Old Sep 20, 2009, 04:08 AM
Andrew Bishop
Guest
n/a Posts
molding sand suggestions for suppliers
I need some molding sand as I find I need to csat a handle in aluminum
I normally just cast solid shapes then machine to what ever I need
but this time its not possible and as this is a job for SWMBO Ive
managed to lose my john winter book so have no idea of cost .Now I
know I can make green sand but don't fancy the hard work
does anyone have recommendations I,m on the essex suffolk boarder if
any one knows of any foundry local
I would rather oil bonded if possible
Thanks Andrew
Old Sep 20, 2009, 05:27 AM
Peter Neill
Guest
n/a Posts
Re: molding sand suggestions for suppliers
On Sun, 20 Sep 2009 02:08:04 -0700 (PDT), Andrew Bishop
>Thanks Andrew
You could try Hadleigh Castings Andrew
http://www.hadleighcastings.com/
Peter
Old Sep 20, 2009, 01:03 PM
englishfoundryman
Guest
n/a Posts
> >but =A0this time its not possible and as this is a job for SWMBO Ive
> >Thanks Andrew
> You could try Hadleigh Castings Andrewhttp://www.hadleighcastings.com/
> Peter
Hi Andrew,
In addition to Hadleigh you might consider Finch Seaman at Braintree
their web site is http://www.fsegroup.co.uk/
I think you mean cold setting resin binded which uses a liquid resin
and catalyst system analagous to the ubiquitous araldite although
quite different chemistry. the old stoved Linseed "Oil Sand" is
practically unused these days.
If you do indeed fancy having a go yourself John Winter supply a super
service and their web site is http://www.johnwinter.co.uk/
Good luck - regrettably we only cast iron and bronze in our foundry.
Keith
Old Sep 20, 2009, 01:52 PM
Andrew Mawson
Guest
n/a Posts
"englishfoundryman" <keith.shephard@shephardassociates.co.uk> wrote in
message
news:052c5145-bf0d-4c38-a2e9-b89f44bdea97@p15g2000vbl.googlegroups.com...
aluminum
if
> >Thanks Andrew
> Peter
Hi Andrew,
Keith
Andrew,
You could use sodium silicate mixed sand which is set by passing CO2
thnrough it - very simple. Buy dry bagged silver sand from a builders
merchant - mix in about 3% sodium silicate by weight, ram and gas
simply by inverting a funnel over the mould and releasing your pub gas
into the funnel via a rubber tube. I can let you have some sodium
silicate (waterglass) if you don't have a local source)
AWEM
Old Sep 20, 2009, 04:33 PM
Mark Rand
Guest
n/a Posts
On Sun, 20 Sep 2009 11:03:20 -0700 (PDT), englishfoundryman
>> >Thanks Andrew
>> Peter
>Hi Andrew,
>Keith
Nah. He meant oil bonded sand (eg Petrobond or similar)
Mark Rand
RTFM
Old Sep 21, 2009, 03:49 PM
Andrew Bishop
Guest
n/a Posts
On Sep 20, 7:52=A0pm, "Andrew Mawson"
<andrew@no_spam_please_mawson.org.uk> wrote:
> "englishfoundryman" <keith.sheph...@shephardassociates.co.uk> wrote in
> messagenews:052c5145-bf0d-4c38-a2e9-b89f44bdea97@p15g2000vbl.googlegroups=
..com...
> aluminum
> if
> > >Thanks Andrew
> > Peter
> Hi Andrew,
> their web site ishttp://www.fsegroup.co.uk/
> service and their web site ishttp://www.johnwinter.co.uk/
> Keith
> Andrew,
> AWEM
That would be the ideal I had my hand reproduced in ali using this
method and the detail was good when i enquired about buying some it
was only in large barrels if I could purchase some of you that would
be perfect or if you know of a suppler who sells small amounts as i
understand it has a shelf life .
