Old Jan 27, 2013, 11:32 AM
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
The 5v should be ok. These cams also works as a webcam hooked up 5v from the USB. (Other's have done this mod and confirmed that it works ok at 5v.)
http://www.rcgroups.com/forums/showp...postcount=1766
As far as the 40 A Esc is concerned, it's actually the Esc's BEC rating that's important. The cam will be running off the BEC, not the ESC.
To know for sure if the BEC can handle the exta current draw from the cam, you'd have to do some current draw tests to be sure if it's within the BEC's specs.
KC
KC is offline Find More Posts by KC
Old Jan 27, 2013, 09:12 PM
United States, FL, Miami
Joined Sep 2011
i purchased the turnigy keychain camera from hobby king around a year ago, and can't seem to get it charging again. When i plug it into my computer the yellow/orange light stays solid, but does not blink (the manual on the hk forums says that it should blink to charge). I havn't tried charging it for more than a few minutes, but as of right now i can't get the light to turn on when not connected to the computer
i just opened it up and then battery may be a little puffed... i dont have another one to base it off of though
mat3415 is offline Find More Posts by mat3415
Old Jan 28, 2013, 02:33 AM
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
A puffed battery is bad news, I wouldnt charge it in that state , its small but it could still go up in flames.
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Jan 28, 2013, 05:12 AM
United Kingdom, England, Worcester
Joined May 2010
KC
Ok cheers - what's an easy way to do this? I've got a voltmeter etc but have no idea what I need to do or anything
The ESC has a 3A BEC, but I'm wondering with the Servos if the camera will draw too much - we shall see!
Add1ct3dd is offline Find More Posts by Add1ct3dd
Old Jan 28, 2013, 05:24 AM
KC
KC's Avatar
Joined Sep 2006
With the 3A BEC, you should be fine. The cam only draws ~120mA. The Radian Pro has 6 servos as well, but it's stock BEC is only rated at 700mA. If the RP's 6 servos can operate within 700 mA's, your Bixler probably does too.
Old Jan 31, 2013, 10:41 AM
Tampa, Florida
Joined Jun 2006
can someone tell me what is the best keychain camera now? All the #1 to #17 versions have me confused. A buddy of mine saw an old one i had and asked me where to buy one
flashprash65 is offline Find More Posts by flashprash65
Old Feb 01, 2013, 11:56 AM
Michigan, USA
Joined Nov 2009
#3 or #16. See the 808 Basic Q&A
eBay eletoponline365, goes by many eBay names, is the producer of the #3 and #16. The #3 is 480p and is cheap. The #16 is 720p, about US$40, video out (FPV), choice of three lenses, tons of support from a very enthusiastic group of RCGroups people.
http://www.rcgroups.com/forums/showthread.php?t=1556994
http://www.rcgroups.com/forums/showthread.php?t=1777846
Normandy5 is offline Find More Posts by Normandy5
Old Feb 01, 2013, 02:50 PM
KC
KC's Avatar
Joined Sep 2006
I Recently came across this pretty good YouTube video comparison.
The 808 #16 Micro HD Cam (21 min 43 sec)
Old Feb 01, 2013, 04:59 PM
gapi's Avatar
North Georgia
Joined Oct 2010
I can comment on the last part of the video as to the question, "Is this camera for perverts?"
I don't know about perverts but - As a private investigator I can tell you I have successfully closed many-a- case using a #3. I could have closed more if it was better in lower lighting conditions.
Leaving it in a room to record have also been successful.
And they get around security stations where you empty your pockets into a bowl.
Heh!
gapi is offline Find More Posts by gapi
Old Feb 03, 2013, 09:50 PM
Battery Powered==(*)==
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
Where to buy the best lower priced and high end
. #16 808. Any good Ebay sellers for these?
tomcor is offline Find More Posts by tomcor
Old Feb 03, 2013, 10:00 PM
KC
KC's Avatar
Joined Sep 2006
http://www.rcgroups.com/forums/showp...13&postcount=2
Old Feb 09, 2013, 09:36 PM
Joined Nov 2008
FWIW. My #7 camera was forgotten about in a car this winter. When I found it of course the battery was dead. I desoldered it from the board and put it on a voltmeter, it only read .1v. So I put it on a charger, nicad setting, at .1amps. The voltage came up right away and I let it charge for about 3 minutes. Then I set the charger to lipo, 1s, .1a and it took a full charge, camera works fine now.
Note, the battery was NOT puffed, and I would NOT ever charge a puffed lipo of any size..
Also FWIQ, I was going to buy a replacment battery from HK,
(http://www.hobbyking.com/hobbyking/s...gle_Cell_.html) That one has dimensions that should work.
I dont know if the above was ever posted, I hope the info was useful, thanks
kamlooper is offline Find More Posts by kamlooper
Old Feb 19, 2013, 04:55 AM
Joined Feb 2013
Hi everybody here
I am french, I am in France so sorry for my bad english.
I have this gadget video camera me too but since a moment there is no more light even after charging the battery.
Do you have an idea about this problem ? I bought it on www.ebay.fr to a chinese seller.
It's genius this little technology to make videos, but me it's not on plane.
Francegadget is offline Find More Posts by Francegadget
Old Feb 19, 2013, 05:04 AM
crycroft's Avatar
Australia, VIC, Hillside
Joined Oct 2006
my one did the same thing just get a paper clip and press the reset button
crycroft is offline Find More Posts by crycroft
Old Feb 19, 2013, 05:10 AM
Joined Feb 2013
I often have pressed the reset button but it's the same, it seems it doesn't work no more.
"a paper clip" I don't understand what you mean.
My BigMig came today... Wufnu 1/2A Planes 41 Apr 21, 2005 05:45 PM
Cool My new plane came today! glowpwer flyer Fuel Plane Talk 4 Jan 09, 2004 01:11 PM
Yippee! My new Micro V canopy came today FrankW Electric Heli Talk 14 Oct 20, 2003 03:35 PM
My Tantrum came today ManxSR Parkflyers 6 Jul 01, 2003 11:58 PM
My used Housefly came today. Impressive kit! Spaulding Electric Heli Talk 2 Apr 08, 2002 09:39 AM
