Old Nov 12, 2010, 03:01 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Help with cutting spar slots
I need help!
Hopefully this makes some sense! The pictures below, although simplified, hopefully illustrates what I'm trying to accomplish. I'm actually just trying to cut spar slots through ribs. This trick is that the spars are not perpendicular to the ribs.
This first picture shows the location of the "spar" and the "ribs". The second picture show the "ribs" after a Boolean difference operation removed the material for the spar slots. The spar slot is at an angle to match the spar. Although technically correct this slot I can't cut this with a 3 axis cnc router or a laser cutter.
What I'm looking for is shown in the third picture. The forth picture shows the spar back in place.
Everything I've tried so far requires me to modify each rib separately after the initial spar slot has been cut. So the question is what's the best way to do this with Rhino?
Thanks in advance!
Brian
p.s. I hope that the pictures show up in the correct order. If not I've labeled them.
p.p.s. The last picture (green wing) shows what I'm actually working on.
cpdude is offline Find More Posts by cpdude
Old Nov 12, 2010, 04:18 PM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
you can have lines on surfaces
use this function to mark all your surfaces that have to have the spar crossing and mark the spar..
and use this function.
Claus
clausxpf is offline Find More Posts by clausxpf
Old Nov 12, 2010, 09:26 PM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Originally Posted by FlyDave View Post
Hello !
I've drawn a wing and cutted out an aileron.
Can someone explain me how i can cap the hole created by the split function ? (selected in yellow on the picture) i've tried with "cap planar holes", "patch", "net of curves"...
I try to work with solids for most things so that I don't end up with this problem. You can do this by using the "Cap" command immediately after doing a sweep, loft, curve network, etc.
In your case, I would probably do the following.
1) Create straight lines at each open corner resulting from your split.
2) Use the EdgeSrf command to create surfaces using these curves and the appropriate edges of the wing skin. If this command doesn't work, you may need to use a loft or sweep instead.
3) Repeat steps 1 and 2 for the aileron (if desired).
4) Use CreateSolid to turn the wing and aileron into a solid.
Alternatively, you could try undoing to before the split, use Cap to turn your wing into a solid, and then redo the split.
Montag DP is offline Find More Posts by Montag DP
Old Nov 12, 2010, 11:57 PM
Haole is offline
Find More Posts by Haole
Stranger in a land
Haole's Avatar
Hawaii
Joined Dec 2007
Surface>Planar Curves. Done.
Haole is offline Find More Posts by Haole
Old Nov 13, 2010, 09:49 AM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Originally Posted by cpdude View Post
I need help!
You might try working with surfaces rather than fully developed solids. Chop them up as needed with spars, then extrude those surfaces. This way the notches match what the CNC can do.
Or
Do the ribs last. Create all of the parts, such as the wing surfaces, spars, wire holes, lightening holes, linkage holes and oh did mention holes, THEN use the Curves from Section to create the ribs. These rib curves can be used directly for parts or they can be extruded to provide a cutting surface for modeling shear webs.
Knoll53 is offline Find More Posts by Knoll53
Old Nov 15, 2010, 03:13 PM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
I just got an email about this:
http://www.scan-and-solve.com/video/...n-stl-model-of
Looks pretty cool. It's built-in FEA for Rhino. I don't know how good it is, but it definitely looks promising. Interestingly, it looks like the meshing (solution discretization) is done automatically by the application. This could be useful for model airplane design, especially if you can add in balsa/foam as materials.
Old Nov 16, 2010, 02:58 AM
FlyDave is offline
Find More Posts by FlyDave
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
It worked perfectly !
I had to separate the 3 surfaces, but after that the command has closed the surfaces correctly.
Thank you !
Dave
FlyDave is offline Find More Posts by FlyDave
Old Nov 18, 2010, 05:35 PM
Haole is offline
Stranger in a land
Haole's Avatar
Hawaii
Joined Dec 2007
Thank you !
Dave
You're welcome. Glad it worked for you. Sometimes there are really useful commands in Rhino that are very easy to overlook like the above.
Carl
Old Nov 26, 2010, 06:38 PM
rc_starter is offline
Find More Posts by rc_starter
Joined Aug 2006
Hello, I've learned a lot from this thread, and want to thank you all for contribution.
I would like to learn Rhino as i am interested in aircraft 3d modelling...
Now, does anybody of you have step by step video tutorial for airplane modelling techniques. It's kinda hard to follow you cuz you already work in rhino for some time.
This thread needs only that... a video tutorial, and it can be good point to start this fantastic hoby...
Many thanks,
Rale
rc_starter is offline Find More Posts by rc_starter
Old Nov 27, 2010, 01:30 AM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Hello Rale - I did a kind of workshop here in RCG some years ago .... the tutorial is still existing
- go for
WWW.modellbauwahn.de
-> English section
-> Engineering - at the bottom of the page are several packages
Have fun trying -
Hansjoerg
Some weeks ago we did another workshop - physically - some buddies from Germany and I.
Was a great weekend .... and the result...
Harpye is offline Find More Posts by Harpye
Old Nov 27, 2010, 01:51 AM
Konstantin S. is offline
Find More Posts by Konstantin S.
KIT Designer
Konstantin S.'s Avatar
Padova Northern Italy
Joined Jun 2010
I have visited your site Harpye. WWW.modellbauwahn.de
Very much it was pleasant to me!
Konstantin S. is offline Find More Posts by Konstantin S.
Old Nov 27, 2010, 11:03 AM
ptxman is offline
Find More Posts by ptxman
Calgary, AB, Canada
Joined Oct 2002
Hansjoerg...
Hi Hansjoerg. Whats contained in the workshop files? Are they compressed zip files of like pdf's tutorials or .3dm rhino files? My PC was saying something to the effect 'may contain executable files' .. likely just a standard warning, but thought Id ask first.
ptxman is offline Find More Posts by ptxman
Old Nov 27, 2010, 11:11 AM
Harpye is offline
Harpye's Avatar
Germany
Konstantin - Thank you!
PTX - there are no .exe files included - Since most of the beginners start the trial on 25 saves restriction, I added the final of each unit as a rhino .3dm file - so doing at least a whole unit in one step, you can go on with the backup save and so keep your 25 saves for the really important things after finishing the tutorial...
TUTORIAL = PDF
ADDON = 3DM
Both included into a compressed file!
That's all!
Hansjoerg
Old Dec 01, 2010, 07:21 PM
Joined Aug 2006
Thanks Harpye, I will play with Rhino following your tutorial...
What about plans where you dont have cross sections? Do you guess how it looks untill you get satisfied results? From some pictures for example...
Mini-HowTo Rhino ... some basics Harpye CAD/CAM 577 Aug 05, 2016 07:04 PM
Wanted Looking for some 4S and 5S zippy/Turnigy/Rhino Lipos Aga1978 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 30, 2009 08:09 AM
Help! Probably basics for some markles123 Sailplane Talk 6 Oct 07, 2009 01:46 AM
Discussion Some basics of FPV for a beginner?! GOK FPV Talk 10 Feb 15, 2007 08:04 PM
In need of some basics Doug Sipprell Batteries and Chargers 5 May 26, 2004 10:21 PM
