Zurich
Joined Apr 2006
Silverlit Swiss Version F/A-18 (NEW and diff from AirHogs F-18!)
EDIT > NOTE: I have just discovered that this Silverlit Swiss Version F/A-18 is NOT the same plane as the AirHogs F-18!
Rather, it is likely an updated re-design from Silverlit. I spotted and quickly bought a grey Silverlit F/A-18 Hornet (product #87506) in very detailed & realistic Swiss military markings .... on top of very detailed and complete MOLDED-IN all-over surface markings, like a plastic model kit! It's available at Franz Carl Weber and I am sure it can be shipped internationally > http://www.fcw.ch/filialen/zuerich/ The production values are great, and the Silverlit aerodynamics were easily improved with a hairdrier & lots of twisting in various directions. I even bent the nose more realistically scale down (the fuselage, also up to the nose, should be in an almost straight line on the bottom: find a scale 3-view), removed the landing gear and black plastic sockets (filled holes w/ EPP scrap using CA gel). Comparing with wheels-off both before & after, this twisting & bending (needed several hairdrier actions to stay re-formed) almost DOUBLED the L/D (glide ratio), a measure of aerodynamic efficiency, and made the handling/response much more to my liking (it was passable out-of-the box). I'm very happy with this nice toy (now closer to the "Pro" series), and can loop and barrel roll it or fly in small highly-banked circles around me at eye-level. However, I think my ORIGINAL ("UNmod") F-22 is still far more realistic in the air (it's almost exact scale) and can outfly anything similar on the market today > the Unmod has lower min speed, greater top speed, much tighter turn ability, more stable, quicker response (see "Maneuver Test" YouTube vid), and can be flown (by experienced pilots) in very windy/gusty conditions (the Silverlit F-18 needs calm conditions) .... BUT you can't buy that one, so check out this nonetheless very cool Swiss Version F/A-18 anyway! I don't have any Unmods to play with now, so I am off again to fly THIS fun, somewhat modded (I'd say, "trimmed") Swiss Army jet! Lee ![]() EDIT: (reprise) I now see that the AirHogs F-18 is a TOTALLY diff plane than this new one from Silverlit! Everything is different! This ("Swiss Version F/A-18") one has a diff body, diff wings, diff vert and horiz tails. Every part has a diff shape than the AirHogs one! It has molded-in detail, the leading edges are SHARP, it has air-air missle holders on the wingtips, etc. Perhaps it is a 2nd-generation design effort from Silverlit. But it IS cool and I love it (with my hairdrier "re-design"). Everyone needs one! I'm sure FCW can ship .... |
Zurich
Joined Apr 2006
The F/A-18 is larger than my F-22 and out of the box is a floater (I changed that!*). Further, my F-22 (UNmod) can fly circles inside AND outside it (i.e., the UNmod is both slower and faster on command; the ITC version is much faster than the Silverlit/AirHogs F-18, but the UNmod F-22 is faster AND much slower than the ITC version F-22). For calm weather, I still think the Swiss Version F/A-18 is fun (but not close to the UNmod F-22). * by improving the aerodynamics greatly, it has more penetration, but can still loop, FLY INVERTED briefly, climb and also slow down nose-high to land |
Zurich
Joined Apr 2006
ALL are on 27 mHz. |
Zurich
Joined Apr 2006
Tested Band A
I hairdriered & twisted my second Swiss Version F/A-18, but this time left the landing gear sockets in (I think the wt diff btwn leaving them and removing them, filling in the holes with EPP using CA gel is obscure [I can use F-22 gear on the first when I wish, removably fitted into a slot]), BUT I did make NEW landing gear using two old sets (and 3 wheels, natch) from a scavenged old Silverlit "Pro", which use THINNER wire, but splayed & LOWERED the main gear and shortened the nose gear. The takeoff angle is similar, but I saved a bit of weight and lowered the "stupidity" level of the (I think) silly-looking "Concord"-esque landing gear. And it DOES take off fine with the lighter, lower gear. Flying with and w/o the gear, I have the idea that Silverlit attempted to pendulum-stabilize their VERY un-maximized aerodynamic approach. At any rate, the greater vertical (roll axis) mass moment-arm slows down the roll response a bit, but the improved stability resulting from my "intense" hairdrier twist re-arranging of ALL the surfaces overrides that. Airplanes are dynamic (aerodynamics) and don't need pendulums, just smart/educated design.
Delay: it turns out that compared to the nice response on my A, the C does have a bit of a delay (that is the same with my 2 A and 2 C TandemZ-1's: the A is much better!). But my C is STILL fun, and I'll use it for fun "crashing and bashing", knowing I have now a perfect A in reserve!
Zurich
Joined Apr 2006
ground-to-air attack (& vice versa!)
