2A Sources"
LT
lightthings is offline Find More Posts by lightthings
Old Sep 26, 2009, 08:14 PM
marc9129 is offline
Joined Dec 2007
Thankyou! I'll check it out.
Old Sep 26, 2009, 08:33 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
You could also poke through RCM Plans' seaplanes section. Several of those are 1/2 A to .15 size. You could also do a search for anything Ken Willard designed. It seems he had a thing for waterborne aircraft and the smaller engines.
James
Deuce is offline Find More Posts by Deuce
Old Sep 27, 2009, 12:58 AM
TLyttle is offline
TLyttle's Avatar
Keremeos, BC Canada
Joined Mar 2004
Yeah, Willard had a LOT of interesting designs over the years, apparently the all worked really well...
Old Oct 22, 2009, 03:05 AM
Modelholic is offline
Find More Posts by Modelholic
Modelholic's Avatar
Perth WA
Joined Feb 2007
http://i7.photobucket.com/albums/y25...7/102_1704.jpg
http://i7.photobucket.com/albums/y25...7/102_1708.jpg
Ken Willards Drake (free flight) converted to 3 channel RC.
Plan here:
http://www.unclewilliesplans.com/about24.html
and a very nice version here with ailerons in place of rudder:
http://www.rcgroups.com/forums/attac...mentid=2774816
Oh so sweeettt!
Modelholic is offline Find More Posts by Modelholic
Old Oct 22, 2009, 10:01 AM
marc9129 is offline
Joined Dec 2007
Cool! Thanks!
Old Oct 24, 2009, 04:34 PM
Subarubrat is offline
Find More Posts by Subarubrat
Joined Jan 2005
I suggest the Herr Aqua Star as mentioned above. I did mine with some really small servos in the wing panels to operate tip floats. It looks really cool to come in over the water and drop them down just before landing.
Floats down
http://subarubrat.com/misc/seaplane.jpg
Floats up
http://subarubrat.com/misc/seaplane1.jpg
Subarubrat is offline Find More Posts by Subarubrat
Old Oct 25, 2009, 10:22 AM
marc9129 is offline
Joined Dec 2007
wow! That looks really cool! Do the plans show how to do that??
Marc
Old Oct 25, 2009, 11:52 AM
Joined Oct 2008
Marc
Marc, before you get all starry eyed about those floats- They don't retact themselves into the wing like retractable landing gear does. Here is a link to a picture that you can see the rubber bands on the wing holding the wing floats in place as shown on the plan.
http://www.tcrconline.com/photos/fal...ua%20Star.html
and another: http://www.rcgroups.com/gallery/showphoto.php?photo=520
LT
Old Oct 25, 2009, 12:54 PM
Joined Jan 2005
As lightthings pointed out the Auqa Star does not come with that feature, the stock floats rubber band on. My tip floats are a modification and they do retract up and become part of the wing.
All I did was take some balsa and make tips that matched the wing shape. I notched them for a 1/16th sheet of light ply about an inch wide and long enough to put them at the right height in the water. I then fit it up against the end of the wing and notched the ribs as needed and then put a small balsa block on the rib where the end of pontoon strut fell and used a regular control surface hinge to allow the tip float to fold up into the wing.
I installed two of the really small cox servos (any small servo is plenty) and linked them with a pushrod. You hit the toggle and the floats snap down, hit them again and the floats snap up.
If I did it again I would do two things differently.
1. I used 1/2 x 1/2in balsa blocks as I recall. I would make the floats a wee bit bigger, they could use just a bit more floatation, it works but more would be nice.
2. I did not seal the float bay for weight. This only bit me once when the wind put the tip into the water. Sheet it in thin balsa and paint it.
The floats make no measureable difference in speed or handeling, so they are just a cosmetic gadget. But when the plane is coming in on final and the floats pop down it is a really cool gadget.
Oh and most of all. A friend who built an auqa star pointed out that you need full length chines or the thing submarines on you. I don't know if they changed the kit but if you look at mine and Lightthings second image of the red one you can see what to do.
Wanted Any 1/2 built,tired or crashed Sagitta 900s rcdude01 Aircraft - Sailplanes (FS/W) 0 Sep 29, 2007 12:36 PM
Sold (4) Airwild 1 1/2" arms for Hitec servos cje0114 Aircraft - General - Radio Equipment (FS/W) 4 Jul 30, 2007 07:02 PM
Discussion F-15C 1 : 9 1/2 Scale EDF For AP-1200 Test !! AirPower RC Electric Ducted Fan Jet Talk 15 Dec 20, 2006 10:06 PM
Help! 1 1/2" Spinner for 3-blade prop? GroundBound Scale Fuel Planes 4 Jan 26, 2005 08:33 PM
any 1/2 a 3D Planes for the norvel engines? Rev Maximillion 1/2A Planes 6 Sep 18, 2004 10:58 PM
