Old Sep 22, 2009, 12:30 PM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Poll
What do you guys think of Hyperoin Motros, and Castle Creations Speed Controllers ???
I am building an electric sailplane, and I will be using a 5000 mAH 4 cell pack for power, being able to cruise about 45 minutes is important so this size is set in stone. I also need to climb very quickly for soaring when conditions permit so I need to have motor that will easily use 600 watts of power on a long climb without overheating. I am looking at a Hyperoin motor with a Castle creations speed controller, what do you guys think of these brands, are they very good quaity ? Also, what size motor would I need, the glider is in the picture below, it will be a bit heavy with the big battery.
http://www.hobbycity.com/hobbycity/s...__(99.6in)_ARF
Any suggestions will be appreciated.
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Sep 22, 2009, 12:58 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Why do you say you need at least 600 watts? How much does that plane weigh?
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Sep 22, 2009, 02:33 PM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
According to the link: 38 oz - 49 oz approx. (I'm guessing that's based on what you put into it).
Castle Creations and Hyperion are both well known reliable brands. There should be no problem with either one.
Try using a motor calc like this one: http://www.adamone.rchomepage.com/calc_motor.htm
cjbucher is offline Find More Posts by cjbucher
Old Sep 22, 2009, 03:12 PM
RobC(UK) is offline
Find More Posts by RobC(UK)
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
Reading the reviews the ready to fly weight come out at 68oz.
RobC(UK) is offline Find More Posts by RobC(UK)
Old Sep 22, 2009, 06:48 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
cjb ... you read the wrong number... the 38-49 was wing-loading in g/dm2.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 22, 2009, 07:24 PM
Joined Jul 2006
How's this?
According to WebOCalc, you don't need anywhere near 600 watts to get a greater than 1:1 thrust to weight ratio.
Using an average, run of the mill, 75% efficient outrunner of 500kV and only pulling about 25 amps static current, we should be able to develop about 61 ounces of thrust on your 49 ounce plane.
The power in will only be about 367 watts on an AeroNaut 14x10 folder prop.
Now, I am assuming that the 14x10 AeroNaut has the same prop constants as an APC 14x10E prop, so Phil (Dr Kiwi) may have to chime in and tell us the actual prop constants. If he knows them, then we can fine tune the results to reflect the actual prop constants.
All calculations were performed using WebOCalc 1.5 written by RCG member FliesLikeABeagle
Chuck
Old Sep 22, 2009, 08:21 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I think we need to know the correct AUW: here is one guy's cumulative component weights... comes out to be 2178g = 76.7oz!
alex4orly
I was puzzled with what the web site says about the expected weight 1,400 . When I finished assembly and put it all on my scale it comes up to a total of 2,178 grams, this is far off the suggested weight on the web site. details:
Fuselage all up with a 3S 3300 mah battery = 1,264
canopy = 54
right wing = 308
left wing = 316
stainless steel tube = 236
Waiting for a carbon fibre replacement, will reduce by 200 g, still too heavy.
Another guy got 1438g for the bare components to which he needed to add ~160g motor, 25g prop etc, 60g ESC, 425g battery... so he's up over 2100g too.
Old Sep 22, 2009, 08:36 PM
Joined Jul 2006
alex4orly
canopy = 54
right wing = 308
left wing = 316
Holy Cow!
Makes me glad I picked the 2 meter ParkZone Radian with the sweet stock ParkZone 480 brushless and a 10x6 AeroNaut folder on a 3s Li-Po.
All up weight = 25 ounces, and will haul some serious tail up to altitude.
Chuck
Old Sep 22, 2009, 08:40 PM
cjbucher is offline
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
But this is what it said:
Specification;
Wing Span: 2530mm (99.6inch)
Weight: 1,100 ~ 1400g <--- ~38 oz to ~49 oz
Length: 1170mm (46inch)
Wing Area: 28.5dm2
Wing Loading: 38~49g/dm2
Airfoil: HQ 3015
I guess their estimate is a bit off!
Old Sep 22, 2009, 08:45 PM
Challenger 413 is online now
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
I agree, it would be best to pick the motor after plane is built, including servos, prop, battery, etc..
That weight is a way off from what the manufacturer shows and what others are actually getting...could make the motor you buy too small going by what the manufacturer shows as the finished weight...
Challenger413
Challenger 413 is online now Find More Posts by Challenger 413
Old Sep 22, 2009, 09:00 PM
skyking1231 is offline
Find More Posts by skyking1231
uhhh....this thing on?
skyking1231's Avatar
Long Island, NY USA
Joined May 2005
I think castle creations makes some really good ESCs. the great thing is if you get the castle link you can update the firmware on the ESC. With some of my older ESC's...there has been more features added to the firmware over the years since when I first bought them.
Can also use it to program the ESC as well.
skyking1231 is offline Find More Posts by skyking1231
Old Sep 22, 2009, 09:07 PM
Joined Jul 2006
Some of the reviews are complaining that the suggested motor is a 35mm, yet guys are saying that the opening is only 32mm. Should make for an interesting fit...
Old Sep 22, 2009, 09:29 PM
Dickinson, Tx.
Joined Sep 2004
As far as Hyperion motors and CC ESC's.
I have a Hyp. 2213/24 motor, but have never ran it. I have read that they are good motors, being in the middle range of standards.
I have (10) CC brushless ESC's and have had great luck with them. Had a CC-10 that lost its memory during a link up. Mailed it in and got a new one, not bad for the price of a stamp. Had a 4 year old CC-35 go bad and sent it in with $30.00 and got a new CC-35 a couple of weeks later. With the rest, I have never had any problems. I feel they are the best brand of ESC's sold.
Challenger413
What do you guys think of the OMNI charger? Vonbaron Batteries and Chargers 0 Oct 09, 2002 01:03 PM
What do you guys think of this camera? I FO nut Aerial Photography 3 Oct 04, 2002 12:35 AM
what do you guys think???? AirWarriorBelgy Parkflyers 13 Sep 16, 2002 01:32 PM
What do you guys think of the Jerry vs the Windy from NSP CHRIS_00 Thermal 3 Mar 12, 2002 12:00 PM
Stock Up on Equipment or Get an LMR Glider, What do you Guys Think? AndrewK Electric Plane Talk 6 Jun 17, 2001 07:43 PM