Yesterday I was at a predominantly Italian birthday party at a small park here in Züri. One of the guys who had a toy cardboard-tube mortar-like foot-long foam-"rocket" launcher, decided it would be fun to play (I won't name the adversaries) "religious"-Insurgent vs modern Military aircraft. Even though THIS F/A-18 has Swiss (NON-combative!) markings, it made no diff in the game. So with my acceptance and no further encouragement all the males took turns trying to shoot down my EPP foam F/A-18 with yellow EPP foam rockets. Some came close, as I flew over, through or around them at low and higher speeds, but no one hit it.
However, I did manage, as the wind came up, to hit the main antagonist (rocket-launcher owner) in the head; I'd only wanted to come close to his head, but the (harmless!) "hit" was some kind of justice. Then they spent hours shooting the rocket at each other, etc., as I got into some GREAT food & wine ....
Joined Feb 2008
Hi Lee, hows things?
Sounds like a fun party. I would love to get one of those fully auto nerf guns for that kind of a game! I don't know how old your playmates were in this case....little kids are a blast to play with, but its also cool when the big ones drop that "adult" pretense, and let their soul have some fun too! |
Zurich
Joined Apr 2006
Lee ![]() *[I had more fun with the nice WOMEN, who along with me laughed at the guys who for hours continued to play with the long cardboard-tube rocket launcher, long after the ground/air "combat" ended. My conversation starter: "If I had one of those things, I'd call it "Sigmund" and have that name in large letters on the side!"] |
Zurich
Joined Apr 2006
More Info
1. Using my F-22 landing gear re-bent to give a VERY slight nose-high angle, my well-used C takes off from rough asphalt in NO wind in ~3.5 m/ 11'. With my shortened, thinner-wire "original" F/A-18 landing gear (at a greater angle than above C nose-angle, but less than Silverlit "Concorde"-original), my A could take off in a slight headwind in ~4 m! I.e.: lowered nose angle takes off in shorter distance.
I suppose that the very thin-wire F-22 gear, w/ more fwd mains, flexes to allow rotation at T/O speed, and the lower nose angle with thus more leveled (up-thrusted!) motors permits greater initial acceleration. Another example of Silverlit's design stupidity (even w/ "kid-proof" thicker wire) in a well-MADE product! 2. The R/C range is listed as 50 m (~160'), and that seems to be where it drops out near the ground, esp. as the LIPO nears low-voltage cutoff. 3. My left C motor was tight, resulting in a strong tendency to spin in LEFT, since the right motor would spin down longer w/ no power .... so I used the "unbalanced taped-on paperclip to one blade-half" vibration trick (holding motor!) for ~1 min to loosen & fix it! 4. the printed flt time is ~5 min. |
Zurich
Joined Apr 2006
BACK to the Future ....
Yesterday I was having fun buzzing myself & my two birds*, when one close pass came too close. I bent forward at the waist, ducking my head/upper body as one of the spinning props (no protective landing gear!) actually grazed/touched (OK, buzzed!) the back of my shirt, as the menacing little fighter continued and climbed out. THAT was a very close pass ....
*Both small but intelligent birds enjoy R/C planes indoors (TZ-1 helis) or out (male Kiki used to say "Go, Go!" when I'd catch a thermal), as I also narrate the action. They understand the MEANING of ~80 words in English. I am convinced that from such observation over years that that is how Kiki learned to catch and circle in occasional thermals himself while slope-soar piloting his hangglider (he is a practiced and skilled hangglider pilot; Star just rides). When I have both along for the mtn bike-rides they love, they stay in a small cage-like Transport Box hanging around my neck. Star (Kiki's female partner), who has found out how to open the Transport Box and wait inside [so it's wire-locked shut!], would try for Barcelona or Leipzig if I let her loose outside! Kiki not, having slowly found out that unauthorized flights (he got used to flying on command to specific targets in parks) make a lot of trouble for everyone, him included. When he did get adventurous, he'd often get lost, land and start crying for me till I located him (these birds have zilch navigation skills: it took him 2 yrs to get the multi-room layout at home). So when it's just Kiki and me, he rides on TOP of the box, bravely outsife except in heavy traffic. But Star would go for it (and probably be a cat's appetizer). |
| Thread Tools | |
| Help! F/A 18 Version 2 Jolly Roger - Parts Mising | viperjody | Banana Hobby | 60 | Nov 11, 2009 08:04 PM |
| Question F/A 18 Version 2 Jolly Roger | viperjody | Banana Hobby | 0 | Jul 22, 2009 01:30 AM |
| Help! exceed-rc F/A 18 Tiger version oops | mizzouHHR | Nitro Planes | 4 | Jun 16, 2009 08:17 PM |
| KCOX F/A-18 Plans.... | Kevin Cox | Electric Ducted Fan Jet Talk | 6 | Apr 20, 2007 02:11 AM |
| Kevin Cox F/A-18 Conversion to E version? | Rob Andrew | Electric Ducted Fan Jet Talk | 14 | Sep 16, 2001 04:45 AM |
