Old Sep 09, 2011, 04:09 PM
JMDESIGNS is online now
Find More Posts by JMDESIGNS
JOE MOCERI
United States, MO, St Charles
Joined Nov 2006
Harpye, That flows real good. I will re read your email and try to figure out your reply back.
You are correct that I was sweeping between each former areas to get the surface and mirroring the other side. I have been trying a lot of different things for the past few days and you accomplished it a few strokes of your keys.
I may need a step by step on how you did it,. Once I figure this out I can move foward
Thanks Joe
JMDESIGNS is online now Find More Posts by JMDESIGNS
Old Sep 10, 2011, 05:47 AM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Create formers
Intersect formers with planes calculate intersechtion points
Create " Spline Stringers " trough the points of one Section .... refine the splines in areas of higher spherical complexity and so build a kind of complex tubularity which you afterwards can NURB mesh
Create NURB mesh -
THats all in short words ( I know that there may occur some difficuties but thatīs life
Harpye is offline Find More Posts by Harpye
Old Sep 10, 2011, 06:35 PM
JOE MOCERI
Joined Nov 2006
Harpye, Getting closer, Lofted the formers in a couple of sections. Still have some warps in areas of a greater transition, especially at the lower tail area. What am I still doing wrong... I would like to get the file back I sent you the you have modified to review what you did.. Let me know.
Thanks Joe
Old Sep 11, 2011, 06:26 AM
Harpye is offline
Harpye's Avatar
Germany
I did show you everything I did in the 3 Pics above - nothing else you could take out of the file.... which meanwhile is bit too large to be sent even when zipped
1 define the FORMERS
2 define the STRINGERS -Important for a smooth transition and the "flow" you mentioned ....
3 no pure loft - a loft is straight between two formers - a loft over more formers interpolates the surface but is not precise enough because it refers to the arrangement of the formers wich are only a few - so between the formers there is not enough definition given ... for what you need the longitudinal stringers.... If you work with the wire mesh shown in the three steps and mesh this in a hole part you would do right - and would get one part without warps and edges
Old Sep 11, 2011, 08:54 AM
JOE MOCERI
Joined Nov 2006
are you saying you lofted all the formers in one loft and meshed the surface. I tried this and it still looks some what dished in between some formers
3 no pure loft - a loft is straight between two formers - a loft over more formers interpolates the surface but is not precise enough because it refers to the arrangement of the formers wich are only a few - so between the formers there is not enough definition given ... for what you need the longitudinal stringers.... If you work with the wire mesh shown in the three steps and mesh this in a hole part you would do right - and would get one part without warps and edges .
I do not understand what you mean here. I'm new to Rhino, 3 months.. I think translation from German to English lost here or I am too green to understand...
Joe
Old Sep 11, 2011, 11:00 AM
mcg is offline
mcg
Find More Posts by mcg
mcg
Joined Jul 2005
Hello Harpye and Joe,
The step I cannot quite understand is the third step, "Create NURBS mesh."
On Rhino's feature list online, I looked up all the different ways to create a surface, and all the different ways to create a mesh. Here they are:
Create meshes: from NURBS surfaces, from closed polyline, mesh face, plane, box, cylinder, cone, and sphere.
Create surfaces: from 3 or 4 points, from 3 or 4 curves, from planar curves, from network of curves, rectangle, deformable plane, extrude, ribbon, rule, loft with tangency matching, developable, sweep along a path with edge matching, sweep along two rail curves with edge continuity, revolve, rail revolve, blend, patch, drape, point grid, heightfield, fillet, chamfer, offset, plane through points, TrueType and Unicode (double-byte) text.
In this specific fuselage example, it appears that you should create and refine a spaceframe using curves (representing formers and stringers), and then surface this spaceframe with a mesh. But this last step -- surfacing the frame with a mesh -- is unclear to me.
Is it accomplished with a Network of Curves command? Is the mesh draped over the frame? Is the surface created initially as multiple sections, and then Merged to form a single surface?
In other words, what are the specific Rhino command words that enable you to work with a wire mesh, and in this way transform the spaceframe of curves into a smooth, continuous surface?
Many thanks for your insights.
Michael
mcg is offline Find More Posts by mcg
Old Sep 11, 2011, 11:30 AM
Harpye is offline
Harpye's Avatar
Germany
Michael - I was off over the weekend and answered the questions via cellphone - was not able to refer to the Rhino commands list
Create "Mesh from Network of curves" ( submenue of " surface from 3or 4 corner points") is right...
The steps called above are steps in the meshing process but not Rhino commands
__________________________________
HI Joe - Skype would be that easy ... for English is far away from beeing my mother thoung would be much easier to explain interactively - that stuff is not that easy going over my lips... !NO PURE LOFT! meant you should not LOFT the formers but also use the "Stringers" to create a kind of line mesh you could easily coat with a NURBS mesh ( command - see above or in the Tutorial)!!!
