Old Sep 19, 2009, 06:17 AM
FlyDave is offline
Find More Posts by FlyDave
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
[Question] : Foam cutting correct sequence
Hi all !
I have a question for the Foam-builders-Pro :
When someone want to build an airplane with a hot-wire foam cutter, what's the correct sequence of the cuts, if he want to cut the formers and the wing attach ?
For example, i followed the buildlog of Sparky's B25, and he has cutted the wing attach after the fuse was completed.
I know this was almost "easy" to do because the bottom side of the fuse is flat, but how to do the same thing if i want to build an airplane with a round bottom ? How i can put it flat on the table, to draw and cut the wing attach ?
Sorry for my english, i hope you've understand my question...
thank you!
David
FlyDave is offline Find More Posts by FlyDave
Foam Cutting Question mt_100 Foamies (Kits) 2 Sep 28, 2003 06:50 PM
foam cutting noob question johnny_carlos Foamies (Kits) 3 Jan 22, 2003 11:46 PM
Question about foam cutting... NetForce2K Foamies (Kits) 1 Jun 20, 2002 04:33 PM
Another foam cutting question....filament... JayParke Foamies (Kits) 3 May 26, 2002 06:47 PM
Foam cutting - electronics question AC to DC ChrisD Power Systems 5 May 02, 2001 06:11 AM
