Old Sep 24, 2009, 05:42 PM
dirtman is offline
Find More Posts by dirtman
Lost it again!!!!!
dirtman's Avatar
United States, CA, Menifee
Joined Aug 2007
Help!
How to repair a fuel tank?
I crashed and put a tiny hole in my tank. I can't even see it, just the drip. What is the best way to fix it?
I would buy a new one but cant get them anymore. I need the flush fit,the stopper fits through a hole in the firewall. Of course I can get a Dubro and make it work, but would like to fix this one.
Curt
dirtman is offline Find More Posts by dirtman
Old Sep 24, 2009, 05:58 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
In general you can't get a satisfactory repair of the plastic fuel tanks. The residual fuel/oil prevents any glue from bonding.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Sep 24, 2009, 05:59 PM
realtimerecon is offline
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
How about melting a plastic patch -over the hole...RTR
realtimerecon is offline Find More Posts by realtimerecon
Old Sep 24, 2009, 06:01 PM
Joined Mar 2005
Again... the residual oil prevents a decent bond.
Old Sep 24, 2009, 08:10 PM
linw is offline
Find More Posts by linw
Wellington, NZ
Joined Aug 2006
I get the soldering iron and run it over the hole to get melted plastic over it. I sometimes also put some epoxy over it as well. To my surprise, it sticks well.
If there is oil on it, surely it can be cleaned with something like acetone?
linw is offline Find More Posts by linw
Old Sep 24, 2009, 08:41 PM
Joined Mar 2005
Last thing you want to do is create a "leak waiting to happen".... and thats what you get when you repair a plastic fuel tank.
Old Sep 24, 2009, 09:05 PM
Ira NZ is offline
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
Just replace it, they're cheap.
Ira NZ is offline Find More Posts by Ira NZ
Old Sep 24, 2009, 10:13 PM
dirtman is offline
Lost it again!!!!!
dirtman's Avatar
Joined Aug 2007
Yea, thanks for the replies.
I think I will just replace it. No need to deadstick it. It doesn't float to well. It is a 60 size Shoestring by great planes. Beautiful plane(or was till I forgot to put my antena up) and flies great. No need to crash it again over something stupid, that could have been prevented.
Old Oct 01, 2009, 03:29 AM
jjkupinski is offline
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
If you have an ARF with a leaky metric sized tank (no exact USA replacement), they can be successfully repaired if you don't want to cobble your airframe for a larger replacement or install a smaller tank. All it takes is a bit of mineral spirits or a strong detergent, a low temp soldering iron, and narrow strips of plastic milk bottle. But if its a neck split - forget it. And don't attempt on a Sullivan flex tank, the walls are too thin.
I have repaired a few tanks successfully by melting the milk bottle strips onto the crack in the tank. First clean the area to remove the oil from the fuel, then a quick swipe with the iron on the tank to burn off the excess petroleum that is inherent with polyethylene, and then melting the bottle strips onto the crack. The key is to back off with the iron if you see the tank material turning clear. Usually two layers of bottle strips, if done right, will stand up to 10 psi. Your basically resealing the crack and adding material.
jjkupinski is offline Find More Posts by jjkupinski
Old Dec 14, 2014, 01:19 PM
MARCUSTHE EDGE is offline
Find More Posts by MARCUSTHE EDGE
Model airplane collector
United States, NV, Las Vegas
Joined Oct 2013
Science always proves that there IS a solution to anything !... But giving up before ever starting and making no attempt to research a solution only proves a serious lack of thought and lack of skills !.. And passing on one's failure's to others is twice the error!.
MARCUSTHE EDGE is offline Find More Posts by MARCUSTHE EDGE
Old Dec 14, 2014, 01:40 PM
exf3bguy is online now
Find More Posts by exf3bguy
exf3bguy's Avatar
United States, CA, Sacramento
Joined Oct 2011
If the small hole is not on a corner, you can drill the hole larger and install a nylon screw, a couple of nylon washers and nylon nut through the hole and it will seal the tank. I have used nylon hardware through the tank several times to mount a tank on a platform.
exf3bguy is online now Find More Posts by exf3bguy
Old Dec 14, 2014, 02:07 PM
Ira NZ is offline
Ira NZ's Avatar
Joined Apr 2006
I'm pretty sure he's found a solution in the last 5 years.
Old Dec 14, 2014, 02:40 PM
exf3bguy's Avatar
Joined Oct 2011
LOL. Good info none the less.
Old Dec 15, 2014, 07:44 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
not sure this was mentioned but tanks are "CHEAP". The problems that hole will cause with idling, suction and leaking fuel in the plane, etc just isn't worth it... IMO
Thermalin is offline Find More Posts by Thermalin
Old Dec 15, 2014, 08:32 PM
exf3bguy's Avatar
Joined Oct 2011
While I agree that the best option would be to replace, sometimes the correct shape and/or size can't be found or can't be had right away. In that case doing a quick fix can save a weekend.
Help! how to change the fuel tank????? chander On-road Cars 2 Sep 14, 2007 10:36 AM
Fuel tank tubing(How to bend) bigbear3721 Fuel Plane Talk 7 Aug 21, 2004 03:08 PM