THink about a wood built ... e.g. Guillows models - you need the formers connected by the stringers to be the wooden part of the airframe - afterwards you use Oracover to coat this structure to be a closed fuselage -
In CAD: the formers and stringers consist of open (= stringers) and closed ( =formers) SPLINEs like in a wooden plane kit and the meshing process overspans all the structure with NURBS mesh (= Oracover)
if you'd leave out the stringers and only use the formers - the coating result would be same as in reallity - you would get straight connections ( tubular elements between the formers but no sperical surface...)!
A loft - originally between 2 closed SPLINE curves causes a tubular element with straight isocurve lines between both edges...
extending this command and applying it on three splines causes a Spherical surface which intersects with al 3 SPLINES
Both is not the right method to control a Free Form Surface of that complexity!
you should do former - SPLINEs and stringer - SPLINEs and use the "SURFACE FROM NETWORK OF CURVES" command to mesh the whole thing ... THat is also what I've shown in the tutorial and in the 3 states of meshing shown above - first wiremesh - second NURBS Surface - and third - check surface with Zebra pattern
Another pic shown below:
3 closed splines ( yellow) - each example shows the same position of them
in the top straight lofts between 2two of them
in the middle a loft done over all 3 of them - see the difference - better but not enough definition for a complex fuselage
the third shows the 3 closed splines with 4 additional what I called stringers
you see that there is much more posibility to add information and definition of the " flow"
THis is also shown by the detail of the isobate curves on the surface created ... the third version is much more complex and detailed!
Old Sep 11, 2011, 01:16 PM
JOE MOCERI
Joined Nov 2006
Harpye your last post made it click for me. Did a network on the formers and the rails and i like how it turned out. Attached a picture of the rendering. Thanks
Joe
Old Sep 11, 2011, 01:36 PM
Harpye is offline
Harpye's Avatar
Germany
HI Joe!
Beg your pardon , beeing a bit unprecise in the first step of explanation... but typing on a blackberry keypad without the support of the program was someway a poor attempt as it seems! Main thing is that you finally understood what I'd tried to tell you ! ... Looks good - your first NURBS surface!
Hansjoerg
Old Apr 10, 2012, 10:29 PM
Dirty Dee is offline
Find More Posts by Dirty Dee
Dirty Dee's Avatar
United States, IL, Northbrook
Joined Sep 2011
I am trying to model the wingtip droops on the A-10 but cant seem to get it right. I've tried 1 and 2 rail sweeps and it comes out close. But, the underside is too thick and isnt as bowl-like as it normally would look.
Any ideas?
Dirty Dee is offline Find More Posts by Dirty Dee
Old Apr 11, 2012, 05:55 AM
Harpye is offline
Harpye's Avatar
Germany
A pic / screenshot would help!
Otherwise ... create a more detailed crossed wire mesh and use surface from network of curve to coat it!!!
Old Apr 11, 2012, 08:21 AM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
wing tips for a 10
I worked my way through it mostly by use of use of "curved network "
Claus
clausxpf is offline Find More Posts by clausxpf
Old Apr 11, 2012, 01:24 PM
Dirty Dee's Avatar
Joined Sep 2011
I played around with the sweep rails and was able to get pretty close. The top and side profiles are spot on, but it has an abrupt change and just needs a bit more dish on the underside.
orange are the rails, gold are the cross sections.
Old Apr 11, 2012, 03:33 PM
Harpye is offline
Harpye's Avatar
Germany
Try to get some additional curves for better definition of detail and do a fully free form surface mesh!!!Also take care on the tangential consistence onto the main wing surface!!
Old Apr 29, 2012, 01:48 PM
Bart83 is offline
Find More Posts by Bart83
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
So afer a lot of reading and having done the turorials in Rhino 4 i thought i give it a try and draw a part for my next project in rhino. And here ar the results:
This was fun to do.
So now i have the shape how can i make formers and sheeting etc?
Greets ,
Bart
Bart83 is offline Find More Posts by Bart83
Mini-HowTo Rhino ... some basics Harpye CAD/CAM 577 Aug 05, 2016 07:04 PM
Wanted Looking for some 4S and 5S zippy/Turnigy/Rhino Lipos Aga1978 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 30, 2009 08:09 AM
Help! Probably basics for some markles123 Sailplane Talk 6 Oct 07, 2009 01:46 AM
Discussion Some basics of FPV for a beginner?! GOK FPV Talk 10 Feb 15, 2007 08:04 PM
In need of some basics Doug Sipprell Batteries and Chargers 5 May 26, 2004 10:21 PM
