Go Back   RC Groups > Aircraft - Electric - Helis > Micro Helis
Old Sep 23, 2009, 02:00 PM   #1
Hot Glue and Blu!
Flying-Monkey's Avatar
mSR TX Setups, Tweaks, Mods Tips, and Upgrades (a work in progress)
I will eventually edit this into a cohesive posting, but for now I am collecting the data.
Please feel free to add to this, I will just edit it back into this post.
Manuals
RTF Manual
http://www.heliproz.com/images/BlademsrManual.pdf
BNF Manual
http://www.horizonhobby.com/ProdInfo...080-Manual.pdf
Parts Listing
PDF exploded view
http://image2-0.rcuniverse.com/e1/fo...06/Ez83001.pdf
Radio Settings
mediclavina's Thread: MSR is a lot more fun when using a programmable TX
http://www.rcgroups.com/forums/showthread.php?t=1108866
grnbrg's TX suggestions
http://www.rcgroups.com/forums/showp...&postcount=914
DX7
Daedalus66's DX7 Dual Rate Settings.
http://www.rcgroups.com/forums/showp...postcount=3068
sideburn's DX7 use of flight mode for multi settings.
http://www.rcgroups.com/forums/showp...postcount=3360
stersman's DX7 settings
http://www.rcgroups.com/forums/showp...1&postcount=19
tommythecat's DX7 Settings
http://www.rcgroups.com/forums/showp...postcount=1109
Piper J3's "Outdoor" DX7 Settings.
http://www.rcgroups.com/forums/showp...postcount=2179
Piper J3's "Indoor" DX7 Settings
http://www.rcgroups.com/forums/showp...postcount=2173
DX6i
j.picken's DX6i settings
http://www.rcgroups.com/forums/showp...&postcount=811
iAdam's DX6i settings (at bottom of post)
http://www.rcgroups.com/forums/showp...postcount=1074
Pilotrob56's DX6i settings
http://www.rcgroups.com/forums/showp...postcount=1423
beetyii's DX6i mixing settings
http://www.rcgroups.com/forums/showp...59&postcount=1
linac's DX6i settings
http://www.rcgroups.com/forums/showp...postcount=4341
LP5DSM/HP6DSM
RCBABBEL'S 5 Channel Info
http://www.rcgroups.com/forums/showp...postcount=1086
FUTABA 9CAPS
fairplane's FUTABA 9CAPS settings
http://www.rcgroups.com/forums/showp...&postcount=207
Radio Mods
Bob K's Stick Extensions for the RTF package TX
http://www.rcgroups.com/forums/showp...56&postcount=1
Battery
Greg D's recommendation for battery installation.
http://www.rcgroups.com/forums/showp...8&postcount=20
Daedalus66's Description and Tip on LVG (Low Voltage Cutoff)
http://www.rcgroups.com/forums/showp...postcount=3752
Batery ratings explained by 9sec240
http://www.rcgroups.com/forums/showp...&postcount=931
HobbyCity/HobbyKing Flight Max Battery
http://www.hobbycity.com/hobbycity/s...idProduct=8864
RCBABBEL's battery mods
Part 1
http://www.rcgroups.com/forums/showt...r#post13012360
Part 2
http://www.rcgroups.com/forums/showp...postcount=1127
Battery connections
http://www.rcgroups.com/forums/showp...postcount=1952
Charger
Charger Mods
A whole thread, started by modfly
http://www.rcgroups.com/forums/showthread.php?t=1108545
TheSteve's AA Mod
http://www.rcgroups.com/forums/showp...postcount=1317
melcrose's AA Non-mod Mod
http://www.rcgroups.com/forums/showp...postcount=1435
Blades
Piper J3's Blade Mod for allowing nearly 90* movement in a crash.
http://www.rcgroups.com/forums/showp...postcount=2562
Kai_Shiden's Walkera Blade Mod
http://www.rcgroups.com/forums/showp...postcount=1398
Custom CF Blades thread started by CQE Flash
http://www.rcgroups.com/forums/showthread.php?t=1082651
WildBlueYawnde's Colorful Glow In The Dark Blade Mod
http://www.rcgroups.com/forums/showp...postcount=3719
DarkHorse's Blade Balancer
http://www.rcgroups.com/forums/showp...postcount=4317
Head
richord's head overview.
http://www.rcgroups.com/forums/showp...postcount=9001
richord's head break down.
