Old Nov 15, 2012, 09:12 AM
Wazmo is offline
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
Don't know if it's the same model format, but Maya might be worth a shot.
Wazmo is offline Find More Posts by Wazmo
Old Nov 15, 2012, 11:51 AM
dpot is online now
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
the only thing you could try is copy the file and then rename it to .3ds and try it
or try to import as all formats.
none of my software imports .mld
but i found this model her for 35$ http://gunpoint-3d.com/model-ma.html
dpot is online now Find More Posts by dpot
Old Nov 15, 2012, 01:17 PM
Derfy is offline
Find More Posts by Derfy
North Britain
Joined Jun 2006
Originally Posted by Bart83 View Post
I have a question ,
Is it possible to import a 3d model from Microsoft flight simulatorX into Rhino ?
Cheers,
Bart
You could always try ModelConverterX.
A great little programme that works well with most models and should, at least, give you something to work from.
Derfy is offline Find More Posts by Derfy
Old Feb 28, 2015, 08:18 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
Nothing like digging up an old thread, eh?
With the aid of a friend (who may live to regret this) I'm trying to learn how to use Rhino. I've been doing 2D cad for a number of years but never tried 3D before. It's a very steep learning curve and it's amazing how much time I spend just faffing around. Hopefully some of what I learn will stick.
Anyone else here working with Rhino at the moment?
epilot is offline Find More Posts by epilot
Old Feb 28, 2015, 11:25 AM
chiloschista is offline
Find More Posts by chiloschista
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
Yes, I am and I feel what you mean
The learning curve at beginning is really steep, but just try and find your way.
... and I noticed you are from Faroe: mhmm interesting.
I was wondering few weeks ago how is slope flying there.
And also I did conduct a piece called *Faroese circle dance* some time ago
Best regards,
Ric
chiloschista is offline Find More Posts by chiloschista
Old Feb 28, 2015, 11:29 AM
ribotero is offline
Find More Posts by ribotero
Colombia
Joined Sep 2005
Yes, I started with this thread. I am still learning. But have managed to do some fun stuff.
ribotero is offline Find More Posts by ribotero
Old Feb 28, 2015, 05:10 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
I work with it every day. Anything I can do to help just let me know. I'm no expert but I'm proficient.
Tom
tom43004 is offline Find More Posts by tom43004
Old Mar 01, 2015, 11:44 AM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Hello Michael!
As long as the old thread is useful it is perfect for me as I'm already hooked in!
Hope you make a good progress and have fun - Rhino has a pretty intuitive interface and so it should not take too long untill the first little success comes up and everything comming after this may be named by the word addiction.....
Have a good time and come back with your questions!
Hansjoerg
Harpye is offline Find More Posts by Harpye
Old Mar 02, 2015, 04:46 AM
epilot is offline
Joined Nov 2000
It's certainly a steep learning curve. I probably spent over 10 hours on it this weekend and only produced a very simple part. Next part I draw will take less time of course. I have access to tutorials that I will be watching over the next couple of weeks.
I like Rhino but I probably wont be able to afford a license. I don't know if there are alternatives that will do the same but at lower cost.
Old Mar 02, 2015, 10:41 AM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Moment of Inspiration is very similar and a lot cheaper, but it doesn't have as many advanced tools (depending on your needs, you will likely not need them -- I don't). It is actually developed by one of the original Rhino developers and uses the same geometry library. I'd recommend you test out the trial version if you like Rhino but don't want to spend that much.
moi3d.com
Montag DP is offline Find More Posts by Montag DP
Old Mar 02, 2015, 02:53 PM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Hansjoerg has taught me to use Rhino and therefore I recommend to go to his profile and check some of the threads he started - Rhino related.
Recommended.
RNAF is offline Find More Posts by RNAF
Old Mar 02, 2015, 03:18 PM
epilot is offline
Joined Nov 2000
I've hit a snag. I'm drawing a Hellcat using Hansjoerg method of aligning formers with a side and top view. At the moment all the formers are aligned to the side view. However I discovered the traced side view needs to be adjusted a bit. I can do this by moving control points around. However that means the formers are no longer aligned to the side view. Is there a way to lock the curves together, so when I change the side view, the formers follow it?
Old Mar 03, 2015, 03:02 PM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
I know your issue. In short, no. You'll have to run the Scale1D command again (for both planes).
Old Mar 04, 2015, 04:31 PM
jumo004 is offline
Find More Posts by jumo004
jumo004's Avatar
Joined Apr 2010
moi3d.com
+1
I've been using it about a year now and I think it's great.
jumo004 is offline Find More Posts by jumo004
Old Mar 13, 2015, 09:24 AM
FlyDave is offline
Find More Posts by FlyDave
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
I used Rhino until 1 year ago, great software ! More features than really necessary for our needs, but very intuitive.
Thanks to HansJoerg for the "immersive training", great weekend in Germany ;-)
FlyDave is offline Find More Posts by FlyDave
Mini-HowTo Rhino ... some basics Harpye CAD/CAM 574 Apr 28, 2016 08:40 PM
Wanted Looking for some 4S and 5S zippy/Turnigy/Rhino Lipos Aga1978 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 30, 2009 08:09 AM
Help! Probably basics for some markles123 Sailplane Talk 6 Oct 07, 2009 01:46 AM
Discussion Some basics of FPV for a beginner?! GOK FPV Talk 10 Feb 15, 2007 08:04 PM
In need of some basics Doug Sipprell Batteries and Chargers 5 May 26, 2004 10:21 PM
