Old Sep 23, 2009, 02:26 PM
GaryX1001 is online now
Find More Posts by GaryX1001
Builder & Pilot
GaryX1001's Avatar
Germany
Joined May 2009
Video
Learning to fly my Belt CP v2 - evening!
learning to fly my Belt CP v2 in the evening
GaryX1001 is online now Find More Posts by GaryX1001
Old Sep 23, 2009, 04:12 PM
badpilotto is offline
Find More Posts by badpilotto
BadPilot
badpilotto's Avatar
United States, IL, Custer Park
Joined Nov 2007
Gary,
Good job on safely landing the heli. Nice flying area too.
Thanks for sharing.
John
badpilotto is offline Find More Posts by badpilotto
Old Oct 03, 2009, 09:16 AM
steve1975 is offline
Find More Posts by steve1975
Joined Oct 2009
can anyone help,i have a cp belt and it wont lift off the ground,ive tried everything that i no(not alot lol) please,ive set up the pitch but still nothing,eveything moves correct"!!
steve1975 is offline Find More Posts by steve1975
Old Oct 03, 2009, 06:55 PM
flyguy88 is offline
Find More Posts by flyguy88
flyguy88's Avatar
United States, TX, Killeen
Joined Oct 2009
Im having a similar problem with my Axe cpv the pitch on my main rotar blades is way out of wake giving me no lift and I cant seem to figure out what is wrong with it I have replaced parts etc. I cant seem to fix the problem. Without a picture I can only describe the best way I can the issue. but the main rotar blades wont lay flat. When I turn the power on the blades pitch the wrong way giving it no lift I can seem to figure out how to fix it I will post some pictures in a few hours but if you have any ideas please give me your ideas. Im in iraq and cant exactly go to a local hobbie shop for help.
flyguy88 is offline Find More Posts by flyguy88
Old Oct 03, 2009, 11:39 PM
BadPilot
badpilotto's Avatar
Joined Nov 2007
Guys,
If you go to the heli area on RCGroups you will most likely receive the most viewing and help.
http://www.rcgroups.com/beginner-tra...-electric-599/
I do fly helis but am no expert. STEVE, have you checked the head RPM? What about the radio settings. What is the M/R blade pitch set to, both positive and negative? Much more information is needed in order to help you with this problem.
John
Old Oct 07, 2009, 02:37 PM
Builder & Pilot
GaryX1001's Avatar
Germany
Joined May 2009
today i had my first real flight, fast, nose in etc..
im still full of adrenaline after this flight
E-SKY Belt CP v2 - first real flight (7 min 19 sec)
Old Oct 08, 2009, 01:06 PM
BadPilot
badpilotto's Avatar
Joined Nov 2007
Gary,
What was the problem with the heli from the first vid? What did you do to change it?
John
Old Oct 08, 2009, 01:25 PM
BadPilot
badpilotto's Avatar
Joined Nov 2007
Gary,
How many flight do you have on that heli? It looks like your way passed hover..... LOL
TFS the vid
John
Old Oct 08, 2009, 02:34 PM
Builder & Pilot
GaryX1001's Avatar
Germany
Joined May 2009
Originally Posted by badpilotto
Gary,
John
i dont really know what you mean..
i havent had any problem at all or do you mean why i didnt flew like in the last vid?
in the last vid i was bored only hovering around and trying to fly.
so i just took off and flew
Old Oct 08, 2009, 02:39 PM
Builder & Pilot
GaryX1001's Avatar
Germany
Joined May 2009
Gary,
TFS the vid
John
i dont know, i can tell you how often i had to repair
1 crash because of loosing orientation and noob acting
1 crash because motor shut down cuz of low battery
i dont know how often i have charged the battery.. maybe 30x ?
at the beginning i had alot of problems with the tail drifting, so i couldnt really fly at all. so most of the time i hovered around testing and adjusting.
Old Oct 09, 2009, 03:41 AM
BadPilot
badpilotto's Avatar
Joined Nov 2007
Gary,
Post number 7 was meant for another thread, sorry.
I too have rebuilt and repaired my heli many times. I wish I had them here now. I am in the middle of moving and have shipped all of my helis.
As for the flight time, do you set an alarm for 5 minutes? If you do that then it will not matter how much batt is left over, you will not lose power and it saves that batt from being over drained. I have had a few batts puff because of over drawing the voltage (flying too long).
John
Old Oct 09, 2009, 06:18 AM
Builder & Pilot
GaryX1001's Avatar
Germany
Joined May 2009
Gary,
John
the crash happend after 1:45 min. i had my girlfriend to charge my batteries, so i think she discharged instead of charging full. no idea.
when i fly 7 min in idle up, my 2200mha battery is still at 11.6v.
Old Oct 10, 2009, 02:02 AM
BadPilot
badpilotto's Avatar
Joined Nov 2007
Gary,
Sorry to hear about a crash. On the plus side you can build her better....
What type of batteries are you using? I was using Thunder Power but switched to Zippy due to price and quality.
John
Old Oct 10, 2009, 04:09 AM
Builder & Pilot
GaryX1001's Avatar
Germany
Joined May 2009
Gary,
John
1 original esky 1800mah
1 XCell eco 2200mah 20c
building is a thing.. im still not happy with the swash plate..
Old Oct 10, 2009, 04:11 PM
BadPilot
badpilotto's Avatar
Joined Nov 2007
Gary,
That is a huge weight difference between a 1800 and 2200mAh batts. Of course that depends on the manufacturers and what "C" rating they are.
If your G-friend charged the batt you should slap her (just kidding) it is your own fault for not checking all the components prior to flight. I keep an inexpensive batt volt plug with me all the time. I double check batts prior to flight in case they were damaged after my last charging (you just never know). I spend too much time and money in purchasing, building and handling of my helis and planes in order to fly. I will not let anything stop me from all of my check to ensure the safety of my helis, planes and equipment, not even my wife.
What is wrong with the swash plate? I keep a full work-shop on hand in order to rebuild any of my ACFT. I shop for items I may need when they are on sale, then I purchase in quantity. Just something to think about.
Take care.
John
Question any thing i should do b4 i fly my belt cp? letard Mini Helis 5 Dec 25, 2007 12:10 AM
Help! blades for my belt cp evangelist Mini Helis 3 Oct 24, 2007 01:32 PM
Question Is my belt cp rtf ready or are their things that need to be done before I fly? evangelist Mini Helis 6 Oct 17, 2007 06:22 PM
Question Learning to fly a Blade CP - Advice Please!! Creosote Simulators 7 Jul 20, 2006 04:27 PM
Discussion Learning to fly my Blade CP skylane42 Micro Helis 1 Apr 14, 2006 09:01 PM
