Old Sep 18, 2009, 06:40 AM
vleisie is offline
Find More Posts by vleisie
boerie roll
vleisie's Avatar
Johannesburg, South Africa
Joined Apr 2007
Build Log
Prop in slot Saab Draken - Plans (6mmFlyRC)
So, I’ve been working on this design for a 6mm Depron, profile, prop in slot Saab Draken.
Depron Draken (2 min 12 sec)
This jet is designed in the size and style of build that I like.
The dimensions are:
Span: 26” (660mm)
Length: 40.5” (1029mm)
Flying weight with 2200mah battery: 17.75oz (503g)
Motor: 2212-06 (2200kv)
Prop: APC 6x4E
6mm depron.
2 Servos on the elevons only.
It should be an easy build so I’m hoping to have the prototype flying by the end of the weekend. If there is any interest, I’ll post plans once any snags are sorted out.
***Update***
Plans added
CG position 0.5" (13mm) in front of wing break.
****Update 2****
Tiled plans in post #14
Build pictures from post #21
*****Update 3*****
Optional underwing pylons shown in post #54
******Update 4******
Video: post #100 & #121
*******Update 5*******
This jet is available as a kit from www.6mmflyrc.com.
********Update 6********
A 17" span version is available from www.nicohobbies.com, where there is also an excellent build guide from crxmanpat as a free download.
Enjoy!
Marcel
vleisie is offline Find More Posts by vleisie
Old Sep 18, 2009, 05:44 PM
Kangaman is offline
Find More Posts by Kangaman
Kangaman's Avatar
North Hollywood
Joined Jun 2006
ARGH ----- More to build
yes please
Is there a 12 step program to stop me wanting to keep building??/ ,
paul
Kangaman is offline Find More Posts by Kangaman
Old Sep 18, 2009, 05:55 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
yes please
paul
Yes there is:
1) Wife
2) kids
3) wife
4) wife
5) wife
6)....you get the picture
ATIS is offline Find More Posts by ATIS
Old Sep 18, 2009, 10:28 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
This is very cool and adds a little dimension to the plane. I'd be interested in doing one if it works out.
And of course you've made it for my preferred power plant.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Sep 19, 2009, 01:38 PM
Kangaman is offline
Kangaman's Avatar
North Hollywood
Joined Jun 2006
Funny - - but oh so true.
Paul
Old Sep 20, 2009, 11:03 AM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
Thanks for the comments.
The Draken went together quite easily. Maiden flight tomorrow morning, hold thumbs!
Marcel
Old Sep 20, 2009, 12:09 PM
mullinspsm is offline
Find More Posts by mullinspsm
Jets are for kids-of all ages
Florida, USA
Joined Jun 2008
I have always liked the Drakken. It was my first plastic airplane model as a kid. I would like to have plans in .dwg if possible, or any other way. I also would like to know. All up weight, size of battery you are using and c.g. location.
mullinspsm is offline Find More Posts by mullinspsm
Old Sep 20, 2009, 12:11 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Looks good Marcel. Good luck on the maiden!
If it works out, I'd definitely like a set of the plans to try one for myself.
Pat
Old Sep 20, 2009, 01:36 PM
smkn951 is offline
Find More Posts by smkn951
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
same here.
TIA
Carl
smkn951 is offline Find More Posts by smkn951
Old Sep 20, 2009, 05:14 PM
vsci79 is offline
Find More Posts by vsci79
Joined Sep 2008
Beautiful!
vsci79 is offline Find More Posts by vsci79
Old Sep 21, 2009, 12:15 AM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
Well, I had two very successful flights this morning and it looks like this thing will be a lot of fun!
As could be expected, it rolls like a drill and seems to be capable of extremely high angles of attack.
The prototype weighs 16.75 ounces (475g) ready to fly but without paint, using a 2200mah battery.
I had the CG at 1 (25mm) in front of the wing break, which seems to be a good stable position.
Plans and build pics will be up soon.
Thanks for the interest.
Marcel
Old Sep 21, 2009, 12:31 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Marcel,
Congrats on the maiden flights! I would say the weight added by paint will be negligible, maybe get you to 17oz total if that.
Looking forward to seeing plans so I can try one myself.
Pat
Old Sep 21, 2009, 12:38 AM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
Thanks Pat,
I have added plans in A0 format to the first post. I'd be grateful if someone could tile them to A4 and Letter size.
Marcel
Old Sep 21, 2009, 12:48 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Marcel,
Tiled for Letter and A4 at your request.
EDIT - Tiled files cleaned up some.
Pat
Old Sep 21, 2009, 01:00 AM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
Now, if there were any way to make it sound like a real one
A Draken doing a low pass during a show was one of the high points of life when I was a kid.
Those "intakes" look pretty good for such a simple design. That is always the spot I complain about when I see a Draken model....
perttime is offline Find More Posts by perttime
Discussion Prop in a slot BlueWonder jets TJC Foamies (Scratchbuilt) 427 Aug 17, 2011 05:09 PM
Discussion prop in slot wing steve88r Foamies (Scratchbuilt) 17 Jun 30, 2009 04:03 PM
Video Prop in slot noise test leadfeather Electric Plane Talk 5 Nov 07, 2008 06:41 PM
Discussion Slot design for "prop in slot" leadfeather Foamies (Scratchbuilt) 32 Oct 17, 2008 09:45 PM
Discussion Plan for "Prop in a slot" profile Epp jet model ? dekan Pusher Prop Jet Models 0 Jul 11, 2007 01:36 PM
