Old Sep 21, 2009, 08:15 PM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Mylar/plastic for exhaust ducting?
Where is the best source to buy rolls of mylar or similar plastic for making exhaust ducting. When we were at E-jets, it seems that everyone used mylar or some type of acetate sheet. In Arizona, mylar warps because our temps here sitting on the tarmac can exceed 140 degrees. Stu (Stumax fame) mentioned some type of PTGE (sp?) plastic. Any ideas what to use and where to get it?
JimDrew is online now Find More Posts by JimDrew
Old Sep 21, 2009, 08:33 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I use drafting mylar, never had a problem with heat warping it. Most drafting supplies offices sell it.
Bob
bruff is online now Find More Posts by bruff
Old Sep 21, 2009, 08:35 PM
PlumberJohn is offline
Find More Posts by PlumberJohn
John Green
USA, FL, St Petersburg
Joined Dec 2007
I have been purchasing mine locally for ten or eleven years at:
Ge Polymershapes
12707 49th Street North
Clearwater, Fl
727-573-3535
Usually use .01 polycarbonate (lexan). I have found it's fairly heat resistant as I use in with my ICDF's as well and the tube is really close to the tuned pipe. Thicker polycarbonates also work in the inlet when reinforced with carbon. Glues together very well with standard Elmer's contact cement or equivalent.
PlumberJohn is offline Find More Posts by PlumberJohn
Old Sep 21, 2009, 08:55 PM
Lboogie is offline
Find More Posts by Lboogie
Lboogie's Avatar
Sebastian Fla
Joined Nov 2005
http://www.acp-composites.com/home.php?cat=4752
About halfway down the page. MylarŪ (PET Polyester Film). I like the 48 inch widths. The material comes rolled into a tight radius and as such with the 48" width the "roll" is in the correct direction for thrust tubes up to 48" (material will not completely flatten out).
It's a thick material (0.014") and is unaffected by Florida summer heat. The efflux tube for one of my jets laid flat measures approx. 16" by 29" and weighs 5 oz.
The material is also good for wet fiberglass layup work.
Regards,
Leonard
Lboogie is offline Find More Posts by Lboogie
Old Sep 21, 2009, 09:30 PM
Lake Havasu, AZ
Joined Jun 2005
Thanks guys!! Looks like we have a source!
Old Sep 21, 2009, 10:01 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Jim i use mylar that is made for printing drawings ,could try at a printing store.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Sep 21, 2009, 10:36 PM
One Six Right is offline
Find More Posts by One Six Right
another MONSTER ?
One Six Right's Avatar
Valencia, CA
Jim,
Also, Aaron Bros art marts or any good art store carries .005 mylar drafting film. A 40" x 12 foot roll is is about $13 at Aaron bros.
BTW: .005 is plenty thick enough for even big jets.
I would use aluminum furnace tape (hdwr store) cut to the width you want, for assembling and mounting the thrust tube. The alum is conforming and the adhesive will hold up better to the higher temps, than a cellophane type tape.
Gary
One Six Right is offline Find More Posts by One Six Right
Old Sep 21, 2009, 10:43 PM
sheppard559 is offline
Find More Posts by sheppard559
Joined Mar 2008
man i went all over lookin for this stuff(staples, walmart, target,etc. ALL the WRONG places!!!)lol
sheppard559 is offline Find More Posts by sheppard559
Old Sep 21, 2009, 11:02 PM
T-spin is online now
Find More Posts by T-spin
Joined Mar 2005
Tam sells it .
Tony
T-spin is online now Find More Posts by T-spin
Old Sep 21, 2009, 11:38 PM
Lake Havasu, AZ
Joined Jun 2005
I can't imagine anything thinner than .030 working properly. I know the thin Mylar we tried in the past just ripped right open from just 15 pounds of thrust being compressed from 5" to 3.3875".
Old Sep 21, 2009, 11:47 PM
another MONSTER ?
Valencia, CA
Jim,
Where did it rip? Probably at the feedthrough for the wires, or the edge Joint. Be sure to reinforce the feedthrough area and provide for a well overlapped edge. Tape the full length of the duct, INSIDE and OUTSIDE.
Old Sep 22, 2009, 12:05 AM
John Green
Joined Dec 2007
The .01 is plenty thick enough to stand up to almost any abuse you can give it. I can cut it but have never torn it even in crashes. The contact cement although a little messy is a superior bonding method. Taped joints seem to open up in the heat of the sun even if they are done inside and out.
Old Sep 22, 2009, 12:06 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
That what i do ....but then im only doing 3-4 lbs of thrust.
Old Sep 22, 2009, 12:31 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
im using drafting mylar on my 3600W midi setups. using packing tape to hold the seam, and a couple bands around it ever 8" or so. i plan to use it on my 5kw turbax. i dont think there will be a issue. you can rip that stuff to save yourlife unless it has a tear or a cut already in it.
corsair nut is offline Find More Posts by corsair nut
Old Sep 22, 2009, 12:36 AM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
I get mine at Tap Plastics. They have a website, but I live 15 minutes from one of their stores. They have several types at the store and sell it by the foot.
Steve C
Steve C is offline Find More Posts by Steve C
Help! Making patterns for exhaust ducting? badbill Electric Ducted Fan Jet Talk 7 May 13, 2009 04:25 PM
intake and exhaust ducting for gws 40? REVKEV6 Electric Ducted Fan Jet Talk 2 Jan 06, 2005 09:23 AM
Drastically oval Exhaust Ducting wtghost Electric Ducted Fan Jet Talk 2 Jun 12, 2003 11:13 PM
Plastic for canopy and cowl? Mike Hall The Builders Workshop 1 Nov 28, 2002 12:41 AM
mylar film for vaccum bagging.... buckeyes1997 Foamies (Kits) 2 Jan 25, 2002 05:51 PM
