Old Jul 29, 2010, 03:38 PM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Anything possible to do by mouseclics could also be done in parametrizable way by rhino script... ( e.g.) I built a virtual machine space and actually try myself in writing some nc code generator from 3D... But Rhino script is not that well documented compared with VBS . Only half way reliable source for documentation seems to be Rhino 101...
Harpye is offline Find More Posts by Harpye
Old Jul 29, 2010, 04:34 PM
Haole is offline
Find More Posts by Haole
Stranger in a land
Haole's Avatar
Hawaii
Joined Dec 2007
Guys, these are two absolutely must-have scripts for making airplanes.
The first is for importation of airfoils from .dat files and the second is exportation of .dat coordinates of your own airfoils.
First, download the UIUC database from here:
http://www.ae.illinois.edu/m-selig/a..._database.html
Next, use the script. Select Tools>Rhinoscript>Load and point at the directory where you saved the script file. Then repeat only choosing Run instead of Load, and look into Selig's database to import thousands of well known sections.
Carl
Edit: The other beauty of this script is that you can download .dat files of your favorite airfoil if it's not in the database already, and be lofting wings in a matter of minutes.
Haole is offline Find More Posts by Haole
Old Jul 29, 2010, 06:32 PM
ShaneW is offline
Find More Posts by ShaneW
Am I going up?
ShaneW's Avatar
Melbourne, Australia.
Joined May 2006
Hi Harpye,
I've actually found the Rhino Script help file pretty good.
It's not the best "beginners" guide, but the function definitions are pretty well described and get you through most things.
Of course, I'd still like to see more...
Shane.
ShaneW is offline Find More Posts by ShaneW
Old Jul 29, 2010, 06:45 PM
ShaneW is offline
Am I going up?
ShaneW's Avatar
Joined May 2006
Hey Vintage,
What does scripting do?? Well that's a big question and I'm not going to answer it fully - don't have the time, however I've give you an example.
A few years ago I started playing around with Rhino as a friend of mine had a CNC router sitting around not doing much and I wanted to make use of it. We were building 60inch slope racers and I (after much tearing out of hair) finally created a nice fuselage surface.
Next I wanted to add a wing fillet. I eventually did this and realised that the process could be repeated for most fuselage surfaces.
I decided to have a look at rhino scripts and see if they could help me to automate the process. Given the code is based on VBS and I'm an old VB programmer from way back, it wasn't long before I started on a script to make it happen.
So I now have a script (amost others), that allow me to select a fuselage surface, a desired wing profile, incidence, width and height (for the fillet) and generate a nice wing fillet.
The process now runs in a matter of seconds rather than me having to spend hours doing each one by hand. (we won't count the weeks I spent getting the script right, but that's part of the fun!)
I've since converted it into a Rhino plug-in which can be added into the standard Rhino menu and provides the function from there.
So my definition is that scripts help you automate processes that you perform regularly, with the intention of reducing the time in doing it manually.
I'll throw on a couple of images for the wing fillet I jut described in a minute.
Shane.
Old Jul 29, 2010, 07:01 PM
ShaneW is offline
Am I going up?
ShaneW's Avatar
Joined May 2006
So here's some images...
You may notice the Canopy also...that was created using another rhino script.
Shane.
Old Jul 29, 2010, 09:08 PM
Haole is offline
Stranger in a land
Haole's Avatar
Hawaii
Joined Dec 2007
Nice wing fillet. They have been a popular item of discussion here. Will you be sharing your script plugin?
Carl
Old Jul 29, 2010, 09:37 PM
ShaneW is offline
Am I going up?
ShaneW's Avatar
Joined May 2006
Thanks Carl.
Good question. Now here's where I might sound like a bit of a d#@k. I've actually been working on packaging them up as a commercial product. Nothing too expensive, but a lot of work went into them. Haven't taken the plunge yet as to offer them as a product as I would want to have them a bit more robust.
But, having said that, I'm more than happy to share my knowledge on the subject and provide some hints and tricks, etc.
