Old Apr 29, 2012, 03:34 PM
Dirty Dee is offline
Find More Posts by Dirty Dee
Dirty Dee's Avatar
United States, IL, Northbrook
Joined Sep 2011
Originally Posted by Bart83 View Post
This was fun to do.
So now i have the shape how can i make formers and sheeting etc?
Greets ,
Bart
To get formers you can create planes and set them going through the solid at locations that you want the former. Then use the command SECTION. then offset the cross section by the sheet thickness, and remove excess material from the former.
Dirty Dee is offline Find More Posts by Dirty Dee
Old May 09, 2012, 03:06 PM
Bart83 is offline
Find More Posts by Bart83
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
Hello , cant get the float to become a solid er get a solid one piece skin , this is how far i have come.
Greets ,
Bart
Bart83 is offline Find More Posts by Bart83
Old May 10, 2012, 04:15 PM
Bart83 is offline
Bart83's Avatar
Joined Jun 2009
Does anny one know how i can give tthe balsa sheeting a 1.5mm thickeness ?? i tried using offset surface -solid but the result is not what i want ( see picture)
Greets , Bart
Old May 10, 2012, 04:28 PM
Dirty Dee's Avatar
Joined Sep 2011
you can create a vertical plane going down the centerline of the floats. Then use that plane to split the solids so each side butt against one another. you will need to cap the split ends though
Old May 24, 2012, 08:50 PM
JMDESIGNS is offline
Find More Posts by JMDESIGNS
JOE MOCERI
United States, MO, St Charles
Joined Nov 2006
When I input a picture using picture frame in Rhino the picture dissapears when zooming in on it. Do I have a setting wrong? Anyone experience this problem.
Joe
JMDESIGNS is offline Find More Posts by JMDESIGNS
Old May 25, 2012, 02:23 AM
Bart83 is offline
Bart83's Avatar
Joined Jun 2009
do you have the wire frame on visible ? if you have turn it off.
greets,
Bart
Old May 25, 2012, 01:16 PM
JOE MOCERI
Joined Nov 2006
The picture shows up in render and also in the view ports when imputed. It turns white after a couple of scrolls to zoom in. I have searched the web for the problem and others have experienced the same issue on white picture. I have removed and reloaded the program and no change.
I tried with wire frame on and off and still same problem. I'm wondering if it is my computer............... Has worked in the past so I'm still searching for the answer.
Joe
Old May 25, 2012, 01:20 PM
Dirty Dee's Avatar
Joined Sep 2011
Dont know if this might fix it. But, have you placed the images on their own layer, and then locking that layer?
Old May 25, 2012, 01:23 PM
JOE MOCERI
Joined Nov 2006
The image imputs to a default layer and I have locked it. Ill try coping to a new layer and see if it works.
Joe
Edit,,,, Still has the issue with being on a different layer.
Old May 30, 2012, 09:57 AM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
United States, GA, Atlanta
Joined Apr 2005
I'm having some trouble printing. For some reason it just shows up as a black page. I'm pretty sure I've tried to do this before, so I'm not sure why it's not working. Anyone seen this before?
Montag DP is offline Find More Posts by Montag DP
Old May 30, 2012, 02:46 PM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Open GL / Graphics Driver Update Some Graphic mode changing parallel tasks opened??? if not - no idea ... never had this issue!!
Harpye is offline Find More Posts by Harpye
Old May 30, 2012, 05:38 PM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Yeah, I'm not sure what it is. I may have switched drivers since the last time I tried printing from Rhino but I'm using the ATI Catalyst drivers and they are up to the task for everything else. I think I will try submitting a support ticket.
Old May 31, 2012, 02:26 AM
FlyDave is offline
Find More Posts by FlyDave
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
Have you tried "Vector" instead of "Raster" output ? (options on the left)
FlyDave is offline Find More Posts by FlyDave
Old May 31, 2012, 04:37 PM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Oh hey, that actually works. I thought I had tried it but I guess I actually hadn't. Thanks.
Dan
Old Aug 08, 2012, 02:58 AM
Bart83 is offline
Bart83's Avatar
Joined Jun 2009
Hello ,
I am a bit further on my way trying to learns rhino3d. I desinged a replacement wing for my widgeon and made a few pics. I arranged the parts for milling , did i do this wright ?
I would like to know if there is any easy way to make parts interlocking for making fuselage formers for example ?
Greets ,
Bart
Shear webs
Ribs
Joiner
Spars
Dowels
Hold-down block
Leading-Edge
Trailing-Edge & Sub trailing-edge
Fill blocks
Ailerons & tips
Sheeting
Rendered construction
Started nacelle
Nacelle formers
Complete wing
Parts for milling done wright?
Parts for milling using '''make 2d visible''
Plan
Mini-HowTo Rhino ... some basics Harpye CAD/CAM 570 Mar 13, 2015 12:06 PM
Wanted Looking for some 4S and 5S zippy/Turnigy/Rhino Lipos Aga1978 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 30, 2009 09:09 AM
Help! Probably basics for some markles123 Sailplane Talk 6 Oct 07, 2009 02:46 AM
Discussion Some basics of FPV for a beginner?! GOK FPV Talk 10 Feb 15, 2007 09:04 PM
In need of some basics Doug Sipprell Batteries and Chargers 5 May 26, 2004 11:21 PM
