Old Sep 23, 2009, 07:30 PM
MWCores is online now
Find More Posts by MWCores
MWCores's Avatar
Moses Lake, Wa.
Joined Apr 2008
MWC Starfire
These wing cores are now available at:
www.mwcores.com under Flying Wings
Jeff
MWCores is online now Find More Posts by MWCores
Old Sep 24, 2009, 09:20 AM
dghutt is offline
Find More Posts by dghutt
Halifax Electric Flyers Assoc
dghutt's Avatar
Halifax, Canada
Hi Jeff! Very interesting wing -- I'm considering it for a slope soaring rig. Do you have or provide recommendations for set-up, CG, elevon size and location, vertical stabs and the like, or do you just provide the wing? I'm game either way but the decision would be a lot easier if I had a baseline for some of these specs before starting, and I haven't found a build thread here setting up the Starfire as a sloper.
Dave
dghutt is offline Find More Posts by dghutt
Old Sep 24, 2009, 04:31 PM
MWCores's Avatar
Moses Lake, Wa.
Joined Apr 2008
Yes I can send you info along with the wing.
Jeff
Old Sep 25, 2009, 06:46 AM
pval3 is offline
Find More Posts by pval3
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
baseline
McClain Wing Cores STARFIRE beta1 v2 maiden - fins (8 min 2 sec)
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Ac69B5cCZFk&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Ac69B5cCZFk&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
baseline!
pval3 is offline Find More Posts by pval3
Old Sep 25, 2009, 09:07 AM
pval3 is offline
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
rcg video link in case audio fails on youtube
http://www.rcgroups.com/forums/showt...8#post13198044
Old Sep 27, 2009, 03:57 PM
MWCores's Avatar
Moses Lake, Wa.
Joined Apr 2008
Great job on the video
Old Sep 30, 2009, 08:21 PM
pval3 is offline
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
slope mods
Hey guys
For those sloping, take the beta build thread with the increased depth elevon and larger winglets.
I would use three CF Tubes as the spar system in an "A" shape if you are going to be loading it up with lead for penetration and speed. My thin walled dual spar was not enough for the high speed set up. Anything over 100 mph needs the thick walled cf tubes.
If it is going to be a lighter sloper, use one thick walled 1/4 cf tube (bottom of wing) or two 1/4 light walled tubes (one top and one bottom).
I would not hesitate to use the Kellys cloth with the spray 77 (will not attack the white foam main core like the spray 90 will). Cover it with Monocoat or Ultracoat and you are ready to rock! The weight is not that much greater in the end and the gain in durability is nothing short of amazing.
Old Oct 04, 2009, 10:38 AM
MWCores's Avatar
Moses Lake, Wa.
Joined Apr 2008
I just posted pics on ebay.
Jeff
