Old Jul 25, 2011, 12:27 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Yes, you can upgrade to the new top mount with your setup. You need to order the LONG pigtail and the top mount adapter. They will come assembled ready to install. You just remove the old pigtail assembly and slide the u.fl end of the new assembly down the tube and snap it on to the u.fl connector on the XBEE board. Please note that the pigtail end of the u.fl is only good for 2-3 insertions. So, it is important that you snap the connector in place the first time (or second time). It needs to be directly on top of the connector and pressed straight down. There will be a 'snap' sound when a good connection is made. Now, orient the cable so it is out of the way of the lid closing and then use shoo-goo or similar semi-permanent adhesive to make sure that the connector can not pop off.
That glue is "shoo-goo", and it just peels off. Once that is gone, you need to pull straight up on the connector, do not twist it sideways or you can damage the u.fl on the XBEE module. THAT would require replacement of the module.
JimDrew is offline Find More Posts by JimDrew
Old Jul 25, 2011, 12:35 PM
GoFaster is offline
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
So these two components?
http://www.xtremepowersystems.net/pr...-MOUNT1&cat=12
http://www.xtremepowersystems.net/pr...XPS-PT2&cat=12
How is the mount secured in the Evo's antenna tube?
GoFaster is offline Find More Posts by GoFaster
Old Jul 25, 2011, 02:48 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Yes, those two.
The mount is pressed into the top of the EVO. It can spin, so I used a dab of shoo-goo to prevent that (and I can still get it out if need be). MAKE SURE that you keep the antenna pivot relatively straight. It is possible to kink the cable if you try to pivot it all of the way.
Old Jul 25, 2011, 03:10 PM
GoFaster is offline
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Ordered! Thanks for the shoo-goo tip.
I've opened up the pivot ball so it's much more resistant to swiveling.
Waiting for your new DivBee sailplane rx with the external antennas.
- Felix
Old Jul 25, 2011, 07:10 PM
ChuckA is offline
Find More Posts by ChuckA
Tennessee
Joined Sep 2003
I long ago found the Evo pivot ball to be useless and disabled it with CA. Shoe Goo would be better but I didn't have any at the time and the CA was handy. That was 5 years ago and it is still holding.
ChuckA is offline Find More Posts by ChuckA
Old Jul 26, 2011, 04:43 PM
tadawson is offline
Find More Posts by tadawson
tadawson's Avatar
Lewisville, TX
Joined Dec 2003
Odd . . . At least on 72, I use it all the time . . . . I find the ball to be one of the more useful subtle features on the Evo . . .
- Tim
tadawson is offline Find More Posts by tadawson
Old Jul 29, 2011, 09:53 AM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
Ditto what Tim said, although I haven't found it real useful since I removed the 72MHz antenna.
Pete
PGR is online now Find More Posts by PGR
Old Jul 29, 2011, 10:06 AM
GoFaster is offline
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
I suppose that if I were still using a neck strap (or a tray), I would be swiveling the antenna to point up. However I found that I was constantly smacking myself in the face with it
Old Jul 29, 2011, 11:29 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
You can just bend the 2.4GHz antenna at its pivot point if you wanted to change the angle of the antenna.
Old Jul 29, 2011, 10:15 PM
causeitflys is offline
Find More Posts by causeitflys
THAT'S WHY
causeitflys's Avatar
Eastern Ohio
Joined Aug 2004
GoFaster,
If you still slap yourself in the face with the 2.4 antenna I suggest you lengthen that neck strap
causeitflys is offline Find More Posts by causeitflys
Old Aug 02, 2011, 11:00 AM
GoFaster is offline
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Now that I am finishing up the Black Box support, I will make a change to the EVO module firmware to give you more sensor options as well.
Jim, is this in progress? I am looking at getting an OpenAltimeter as a telemetry sensor.
http://www.rcgroups.com/forums/showthread.php?t=1342829
Old Aug 02, 2011, 01:31 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
That is a neat project. So neat in fact that I laid out a board today to make a sensor for our radio system using the BMP085 pressure chip. I just modified one of my existing sensor board designs. I can change the EVO firmware to add this sensor.
I will post PCB layout and source code as soon as it is tested.
Old Aug 02, 2011, 03:10 PM
GoFaster is offline
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Super! I would like to see real time altitude on my Evo to help me optimize my launches.
Since the rx can also send data to the "PC" (telemetry station?) at the same time, the entire launch profile of altitude over time can be viewed later too.
- Felix
Old Aug 03, 2011, 01:35 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
- Felix
Do you have room for an 8+ channel Rx ++?
flarssen is online now Find More Posts by flarssen
Old Aug 03, 2011, 02:11 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Our sailplane receiver is 1" wide with end pins, and fits in just about every glider made.
Question Evo Pro Update CyberPilot Hitec/Multiplex USA 30 Nov 25, 2009 11:34 PM
Funtana Pro Update Matt Fritz Sport Planes 302 Oct 29, 2005 02:58 AM
Multiplex ROYAL Evo software update modelspot Electric Plane Talk 1 Aug 09, 2003 10:46 AM