Thanks Andrew
Old Sep 21, 2009, 04:46 PM
Andrew Mawson
Guest
n/a Posts
"Andrew Bishop" <andrew@andrewbishop66.plus.com> wrote in message
news:9a38f148-d6fa-4589-ab4f-7f64d97c87a3@d34g2000vbm.googlegroups.com...
On Sep 20, 7:52 pm, "Andrew Mawson"
in
ups.com...
> aluminum
need
I
> if
> > >Thanks Andrew
> > Peter
> Hi Andrew,
super
> Keith
> Andrew,
builders
gas
> AWEM
Thanks Andrew
Yes it probably does have a theoretical shelf life, but I have a drum
I've used for years and it was ok when I last used it <G>
Send me your snail mail address by email (despam my address) and I'll
post you a litre (or whatever bottle I can find) and you can refund
whatever the postage is.
Regards,
AWEM
Old Sep 24, 2009, 11:57 AM
Steve
Guest
n/a Posts
"Andrew Mawson" <andrew@no_spam_please_mawson.org.uk> wrote in message
news:PZmdnX219YvRaSrXnZ2dnUVZ8mSdnZ2d@bt.com...
> in
> ups.com...
>> aluminum
> need
> I
>> if
>> > >Thanks Andrew
>> > Peter
>> Hi Andrew,
> super
>> Keith
>> Andrew,
> builders
> gas
>> AWEM
> Thanks Andrew
> Regards,
> AWEM
Andrew,
Is it "dry" sodium silicate you use or the runny stuff for doing strange
things with eggs?
TIA
Old Sep 25, 2009, 11:17 AM
Andrew Mawson
Guest
n/a Posts
"Steve" <steve.withnell@btinternet.com> wrote in message
news:eIydnUXcIeFrOSbXnZ2dnUVZ8gydnZ2d@bt.com...
message
wrote
> > in
> > ups.com...
> >> aluminum
> > need
Ive
..Now
> > I
boarder
> >> if
> >> > >Thanks Andrew
> >> > Peter
> >> Hi Andrew,
Braintree
resin
> > super
foundry.
> >> Keith
> >> Andrew,
CO2
> > builders
pub
> > gas
> >> AWEM
it
would
i
> > Thanks Andrew
drum
I'll
refund
> > Regards,
> > AWEM
> Andrew,
strange
> things with eggs?
> TIA
The later - it's a syrupy liquid
AWEM
Old Sep 25, 2009, 12:21 PM
Steve
Guest
n/a Posts
news:1c2dna3ehsWecCHXnZ2dnUVZ8nidnZ2d@bt.com...
> message
> wrote
>> > in
>> > ups.com...
>> >> aluminum
>> > need
> Ive
> .Now
>> > I
> boarder
>> >> if
>> >> > >Thanks Andrew
>> >> > Peter
>> >> Hi Andrew,
> Braintree
> resin
>> > super
> foundry.
>> >> Keith
>> >> Andrew,
> CO2
>> > builders
> pub
>> > gas
>> >> AWEM
> it
> would
> i
>> > Thanks Andrew
> drum
> I'll
> refund
>> > Regards,
>> > AWEM
>> Andrew,
> strange
>> things with eggs?
>> TIA
> AWEM
Thanks, I fancy giving that a go, just getting the time...
Suggestions for a tri-motor Giacomo Scale Electric Planes 45 Aug 17, 2004 09:56 AM
suggestions for next plane LuckyArmpit Beginner Training Area (Aircraft-Electric) 11 Jun 29, 2001 11:29 AM
suggestions for geardrive on wingo yb2normal Power Systems 8 May 05, 2001 11:54 PM
Motor suggestions for Ryan Rare Bear concept Scale Electric Planes 13 Apr 29, 2001 03:51 PM
Power Suggestions for three engined Italian Bomber R101 Scale Electric Planes 3 Apr 28, 2001 07:31 AM
