Old Sep 18, 2009, 06:49 PM
Wauseon, Ohio
Joined May 2008
weed eater conversion
I am currently trying to convert a Red Max GZ25N weed eater to a rc engine. Its displacement is 25.4cc or 1.55 ci. It runs well and has a walbro carbuerator on it. I was wondering on the size of propeller to put on it. I think it should be between 16x8 and 18x8, but i am not sure. Also if anyone knows about what size fuel tank i should use for it, since i will be using it for sport flying. If anyone could give some ideas here it would be helpful. thanks.
n_spot is offline Find More Posts by n_spot
Old Sep 19, 2009, 07:50 AM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I would say the 16x8 should be about right. After you get it running, you can try a few other props to see how they do. Use a tach to check the RPMs.
I would try a 16 oz tank first, it ought to give you a fairly good fly time of around 10 minutes or so. Maybe a 24 oz tank if you like to fly longer. The carbs usually have a fuel pump built in so longer fuel lines and larger fuel tanks should not be a issue.
earlwb is offline Find More Posts by earlwb
Latest blog entry: My Low Wing plane
Old Sep 19, 2009, 11:11 AM
OCD: Old, Cranky and Disgusted
challenger_i's Avatar
United States, TX, Sweetwater
Joined Mar 2005
The Red Max is made by Zenoah, and the engine is very close to the G-26. So, if you use G-26 specs (props, rpm, break-in schedule, etc.), for reference, you should come out ok.
challenger_i is offline Find More Posts by challenger_i
Old Mar 07, 2010, 04:54 PM
Wauseon, Ohio
Joined May 2008
Does anyone know of any conversion kits for this model.The most necessary part would be the prop adapter.
Old Mar 07, 2010, 06:35 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
IIRC, the diameter and taper of that engine's shaft is the same as a Honda. You can most likely get the adapter here: http://www.carrprecision.com/Pages/prod02.htm
GeoffinIN is offline Find More Posts by GeoffinIN
Old Mar 07, 2010, 09:27 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Wacker engines has conversion parts too.
http://wackerengines.com/
Old Mar 08, 2010, 08:33 PM
Wauseon, Ohio
Joined May 2008
so, Geoffinpdx, the prop hub and adapter from the Honda GX25 should fit on the REd Max flywheel?????????? It looks like the flywheel has three instead of two holes to mount the adapter to.
Old Mar 08, 2010, 10:11 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
I was only considering the flywheel fit on the shaft. If you go with aftermarket ignition it'll make the conversion simpler, and you can get variable timing to boot. I'd call the two businesses and get their advice.
Geoff
For Sale mac weed eater motors for rc conversion 35 shipped kgn831aa Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 13, 2009 10:52 AM
Discussion Weed Eater Conversion Chophop Fuel Heli Talk 6 Dec 27, 2006 12:00 PM
Discussion weed eater brands suitable for conversion carbonexpress Racing Boats - Internal Combustion 6 Sep 29, 2006 07:42 PM
Yippee! R/C Tarantula Weed Eater hall woo Robotics 2 Aug 13, 2006 01:44 AM
Weed Eater Conversions ALEX DOUGHTY Engines 3 Aug 19, 2005 09:26 AM
