Old Aug 03, 2011, 05:40 AM
GoFaster is offline
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Not in my DLGs but it will fit in my F3B models. Perhaps one of the new telemetry-capable rx's will fit in a DLG...
GoFaster is offline Find More Posts by GoFaster
Old Aug 18, 2011, 06:29 AM
GoFaster is offline
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Originally Posted by JimDrew View Post
That is a neat project. So neat in fact that I laid out a board today to make a sensor for our radio system using the BMP085 pressure chip. I just modified one of my existing sensor board designs. I can change the EVO firmware to add this sensor.
I will post PCB layout and source code as soon as it is tested.
Jim, are you still working on this side project?
Old Aug 18, 2011, 10:39 AM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Yep, got some sample boards and built them. Working on the very long and drawn out code for the compensation.
JimDrew is online now Find More Posts by JimDrew
Old Aug 18, 2011, 10:43 AM
Lake Havasu, AZ
Joined Jun 2005
Here is what the board looks like. Fits in the standard sensors case (same box that the XDP uses).
Old Aug 18, 2011, 12:23 PM
GoFaster is offline
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Nice! Will you be selling these or releasing the schematics?
Also what is the empty spot next to the 3-pin connector for, along with the 5 empty solder pads next to the pressure sensor?
Old Aug 18, 2011, 02:58 PM
Lake Havasu, AZ
Joined Jun 2005
Do you mean the blank portion of the circuit board layout? Nothing goes there. The 5 holes are for the programming interface for the PIC.
I will be releasing the schematic, PCB artwork, and code for it. We may also produce them. I really don't want to ever be in the sensor business.
Old Sep 06, 2011, 01:16 PM
yyz is offline
yyz
Find More Posts by yyz
yyz
yyz's Avatar
USA, CA, Paso Robles
Joined Dec 2004
Another Royal EVO upgraded to 2.4 this weekend. This one was my 9 channel with the 10 channel XPS receiver in one plane and a Nano 6 in another.
Installation instructions need updating as the 2.4 antenna on the transmitter module is now installed down through the top rather than up through the bottom.
yyz is offline Find More Posts by yyz
Old Sep 06, 2011, 07:05 PM
Lake Havasu, AZ
Joined Jun 2005
Yeah, we definitely need to update that now that we are pulling this out of a beta stage to production.
Old Sep 06, 2011, 11:40 PM
yyz is offline
yyz
yyz
yyz's Avatar
Joined Dec 2004
Jim,
Is there any way to get at the telemetry data (serial, i2c, etc) at the transmitter end rather than sending it to the EVO's display?
Old Sep 07, 2011, 10:13 AM
Lake Havasu, AZ
Joined Jun 2005
The data going to the EVO is sent its encoded scheme. There is no way to get that data from our module in a normal format.
Old Sep 07, 2011, 04:12 PM
yyz is offline
yyz
yyz
yyz's Avatar
Joined Dec 2004
Thanks Jim. Makes that a pretty simple decision.
Old Sep 09, 2011, 06:00 AM
JonyEpsilon is offline
Find More Posts by JonyEpsilon
JonyEpsilon's Avatar
London, UK
Joined Jan 2009
Just stumbled across this ...
Thanks for the kind words!
I now have more experience of the BMP085's quirks than any person would want, so feel free to PM if I can help in any way.
One thing to watch out for, if you decide to go to production, is that approximately 5% of BMP085s (tested from several batches) have higher noise than usual (by a factor of two or three). The openaltimeter BMP085 driver has a software fix for this (oversampling the temperature) which is far from obvious!
Jony
JonyEpsilon is offline Find More Posts by JonyEpsilon
Old Sep 09, 2011, 10:19 AM
Lake Havasu, AZ
Joined Jun 2005
Thanks for the heads up. I am still working (in my spare time) on the math required to do the conversion. I looked at some Proton Basic source to get the basic equation. Doing it in assembly with a 8 bit CPU is a bit timing consuming, but there is really no rush in providing the data as outgoing telemetry info is not real fast anyways.
Old Oct 17, 2011, 06:02 AM
GoFaster is offline
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Any progress on this side project? Thx.
Old Oct 17, 2011, 12:06 PM
Lake Havasu, AZ
Joined Jun 2005
Worked a little this weekend on the math, but spent most of my time on our 6 channel nano receiver to get the PPM output finished so we can get that to beta.
Question Evo Pro Update CyberPilot Hitec/Multiplex USA 30 Nov 25, 2009 10:34 PM
Funtana Pro Update Matt Fritz Sport Planes 302 Oct 29, 2005 01:58 AM
Multiplex ROYAL Evo software update modelspot Electric Plane Talk 1 Aug 09, 2003 09:46 AM
