Old Apr 10, 2012, 02:20 AM
eye4wings is online now
Find More Posts by eye4wings
...design-build-fly-publish...
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
I think we can safely say 'YES!... it does house something Simon!
An area of doubt surrounds the identity of that something though....
Are you about to enlighten us?
eye4wings is online now Find More Posts by eye4wings
Old Apr 10, 2012, 03:13 AM
DH106 is offline
Find More Posts by DH106
North UK
Joined Jun 2005
Nope - I don't know either Robin ! :-)
I don't remember seeing such a lump on the DC-6 wreck I saw in Cyprus (the left wing was propped up with the underside exposed, so it would have been very visible) - so they may be optional / version specific.
DH106 is offline Find More Posts by DH106
Old Apr 10, 2012, 06:53 AM
DH106 is offline
North UK
Joined Jun 2005
I suspect actually that this 'lump' is just an aerodynamic refinement to perhaps reduce local flow seperation where the nacelles taper in ?
Old Apr 10, 2012, 10:00 AM
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
By making the pressure gradient steeper locally?
Or bringing the possible separation point further forward?
I have my doubts - but given the paucity of my aerodynamics theory, possible nevertheless.
I think on the whole though I will stand by my earlier suggestion.
It may well (whatever it is) have been introduced in the 6B and your wreck have been an earlier version.
There were a couple of derelict 6s (or were they 4s?) a couple of years ago when I last visited North Weald. If I am passing sometime and they are still there I may have a quick snoop... but no holding of breath now!
Old Apr 10, 2012, 12:40 PM
DH106 is offline
North UK
Joined Jun 2005
Well, I was mistaken - having looked again at the photos of the Cyprus wreck I can see now that it does indeed have the lump / flairing, although it's very subdued and not raised very much above the wing skin level.
It's a shame I didn't know about it when I was there - I could have attempted to see what was under it
Old Apr 10, 2012, 12:44 PM
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
Ah, it seems life is full of missed opportunities. The trick is not to let them dampen your spirits!
Old Apr 10, 2012, 02:20 PM
AlexanderB is offline
Find More Posts by AlexanderB
Scratch Builder
AlexanderB's Avatar
Braunschweig, Germany
Joined Sep 2006
Perfect!
AlexanderB is offline Find More Posts by AlexanderB
Old Apr 15, 2012, 12:44 PM
Scratch Builder
AlexanderB's Avatar
Joined Sep 2006
This weekend I had to work unfortunately. But I managed to find some time to sorten out the cabling of the wing. Indeed there are quite some servo cables:
4 x ESC
2 x Flaps
2 x ailerons
2 x landing light servo
1 x sail winch for the main gear
Plus the cables for the nav-light LEDs and landing light LEDs. In order to have the most flexibity with the nav-lights I added a 100mA constant current source per nav-light.
I still have cables for a gear door servo on each side but I am confident I can use the same mechanism I used on the nose gear doors.
I also prepared the Main Bus A (read too much Apollo stuff these days ), i.e. the battery cable that includes also the 150A MUI (voltage and current sensor).
So every cable is identified now and I hope that I can do some RX programming these days. The Jeti RX are programmable. So I can fine tune / align the aileron servos and the flaps servos because I will use only one channel for flaps and one for the ailerons.
Cheers Alexander
Old Apr 15, 2012, 01:37 PM
egras14 is offline
Find More Posts by egras14
Pompano Hill Flyer
egras14's Avatar
United States, FL, Fort Lauderdale
Joined Apr 2003
Wow!Niceley done.Are you making a wire diagram as you go along?
egras14 is offline Find More Posts by egras14
Old Apr 15, 2012, 01:48 PM
Scratch Builder
AlexanderB's Avatar
Joined Sep 2006
Thank you. Yes I will have such a diagram.
Old Apr 15, 2012, 01:57 PM
S_YORAM1@BEZEQIN is offline
Find More Posts by S_YORAM1@BEZEQIN
Israel, Jerusalem
Joined May 2007
Can you expand a bit more on the Jeti RX and how it is programable?
S_YORAM1@BEZEQIN is offline Find More Posts by S_YORAM1@BEZEQIN
Reply With Quote  (Disabled)
Old Apr 15, 2012, 02:20 PM
Scratch Builder
AlexanderB's Avatar
Joined Sep 2006
Well, I think this is a wide field. Let me see...
The main principle is that first of all each output pin of the RX is assigned a channel of the TX. For the flaps you have two output pins (eg 9+10) which both are assigned to channel 6. So you have to learn that the output pins of the RX must not necessarily have anything to do with the channel. Of course the factory standard is the output pins are connected with the channels: pin 1 = CH 1, pin 2 = CH 2, pin 3 = CH 3 etc.
Then you can program some settings per output pin. You can for instance reverse a servo that listens to the same channel. In my DC-6 flaps design the servos are mounted symmetrically, i.e. if they would follow the same CH one would go up while the other goes down (like Ail).
You can also trim (center) each output pin or program a delay for the pin (flaps may move slowly).
There are some more options but I would say this is the most important part.
Cheers Alexander
Old Apr 15, 2012, 04:26 PM
Israel, Jerusalem
Joined May 2007
Thanks for the explanation. Do they have a web site?
BTW - I am subscribed to your project and read avidly all what you do.
Yoram
Old Apr 15, 2012, 04:41 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Yoram
http://jetimodel.com/index.php?page=...=0&category=67
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Apr 15, 2012, 05:19 PM
Scratch Builder
AlexanderB's Avatar
Joined Sep 2006
Yoram
Thank you for your interest in my project. Ben already posted the link to Jeti.
Cheers Alexander
Build Log Pitts S1S for 100 watts scratch build Mike Tully Scale Kit/Scratch Built 73 Nov 24, 2013 11:32 AM
Build Log Tony Nijhuis Douglas DC-3 Dakota kit Build. Basingstoke Roy Scale Kit/Scratch Built 74 Jul 07, 2013 06:25 AM
Build Log Protech Douglas DC 3 (Build) flyingrally Scale Kit/Scratch Built 10 Aug 08, 2010 05:02 AM
Yippee! DC-3 scratch build complete Lowboy Foamies (Scratchbuilt) 4 Nov 28, 2006 08:53 PM
Fokker F-100 scratch build airliner project Igwe Aneke Electric Ducted Fan Jet Talk 35 Jul 07, 2005 07:16 AM
