Old Sep 18, 2009, 11:12 AM
durone is offline
Find More Posts by durone
Italy
Joined Jan 2003
devFus, the new application to draw fuselages
Today has been released devFus, the new application to draw fuselages.
See http://www.devcad.com/eng/devfus_frame.htm
You can find two versions:
devFus - to create Cad drawings of fuselages
devFus Cam - the same as devFus, but with Cam features to create the GCode-ISO files of the parts to cut
The actual versions are 'rather well' tested beta releases, available only in english
I hope you find devFus useful and easy to use
best regards
Stefano
durone is offline Find More Posts by durone
Old Sep 19, 2009, 04:18 AM
orestis is offline
Find More Posts by orestis
Joined Dec 2007
Hello!
I first write on rcgroups now,because i am excited about that software!
I installed the program but i have some problems when i need to edit the fuselage outlines.(the image shows the problem after pressing the button in the red cyrcle)-I am running Windows Vista.
It seems to be a very interesting program that i sertainly need!I always have problems and dificulties on hand-designing fuselage formers for andvanced airplane designs!
Thank you Stefano for all your job you do on these softwares!
Best regards from Greece!
orestis is offline Find More Posts by orestis
Old Sep 19, 2009, 04:36 AM
durone is offline
Italy
Joined Jan 2003
Originally Posted by orestis
Hello!
Does that happens also if you go to modify an existing Project?
Anyway You can go to the Last panel to fiinish the project, then export it and send the exported file to my email info@devcad.com, in this way I can understand where the problem is (it's still a beta...)
thank you for your attenction
stefano
Old Sep 19, 2009, 04:43 AM
orestis is offline
Joined Dec 2007
Yes stefano!It happens if you also modify an existing project!(the picture i posted is from an existing project).
Sorry Stefano, i am stil running the trial version and i can't export projects!
I understand that this is a beta,so i thought it would also be helpful for you to report that issue.It might be for others as well!
Old Sep 19, 2009, 06:28 AM
durone is offline
Italy
Joined Jan 2003
I solved that problem, I'm uploading the Beta2 to the web site
Thank you for the cooperation
Stefano
Old Sep 19, 2009, 06:35 AM
orestis is offline
Joined Dec 2007
I am looking forward to try the new version!
Old Sep 19, 2009, 12:51 PM
mikeperik is offline
Find More Posts by mikeperik
Joined Mar 2005
I downloaded it and it installed but when I try to run it I get a dialog about MSVCP71.dll not being found.
Should the dll be included with the app installation?
Looking forward to trying this out.
mikeperik is offline Find More Posts by mikeperik
Old Sep 19, 2009, 01:12 PM
durone is offline
Italy
Joined Jan 2003
That file is missing in same Windows version (I discovered that now... ).
I'm uploading a new setup file for both devFus and devFus Cam.
That should fix the problem.
thank you for cooperation
stefano
Old Sep 24, 2009, 08:38 PM
Joined Mar 2005
How do you get the formers shaped correctly. I stepped through the Spitfire exampled and it helps understand how to go about creating the fuse. I'm trying to design the Yak-3 fuse but I'm not sure how to go about shaping the formers correctly.
Also, how would you create an angled former. Like the back of the fuse at the rudder joint.
Old Sep 25, 2009, 03:24 AM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
devFus Cam
Hi i am having the same problem trying to get some ideal on how devFus Cam works it looks like a good software
i have started a new project a Grumman panther setup the image in acad export it
side.bmp and top.bmp all OK in background images calibrate all OK
in fuselage outlines settings import side outlines from file .dfo format how or were can i get this file format
save, save as import or export in both devFus Cam and devcadcam pro has .dfo mansion as a format
format are devcad format .dc1
fro mat are devfuz cad cam .dc1 .dc2
dpot is offline Find More Posts by dpot
Old Sep 25, 2009, 04:01 AM
roger2525 is offline
Find More Posts by roger2525
United States, CA, Poway
Joined Oct 2006
I also have the program, Its a great program but has one thing missing, and that is it dont let you import the cross section of the fuselage that you get on a good 3 veiw plan. unless I am missing something. I am having a real hard time getting a fuselage look right in edit former mode.
roger2525 is offline Find More Posts by roger2525
Old Sep 25, 2009, 04:53 AM
durone is offline
Italy
Joined Jan 2003
See the Help (use the help button), it explains the right way to go
No angled former with the current version, I'm evaluating than for the future
Old Sep 25, 2009, 04:56 AM
durone is offline
Italy
Joined Jan 2003
You must draw by hand the outlines, as advised in the help file, as you haven't still a dfo file fot that fuselage
I see a problem in the black background there, something is wrong.
If you finish the project creation, export that project and send me it to info@devcad.com I can take a look at that
Anyway modeling such an odd fuselage can be challenging......
No the simplest as the first project, believe me
Old Sep 25, 2009, 04:58 AM
durone is offline
Italy
Joined Jan 2003
You must simply understand the way the formers definition works.
I cannot let the user to import a free section, as it will break the actual strategy.
News of Beta 3:
the actual Beta 3 version can use as background images also DXF or DC1 (devCad) Cad files
Old Sep 25, 2009, 01:19 PM
dpot is offline
dpot's Avatar
Joined Dec 2005
thanks for your quick response i have zip the file and sent it to you
i thought that if the software can handle the panther then it will do anything looking forward to finishing it have the cnc wormed up and ready to go
Discussion New Blade CX Scale Fuselages Jcopter Coaxial Helicopters 10 Mar 14, 2007 08:45 AM
Discussion New range of Retrofit Fuselages in USA IanA Scale Helicopters 9 Jul 31, 2006 07:45 AM
Discussion New application for my old lipos jfv61 Batteries and Chargers 2 Jul 15, 2006 02:24 PM
new application of beaver decals liaudio Parkflyers 5 Jan 14, 2003 10:56 PM
FS. New FVK Graphite sailplane fuselages and light built up V-tails bfraser Aircraft - Electric - Airplanes (FS/W) 2 Dec 06, 2002 06:35 AM
