Jul 24, 2011, 02:46 PM
USA, CT, Bethany
Joined Mar 2004
I flashed my Evo from 2.62 to 3.41 and the XPS module to the beta version. Tickled to see LQI and rx pack voltage on the Evo's display.  Thank you!!
This was with an 8 ch rx. Wish my handful of Nano's sent back RSSI.
So at this point with the beta firmware, other sensors won't display on the Evo...just the Telemetry Station?
Some other questions:
Is there a table correlating the LQI % to RSSI so we know at what LQI value is getting into fringe range?
How accurate is the voltage display and how often is it sampled and updated? For instance, the Evo displayed 5.0 while my uncalibrated Tenma multimeter said 5.16. When I wiggled the sticks to move the servos, the Evo displayed 4.9V while the meter
said 5.09-5.10.
Edit: The rate is determined by the rate setting when enabling telemetry on the rx. I only just found out that the number equates to how often telemetry data is sent - every nth frame. Recommended value is 10 for every 10th frame - roughly every 220ms.
Are there supposed to be one or two washers at the antenna end of the module's coax pigtail? The whole assembly is not snug in the Evo's antenna tube and wiggles/rotates around a bit on it's own. If I tighten the nut anymore, the O-ring squeezes past the top nut? There's only one washer and it's on the bottom (cable) end.