Blade Grips
Barl14's Tips, including the Fingernail Polish on Blade Grips tip
http://www.rcgroups.com/forums/showp...16&postcount=2
rwl's CA Mod
http://www.rcgroups.com/forums/showp...postcount=2538
Calibration Tool
Explained by pigaro
http://www.rcgroups.com/forums/showp...&postcount=962
Swash Plate
Piper J3's Swash Plate Warning
http://www.rcgroups.com/forums/showp...postcount=2531
http://www.rcgroups.com/forums/showp...postcount=2561
EatAtJoes Tells You How To Remove Your Linkages Without Breaking Your Balls
http://www.rcgroups.com/forums/showp...postcount=3770
Kelley's Metal Swashplate from Xtreme, and a Walkera Blade Mod
http://www.rcgroups.com/forums/showp...postcount=3718
Servos
Razors edge 29's servo tips
http://www.rcgroups.com/forums/showt...9#post13201864
Tail
Kilo60's "T-Rex" Tail Fin Mod
http://www.rcgroups.com/forums/showp...4&postcount=19
rcworm's "Weak Tail Motor" Mod
http://www.rcgroups.com/forums/showp...8&postcount=10
The infamous "Tail motor mod" debate.
http://www.rcgroups.com/forums/showthread.php?t=1104028
Razors edge 29 and EatAtJoes' cooperative Solution to the Tail Motor Problem
http://www.rcgroups.com/forums/showthread.php?t=1115714
RemE's HeatShrink Mod
http://www.rcgroups.com/forums/showp...postcount=2850
EatAtJoes' Tail Rotor Binding Fix
http://www.rcgroups.com/forums/showp...postcount=3066
i812's Tail Motor Repair Directions.
http://www.rcgroups.com/forums/showp...postcount=3809
maukabud's Tail Blade Replacement/SubTailboom/MetalicSharpie Tips
http://www.rcgroups.com/forums/showp...&postcount=171
ShuNut's $5 Replacement Tail Motor.
http://www.helifreak.com/showthread....71#post1669171
beckylane's Brass Washer/Trim/Binding Advice
http://www.rcgroups.com/forums/showp...&postcount=152
beckylane's Swash Leveling Tips
http://www.rcgroups.com/forums/showp...&postcount=166
Landing Gear
Kelly's Landing Gear Mod
http://www.rcgroups.com/forums/showp...postcount=4327
Scale Bodies
sky guy's scale body thread
http://www.rcgroups.com/forums/showthread.php?t=1110869
turbonut's "Wet Huey"
http://www.rcgroups.com/forums/showp...&postcount=906
FR4-Pilot's Paper Canopies
http://www.rcgroups.com/forums/showp...postcount=2033
Flying-Monkey's tip for moving up from a coaxial, and adding aileron inputs.
http://www.rcgroups.com/forums/showp...postcount=3169
http://www.rcgroups.com/forums/showp...postcount=3375
EatAtJoes' Advice for Flying With Aileron Inputs (for people moving up from coaxial helicopters)
http://www.rcgroups.com/forums/showp...postcount=3172
Flying Outdoors
EatAtJoes' tips on safe flying distances
http://www.rcgroups.com/forums/showp...postcount=2969
TBE Toilet Bowel Effect
spudandretti's tips
http://www.rcgroups.com/forums/showp...postcount=1048
FR4-Pilot's Paper Shim Mod
http://www.rcgroups.com/forums/showthread.php?t=1115384
Kilo60's Loose Main Shaft/Main Gear
http://www.rcgroups.com/forums/showp...postcount=3143
EatAtJoes' Tips To Eliminate TBE
http://www.rcgroups.com/forums/showp...postcount=3173
Steve4ustin's loose bushing solution
http://www.rcgroups.com/forums/showp...48&postcount=1
Lights
http://flightlights.net/microsub.html
Stats, Calculations, and Formulas
41North's "Useless mSR measurement for geeks"
http://www.rcgroups.com/forums/showp...postcount=2922
EatAtJoes' "Useless Information" Measurements.
http://www.rcgroups.com/forums/showp...postcount=3133
EatAtJoes' Formula for Calculating Current Draw
http://www.rcgroups.com/forums/showp...postcount=3781
Miscelanious
miataman's price breakdown
http://www.rcgroups.com/forums/showp...&postcount=799
minirips2 TriFlow tips
http://www.rcgroups.com/forums/showt...php?p=13011928
Piper J3's paranoid conspiracy theory...
http://www.rcgroups.com/forums/showp...postcount=1545
Anti-G's Flying in Wind Advice.
spudandretti's packing job
http://www.rcgroups.com/forums/showp...postcount=2671
Repairs
Razors edge 29's Fuselage Pins Repair
http://www.rcgroups.com/forums/showp...postcount=3377
Reviews/Comparisons
Martyn McKinney's Walkera 4#3B/Eflite Blade mSR comparison
http://www.rcgroups.com/forums/showp...postcount=1517
Flying-Monkey is offline Find More Posts by Flying-Monkey   Reply With Quote
Old Sep 23, 2009, 03:07 PM   #2
Post: MSR transmitter mod
My stick extension mod works great for those of us with large
hands. Adjustable,reversable,cheap. Looks hokey, but totally
does the job!
