Old Oct 25, 2009, 08:19 PM
Stranger in a land
Haole's Avatar
Hawaii
Joined Dec 2007
Nice Rhino modeling guys. Keep up the helpful tips! I love developing sections from complicated surface forms, then extruding them into solids for further development.
I haven't played around with the public beta of Rhino 5 (64-bit) but it looks as though it'll be a really promising release. Hopefully I won't run out of memory anymore while doing huge booleans.
Carl
Haole is offline Find More Posts by Haole
Old Oct 26, 2009, 10:17 AM
Build it again, Sam!
Harpye's Avatar
Germany
Hello Carl!
Nice .. I'm quite not sure about the plane type, but looks interesting
Harpye is offline Find More Posts by Harpye
Old Oct 27, 2009, 05:33 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Sadly, its just us three Rhinoers as far as I can tell.
Old Oct 27, 2009, 08:26 AM
Harpye's Avatar
Germany
I know some more... but tey are mainly in the micro builders channel ....
When I did my workshop the other year before .. I got an e-meil from Mc Neel
the husband from the owners secretary is RC modeller , too and reported his wife....
Old Oct 27, 2009, 02:51 PM
Stranger in a land
Haole's Avatar
Hawaii
Joined Dec 2007
There's another person who contacted me via email about using Rhino but I can't remember what that member's name was. He's making Van Horten wings mostly if that helps, and does nice solid modeling. Some of the canard forum guys are using other suites and then it seems I also ran across another couple of Rhino users a while back, but my memory does not serve.
Funny story about McNeel.
C
Old Oct 29, 2009, 12:57 AM
It actually Flies!
Float Flyer's Avatar
Salmon Arm, British Columbia, Canada
Joined Feb 2006
Whoo Hoo!!
Just found this thread.
I just got Rhino after looking at a number of systems. I think that it is the best in class for it's price. I have only been using it for a few weeks now, but I am very impressed. I am teaching myself, so lots of room for assistance and tips from the pros!
Float Flyer
Float Flyer is offline Find More Posts by Float Flyer
Old Oct 29, 2009, 02:40 AM
Stranger in a land
Haole's Avatar
Hawaii
Joined Dec 2007
Well that's great, and I'm up for taking some time to write a few tutorials on building complete airframes--laser-cut-ready, and also looking forward to learning more tricks from you all and whoever else happens to join in this discussion.
Let's keep it going and I'd like to volunteer to demo my process of building a complex wing, starting from root and transitional airfoil sections, into a complete solid structure. This should be fun and educational, and here's a tease of what can be done very easily with Rhino 4.
Carl
Old Oct 29, 2009, 02:44 AM
sandb0x's Avatar
Coventry, UK
Joined Jul 2007
Hi, guys. I am using Rhino for preparing file for laser cutting.
Here is my quick method for making wing in Rhino and some 3D models.
http://http://www.youtube.com/watch?v=x3GfU7gOI5M
Here is the link how to import airfoils into Rhino: http://en.wiki.mcneel.com/default.aspx/McNeel/RsAirfoil
Here is script for calculating balsa weight (its for 9 lb/ft3 balsa):
_-NoEcho
_-RunScript
Option Explicit
Dim arrObjects, strObject, dblLength, intCount, dblNumber, dblBalsa, dblX
dblLength = 0.0 : intCount = 0 : dblNumber = 0.0 : dblBalsa = 0.00014 : dblX = 0
arrObjects = Rhino.GetObjects("Select Objects", 16, True, True)
If IsArray(arrObjects) Then
Rhino.UnselectObjects arrObjects
For Each strObject In arrObjects
'arrMP = Rhino.SurfaceVolume(strObject)
If Rhino.IsPolysurfaceClosed(strObject) Then
dblNumber = Rhino.SurfaceVolume(strObject)
dblLength = dblLength + CDbl(dblNumber(0))
intCount = intCount + 1
End If
Next
If intCount > 0 Then
dblX = dblLength * dblBalsa
Rhino.Print "Polysurfaces selected: " & CStr(intCount) & ", Total wight: " & CStr(dblX) & " grams"
End If
End If)
sandb0x is offline Find More Posts by sandb0x
Old Oct 29, 2009, 04:43 AM
Harpye's Avatar
Germany
I allways use the point cloud from NACA or MH Aero Tools Archieve...
Well there are different styles of building / construction comming up ...
Balsa and ply
The Balsa stringers and ribs are done from the small part to the assembly and back to the elements on the detail work
Foamy / Thermo restructuring
I usually come from the hole thing down to the element when creating tools and structure and go back to the surface / skins when comming to the built
Foamy HWC
I created a kind of virtual workspace, using Rhino Script ... So I can put my virtual part on the virtual machine work space press start and get the 4 axis NC code for that location in the real machine back...
Old Oct 29, 2009, 05:35 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I start with a solid or surface model of the structure, then offset it to get sheeting, then create the structure as interlocking sheets of real thickness wood, then trim it with the skin shape.
Then mesh outline each part to get the raw laser cut file data.
Sheeting is smashed flat.
Over to Corel draw for tabbing..its eraser is slightly easier than subcurve deletion. Or curve boolean
Old Oct 29, 2009, 07:06 AM
Harpye's Avatar
Germany
I mostly use intersection of layers / planes to define the structural parts from a scaled and adjusted 3 view..... this also works rather fine from more "organic like" sources the closed spline " tension" defines the muscle volumina and the effort of definition causes a more or less soft or hard characteristics....
Old Oct 29, 2009, 07:10 AM
Harpye's Avatar
Germany
Or another one ... made after a the Lord of The Ring figure.... guess what it should be....
Old Oct 29, 2009, 07:11 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
closed spline tension? do you mean T-splines..dont have that..
Old Oct 29, 2009, 07:15 AM
Harpye's Avatar
Germany
as you draw an open spline you are able to balance / weighten the definitions ( points ) try what happens as you create a closed line through points ( it is called "curve : interpolated points in the English version") the curve changes as you touch the first point with the last the connection will be "smooth"! so get the longitudinal rails / stringers / guidelines by the intersection layers and afterwards use those closed "rings" to specify the ribs/ spacers muscle segments or whatever to be detailed....
Here is anotherone ( after a warhammer figure which was much easier than the orc.... ouuupps) ... can't find it .... here is alternatively another more RC related trial ... ( I just was not able to get the CG Right...) ( George would kill me )
Old Oct 29, 2009, 07:17 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Looks seriously Uruk-hai to me..
Wonderful work Harpye
I am afraid mine is more munfdane..
Er Indoors wanted a new bedroom..design and we watch a lot of TV in bed..
Still it saved me a load of time and money 'No, I don't want that seat under the window: I would have to cut the curtains' Sigh.
Quite pleased with the telly. Its only cartoon scale, but I did manage a curved screen and an actual screen grab of the TV card in my computer
On another note, this cockpit panel is nice too.
Mini-HowTo Rhino ... some basics Harpye CAD/CAM 557 Nov 15, 2012 01:17 PM
Wanted Looking for some 4S and 5S zippy/Turnigy/Rhino Lipos Aga1978 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 30, 2009 08:09 AM
Help! Probably basics for some markles123 Sailplane Talk 6 Oct 07, 2009 01:46 AM
Discussion Some basics of FPV for a beginner?! GOK Video Piloting (FPV/RPV) 10 Feb 15, 2007 08:04 PM
In need of some basics Doug Sipprell Batteries and Chargers 5 May 26, 2004 10:21 PM
