| Thread Tools |
| This thread is privately moderated by target, who may elect to delete unwanted replies. |
F3B/F Tracer Build-SoaringUSA.com
*************************CLICK ON COMMENTS TO ^^ OPEN THREAD!
B-day present to me, from my wife (I picked it out for her, and she doesn't know just how well she did....)! 270g Fuse (has about the first 1/2" filled with lead shot already) 68g V-tails (pair) 135g Joiner 592g Left Wing 597g Rt Wing 56g Misc Hardware/covers _______________________ 1718g Empty weight -60.6 oz! 138g 6x 761 servos 31g Fusion 9 rx 115g 5 cell 2/3A 1500 pack 35g Target made ballast tube _________________________ 2037g Total, before build out, 72 oz I may try to shave some weight here and there to trim the fat. It does have music wire pushrods in the snakes, for example. The joiner is a bit heavy for its size, and is likely very strong. Wings have ballast tubes in the roots, 14mm diameter x 267mm long. Should hold some weight, but maybe not enough. Calculates out to about 16oz per side, so 900g total in the wings. ************************************************** ******* EDIT: Looks like I can fit a "Ceres" rectangular tube in the fuse to hold 7 slugs; they are 4.6oz each in the stock brass (32.2oz, or another 900g), or 6 oz each in lead (170g each, 1.19kg total), 42oz total. So, I should be able to ballast up the Tracer with between 64 and 74 oz of total ballast, if the wing tube is in the right place (it's centered on 109mm). ************************************************** ***** Nose is considerably long, may not need ANY balance weight whatsoever, or probably very little. Molding quality looks good, on par with my Xplorer from NAN, and the inside of the wings is neat and tidy. Wing skins feel very robust, and I can see the slightest hint of what looks to be "disser" fabric beneath the deep red paint. Tail is two-piece and on SOLID CF rods, which I like. Fuse looks good, and is based on the favored NAN Carbon/Kevlar hybrid fabric they use in most of their other planes. I like this fabric, it seems very strong for the weight. Forward of the wing is all glass and Kevlar, so the plane is 2.4 friendly for those inclined. Overall, the quality looks very good, ESPECIALLY for the cost, but time will tell. There are a couple things that aren't done for you that normally are, namely the v-tail linkages are not there in the kit. Quite a few planes have this part pre-made for you and already installed except for the balls themselves. No biggie, if you can bend music wire, you're golden. The tow hook slot isn't cut out either; the outline of where to dremel out would have been nice, but, just ahead of the CG range is where I know it should be. Also, there is no servo tray provided. To me, this is OK, since I don't like pre-installed ones, and it is a waste to throw away a pre-machined one that doesn't match my servos or layout plan.... The canopy opening comes pretty far back towards wing LE's, and so I will attempt to strengthen this possibly vulnerable area by extending the servo tray aft into the closed area behind the canopy. It's worked well in the past for me. T
That is a great question, and the picture I posted leads you that direction.
What is true, is that the tube in the stab is longer than the amount of rod that engages it when the rod is fully engaged in the fuse.... So, my plan is to use a little spray adhesive on the base of the rods, and tack glue them into the fuse. Then they will stay fully engaged in the fuse. The amount of rod that couples to the stabs is fine, @ 40-50mm, I'm guessing. They could have left the rods a bit longer, there is an extra 10mm (again, I'm guessing) of tube in the stabs that will be "empty" with the rods fully engaged in the fuse. Hope that answers your question. Not ingnorance, per se, a valid point. R, Target |
Latest blog entry: Stork 4 Pro X-tail from...
Ends up, that there is 55mm into the tailplanes and @<20mm into the fuse, David.
Target |
Here are some build pics.
The plane is 76oz balanced at 103.5mm, so I am very happy with that! It's ready to maiden! Pics: T
Yes 2-56, but you can also use 2mm and still use the MPJet nylon clevises.
If you go to 4-40, you have to use a metal clevis at each end or a Hayes at the surface end. I use a metal clevis at the servo only so that I can grind a relief in it and still have it strong enough. Or you can use a bike spoke or a z bend or a couple other options at the servo that doesn't bind on the pulling of the linkage. T |
Here's the slope maiden shot.
T |
| Thread Tools | |
| Discussion new Tracer f3b/f | dhauch | Multi Task F3X | 445 | Yesterday 09:22 AM |
| Convair F-102A build-pics.. | JerryHall | Scale Electric Planes | 24 | Feb 13, 2006 11:18 PM |
| Backyardfoamie F-16 Build | blacksheep | Foamies (Kits) | 61 | Nov 24, 2004 11:13 AM |
| F-22 build pics and question | Basketcase | Parkflyers | 2 | Jun 02, 2003 10:19 PM |
| Flying Styro F-16 build and power questions | G1K@home | Electric Ducted Fan Jet Talk | 2 | May 29, 2003 03:53 PM |
