Old Sep 19, 2009, 11:41 PM
slvmnr is offline
Find More Posts by slvmnr
Federal Way, WA
Joined Oct 2002
Dow Blue FFF clear plastic film
Hi, never used FFF before so dont laugh. Do you leave the plastic sheeting
on except for the glue joint areas, or do you remove all the plastic before painting?
Some jpegs show real smooth paint jobs and others look wavie
type, like foam manufacturing lines. Looked thru the threads but didnt find
if plastic stays on or completly remove it.... Tnx
slvmnr is offline Find More Posts by slvmnr
Old Sep 20, 2009, 06:55 AM
inline300 is offline
Find More Posts by inline300
Joined Jan 2009
Its up to you man, the FFF skin can hold paint but its not smooth like you mention.
I remove it or put the skin side inside the fuselage. Then put packing tape on the finished exterior of plane. Scuff the tape with fine sandpaper and hit it with some spray paint.
Just take your time laying the tape down, it wants to crease and bubble real easily but if done right, youll have that smooth surface your after. Just make sure you scuff the tape with a fine sandpaper so the paint with stick.
inline300 is offline Find More Posts by inline300
Old Sep 20, 2009, 11:19 AM
boberos is offline
Find More Posts by boberos
Ontario Canada
Joined Aug 2003
I leave the skin ON.
Only remove it for glue joints.
Weight savings by removing skin are negligeble & stiffnes is increased by leaving it on.
Bob
boberos is offline Find More Posts by boberos
Old Sep 20, 2009, 02:28 PM
mechrick is offline
Find More Posts by mechrick
Things are looking up...
mechrick's Avatar
Orlando, Florida
Joined Nov 2004
I leave it on, except for glue joints (as mentioned) and on the inside of flexed or curved pieces to allow the foam to compress in the bend. For instance, using BluCore (with skin on both sides) I peal the inside of the top wing so the curved top can be formed, same with thin side of a rolled fuselage. The skin really helps increase the panel strength. Acrylic paint sticks fine to the waxy skin, but to make it stick a little better you can clean it first with alcohol, which will also take off the black print. And a little light spackle on your finger run over the little vent holes in the skin, followed by some light sanding, makes it a fine exterior surface.
If you plan on glassing, though, you might as well remove all the skin, as the foam is easy to sand and the exposed foam is better to bond or glass to.
Rick
mechrick is offline Find More Posts by mechrick
dow blue foam Bill L Slope 37 Feb 24, 2004 06:53 PM
Question About Covering Blue FFF With Econokote Randy Due Foamies (Kits) 1 Jan 03, 2004 02:38 AM
Painting Blue FFF...paper trick. RobDog Foamies (Kits) 1 Sep 21, 2002 09:57 AM
Dyeing Clear Laminating Film jason f Electric Plane Talk 8 Apr 28, 2002 01:46 PM
DOW blue 3/4" thick foam weight? fdisk Foamies (Kits) 1 Apr 06, 2002 05:25 PM