Hope you won't hold this against me too much.
Shane.
Old Jul 29, 2010, 09:44 PM
roger2525 is offline
Find More Posts by roger2525
United States, CA, Poway
Joined Oct 2006
Originally Posted by ShaneW View Post
Thanks Carl.
Shane.
how much are you thinking you want for them
roger2525 is offline Find More Posts by roger2525
Old Jul 29, 2010, 09:47 PM
ptxman is offline
Find More Posts by ptxman
Calgary, AB, Canada
Joined Oct 2002
I've actually been working on packaging them up as a commercial product. Nothing too expensive, but a lot of work went into them. Shane.
Go for it. Im customer #1. Rhino fillets are my arch nemesis as evidencd by my several posts.
ptxman is offline Find More Posts by ptxman
Old Jul 29, 2010, 10:00 PM
Haole is offline
Stranger in a land
Haole's Avatar
Hawaii
Joined Dec 2007
Yeah, it's completely reasonable to sell your code. I think that you will find a lot of support from users like us who are serious about design. Don't expect to get rich or anything, but by all means go for getting compensated for your hard work. I'll stand by as interested in the 'package' deal.
Carl
Old Jul 29, 2010, 11:00 PM
ShaneW is offline
Am I going up?
ShaneW's Avatar
Joined May 2006
Thanks for the support.
I've been mulling this over a fair while now, but I haven't sat down and figured out a price. It won't be much though. I'm not in it to make money, just offset a little of price for the hobby (if I'm lucky!)
Something to note - I have a number of features so I may look at offering them idividually or as a package.
For example I have the following:
Create Wing - Enables you to create a wing surface and associated female mould for CNC. Using a DAT file for te profile and the Leading and Trailing edges. Does bends for turn wing tips or gull-wings, and twists for wash in/out as well as dihedral.
Wing Fillet - As already described.
Create Canopy - Define a canopy line, have a fuselage surface and it will separate the fuz including lips for the canopy to sit on (cool for creating moulds!). Hope to include an extra soon of producing the canopy mould as well.
Create Formers - This is a big one for me. It allows you to take a fuselage surface, define former and stringer reference lines, and create a full set of formers and stringers which have intersecting cutouts from each. This takes about 50% of the work off creating built up kits - which is something I do.
Plus I've got a few other smaller scripts that add value in other places.
Let me think about it a bit more and I'll post the details up. Thanks.
Shane.
Old Jul 29, 2010, 11:15 PM
Arbo is offline
Find More Posts by Arbo
Joined May 2000
Arbo is offline Find More Posts by Arbo
Reply With Quote  (Disabled)
Old Jul 29, 2010, 11:18 PM
Joined Oct 2006
I am inline for it
Old Jul 29, 2010, 11:46 PM
Haole is offline
Stranger in a land
Haole's Avatar
Hawaii
Joined Dec 2007
This would be really nice and would save me some time. Keep us posted.
Carl
Old Jul 30, 2010, 03:05 AM
Harpye is offline
Harpye's Avatar
Germany
As I got into this issue in VERY TRIAL AND ERROR based way... I got Rhino 101 scripted documentation and some help from the Newsgroup / Feeds ... would you link the reference material you used for the code?????
I recently plan to concept a 3D printer ( Gypsum printer) and thought to generate the coding matrix by Rhino script.... And I do gather all the information I'm able to get!
Mini-HowTo Rhino ... some basics Harpye CAD/CAM 574 Apr 28, 2016 08:40 PM
Wanted Looking for some 4S and 5S zippy/Turnigy/Rhino Lipos Aga1978 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 30, 2009 08:09 AM
Help! Probably basics for some markles123 Sailplane Talk 6 Oct 07, 2009 01:46 AM
Discussion Some basics of FPV for a beginner?! GOK FPV Talk 10 Feb 15, 2007 08:04 PM
In need of some basics Doug Sipprell Batteries and Chargers 5 May 26, 2004 10:21 PM