Bob K
Bob K is offline Find More Posts by Bob K   Reply With Quote
Old Sep 24, 2009, 01:16 AM   #3
Tri-C member
Razors edge 29's Avatar
Besides the cusker mod for MSR, are there any mods to strengthen the swash? Particularly the arm end ball links? Like the MCX they can break off very easilly when trying to adjust the swash
Razors edge 29 is offline Find More Posts by Razors edge 29   Reply With Quote
Old Sep 24, 2009, 10:43 AM   #4
Tri-C member
Myself and eatatjoes have come up with an alternative to tape/heat shrink for the tail rotor. You can add this if you like.
Old Sep 24, 2009, 10:59 AM   #5
Hot Glue and Blu!
I am working on it...
I started over reading the thread Blade MSR Confirmed. PICs Below + video and video review , about where the mSR's actually started getting into peoples hands, and I have been going through it, page by page.
I think I am up to page 16 (100 posts per page) with about another 15 or so to go.
Of course, I still have the hundred or so other mSR threads to go through, and that's just on RCGroups.
Last edited by Flying-Monkey; Sep 24, 2009 at 11:02 AM. Reason: http://www.rcgroups.com/forums/showthread.php?t=1084185
Old Sep 24, 2009, 02:23 PM   #6
Tri-C member
There is this
and this
Blade MSR Tail Motor Safety Fix (8 min 22 sec)
Old Sep 24, 2009, 03:13 PM   #7
Helis and Fixed Wing
Thanks for a very useful resource.
Daedalus66 is offline Find More Posts by Daedalus66   Reply With Quote
Old Sep 24, 2009, 10:12 PM   #8
Silver Member
Site Sponsor
Diggs's Avatar
Send a message via Yahoo to Diggs
Fine Job Monkey!!!
Diggs
Diggs is offline Find More Posts by Diggs   Reply With Quote
Old Sep 24, 2009, 10:25 PM   #9
Aircraft Part Separator
Greg D's Avatar
subscribing - thanks for taking the time to do this
Greg D is offline Find More Posts by Greg D   Reply With Quote
Old Sep 24, 2009, 11:27 PM   #10
for those with weak mSR tail motor
For those who are having their tail not holding on a throttle punch it could mean your tail motor is starting to die. You will eventually have to get a new motor BUT in the meantime I found that if you use the propeller from one of those Silverlit x-twin planes (or similar) like this one:
http://bit.ly/niYNB
It is a bit longer than stock and works excellent. It holds the tail much better even with the dying motor and when I get my new motor I might just keep this blade for the tail.
Give it a try-- you will get a better hold on the tail.
Cheers!
i.
rcworm is offline Find More Posts by rcworm   Reply With Quote
Old Sep 25, 2009, 04:43 AM   #11
Solidarn's Avatar
Very nice job Monkey!
Solidarn is offline Find More Posts by Solidarn   Reply With Quote
Old Sep 25, 2009, 07:48 AM   #12
Subscriber....
Elisecat is offline Find More Posts by Elisecat   Reply With Quote
Old Sep 25, 2009, 09:22 AM   #13
**Tri-Flow Joe**
FM,
A very nice service you have done for mSR lovers!
rc
tfj
ps. Found a prob with the "minirips2 TriFlow tips" link.
Click on it and it takes you to
"E-Flite Celectra 4 port charger mods" thread.
RCBABBEL is offline Find More Posts by RCBABBEL   Reply With Quote
Old Sep 25, 2009, 09:44 AM   #14
Very good thread.....
I notice the main shaft have a slope of 5°
mikiko is offline Find More Posts by mikiko   Reply With Quote
Old Sep 25, 2009, 10:04 AM   #15
▲ Click ▼ for blog
FR4-Pilot's Avatar
Thank you for compiling all of this!
Very useful.
-John
FR4-Pilot is offline Find More Posts by FR4-Pilot   Reply With Quote
Yippee! Work in progress - big panorama! CactusJackSlade Aerial Photography 7 Apr 02, 2004 02:20 PM
Kits, Plans & Work-in-Progress Pusher Jets Gordon Electric Ducted Fan Jet Talk 49 Dec 02, 2003 02:07 PM
My new GWS Spitfire - work in progress mattski GWS (Grand Wing Servo) 2 Sep 07, 2003 06:50 PM
RBC Beaufighter (work in progress!, long progress) stuart warne Scale Electric Planes 10 Apr 13, 2003 10:33 AM
Work in Progress Sail 'n Soar Parkflyers 2 Sep 21, 2002 01:13 PM
Congratulations SimpleM!
