This thread is privately moderated by java8297, who may elect to delete unwanted replies.
Old Sep 20, 2009, 10:07 PM
java8297 is offline
Find More Posts by java8297
Trader Rating: 110
just say no to EASYTIGERMODELS
United States, FL, Fort Lauderdale
Joined Jan 2009
Trader Rating: 110
Sold
E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC $50 shipped
E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC........the first $50 gets it shipped conus.....
my paypal is bowhunt10pt@yahoo.com
When performance matters in your high-current applications look no further than the E-flite 60-Amp Pro Switch Mode ESC. This is a high-quality, efficient sensorless brushless electronic speed control with an integrated Switch-Mode BEC. It can operate without the need for a separate receiver battery to power your servos and receivers, saving you weight and complication. It is capable of up to 60 amps continuous current when using 3- to 6-series Li-Po battery packs. You can drive up to 7 analog or 6 digital standard-sized servos with the BEC on any recommended input voltage. Featuring an exposed, finned heat sink aluminum case with lightweight plastic endcaps, safe power-arming along with advanced programmable features such as low voltage cutoff, braking, timing, throttle input range, and more, the E-flite 60-Amp Pro Switch Mode ESC is truly a ‘pro series’ electronic speed control.
Key Features:
* Up to 60-amp continuous current with proper air flow, 75-amp peak
* 5-volt Switch-Mode BEC circuit capable of 2.5-amp continuous current on any recommended input voltage
* Drives up to 7 analog or 6 digital standard-sized servos, with the BEC on any recommended input voltage
* 3–6S Li-Po, 9- to 18-cell Ni-Cd/Ni-MH input voltage
* Finned heat sinks
* Programmable motor braking
* Safe power-arm mode prevents accidental starts
* Programmable low voltage cutoff with settings for 3-cell Li-Po (9V), 4-cell Li-Po (12V), 5-cell Li-Po (15V), 6-cell Li-Po (18V), or 70% of battery starting voltage
* Programmable soft start for helis and airplanes
* Auto motor shut down if signal is lost or there is interference
* Programmable timing—5 user-selectable ranges for use with a larger variety of brushless motors
* Programmable throttle input range (1.1–1.9 ms or 1.2–1.8 ms)
* Utilizes new smaller MOSFETs technology to minimize weight
* Radio System Power On/Off Switch
* Optional RS232 Serial Link available for programming
* Pre-wired connectors—E-flite EC3 on battery input and 3.5mm female gold bullets on motor output leads
E-Flite part number EFLA1060.
java8297 is offline Find More Posts by java8297
Old Sep 21, 2009, 04:10 PM
rcdude01 is offline
Find More Posts by rcdude01
Trader Rating: 143
rcdude01's Avatar
Oceanside, Ca.
Joined Oct 2003
Trader Rating: 143
Ill take it
rcdude01 is offline Find More Posts by rcdude01
Old Sep 21, 2009, 04:34 PM
java8297 is offline
Trader Rating: 110
Joined Jan 2009
Trader Rating: 110
have not heard for RCDUDE
Still for sale....my paypal is bowhunt10pt@yahoo.com
Old Sep 21, 2009, 11:03 PM
badkisson is offline
Find More Posts by badkisson
Trader Rating: 1
Flyin' Texas
Joined Oct 2008
Trader Rating: 1
is this NIB or used?
badkisson is offline Find More Posts by badkisson
Old Sep 22, 2009, 12:29 PM
sarg96 is offline
Find More Posts by sarg96
Trader Rating: 61
Deal Honestly or Don't Deal
United States, SC, Taylors
Joined Jun 2004
Trader Rating: 61
Key Features:
* Finned heat sinks
If it hasn't sold PM me I will definitely take it
sarg96
sarg96 is offline Find More Posts by sarg96
Old Sep 22, 2009, 07:50 PM
java8297 is offline
Trader Rating: 110
Joined Jan 2009
Trader Rating: 110
SOOOOOOOLD to sarg96
sarg96
Thanks.....sarg96 you got it.....PEACE
Sold E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC flyingrandy55 Aircraft - Electric - Power Systems (FS/W) 2 Aug 20, 2009 09:26 PM
For Sale E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC daylight99 Aircraft - Electric - Power Systems (FS/W) 3 Dec 06, 2008 01:11 AM
Wanted E-flite 60 Amp Pro Switch Mode BEC Brushless ESC ASAMech Aircraft - Electric - Power Systems (FS/W) 0 Dec 02, 2008 09:22 AM
Sold E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC $65 Shipped CGReload Aircraft - Electric - Power Systems (FS/W) 3 Oct 26, 2008 07:56 PM
Sold NIB E-flite 60-Amp Pro Switch-Mode BEC Brushless ESC Heat Sink Aircraft - Electric - Power Systems (FS/W) 2 Oct 10, 2008 01:27 PM
