Go Back   RC Groups > Aircraft - Electric - Helis > Micro Helis
Old Nov 06, 2009, 09:01 PM   #1276
Marcin M's Avatar
Faulty receiver 4G6 ?!...
Originally Posted by Z06 Tony View Post
You may be running the batt too low. I only fly 5 mins. Try that and if it holds for 5 mins you are good. Also, The Oversky batts are much better.
I have six batteries - one original and 5 of the Storm 3.7 V / 600 mAh, 20C. On each is the same. In the basic version of the engine problem appeared after about 4min40sec, after changing the HP06S Outrunner Brushless Motor and XP-7A ESC, this happens at 3min30sec. It looks as the receiver lost the signal for a split second and then he did not saw the minimum throttle position.
Marcin M is offline Find More Posts by Marcin M   Reply With Quote
Old Nov 06, 2009, 09:22 PM   #1277
Originally Posted by yoshgixxer View Post
hey amp any chance this short can out runner has more power then the stock or 03 motors?? its wayyy shorter then the stock motor! its a little thing!
Nope...if it is the CO5 and not the CO5L it won't have the torque for a 4g6. Great in a 4#3B or the like. Not alot of reports on the CO5L but the wk would be better there too.
Amp
Ampdraw is offline Find More Posts by Ampdraw   Reply With Quote
Old Nov 06, 2009, 11:07 PM   #1278
Originally Posted by Ampdraw View Post
When I had the 4g3 wk esc running my HP06 the fet's weaken. Don't know if Dkfuji was talking about a wk esc or the XP. But with the wk yep the fets definately weaken (at least for the 4g3 one).
Amp
Hey Cam. Yep, was talking about the Walkera ESC. I just noticed lack of HS and climbout. Thought it might be the motor melting down or battery connectors or ...But it was the ESC. I have a bag of them that just don't have the punch they once did. Use them for parts now. Maybe just too many test flights with mystery motors. LOL.
dkfuji is offline Find More Posts by dkfuji   Reply With Quote
Old Nov 07, 2009, 01:01 AM   #1279
Flying in the Concrete Jungle
HeliFlyer711's Avatar
Anyone Everyone?
How to you fix the tail slider, I just breezed over the whole forum and must have missed it.....where do you put the crazy glue to keep the bearing in place I got like 3mm play
HeliFlyer711 is offline Find More Posts by HeliFlyer711   Reply With Quote
Old Nov 07, 2009, 01:34 AM   #1280
Originally Posted by HeliFlyer711 View Post
Anyone Everyone?
It is the little slider bearing in the plastic slider housing. The bearing has play within the housing. You have to CA the collar of the bearing into the housing to keep it from moving back and forth.
Old Nov 07, 2009, 06:06 AM   #1281
Hi Darryl, yep....I remember having reservations and thinking the esc works...therefore it is fine....not so.
How are you going flipping this little guy? Last vids I have seen were really awesome and well we live just a little far apart to have a fly-off!
Having alot of fun with my HH g3....but also enjoying hearing about this heli.
Amp
Old Nov 07, 2009, 11:07 AM   #1282
U also gotta supe glue the pitchslider arm to the hallow shaft..after you press it together by putting needle nose pliers on the back of the shaft and pressing the plastic slider arm all the way tight with the bearing..
yoshgixxer is offline Find More Posts by yoshgixxer   Reply With Quote
Old Nov 07, 2009, 01:42 PM   #1283
ell after quickly shreding the junk stock dampners, i decided to fnd sumthing better!..i think this should hold upfor a while..i found O-rings in a MIA battery and antenna mounting kit that fit perectly in the head block and firmly over the feathering shaft..smilar to the way the Trex 450 head dampner is set up, then i used very tiny O-rings from the MIA fly bar stabilizer set to use as spacers inbetween the dampner oring and the aluminum bearing spacer. The small o-ring tightens up the dampening and creates a small gap between the dampner and the aluminum spacer to stop it from binding against the head block..
a flew it two flights and now the helicopter stops the weird drifting and sluggy response..everything seems crisp and responsive now..and the head is much much stiffer..so for 5 cents in o-rings it worked out great!
heres some pics so you can see the order i stacked everything..sorry there kinda crappy i took em with my Iphone
  • Name: oringmod3.jpg
Description: orings and package i got them from orings and package i got them from 22.6 KB · Views: 42
  • Name: oringmod.jpg
  • Name: oringmod2.jpg
Description: what it lloks like together what it lloks like together 34.1 KB · Views: 84
Old Nov 07, 2009, 01:47 PM   #1284
Power revived when exchanging it for micro deans connectors(dark red plastic) since the power of the batteries had lowered. However, main blades flutter intensely by the pitch of 50% by HP08S/XP7A/T20 because HS is too fast. the same also T18. The flight is exactly crazy but I have come to like it.
Should I change it to the metal head?
No problem for you with T20?
  • Name: DSC00599.jpg
Tipstar is offline Find More Posts by Tipstar   Reply With Quote
Old Nov 07, 2009, 02:30 PM   #1285
I swapped heads on my 4G6 with my 4G3 to use the Gaui double bearing mixer arms I had installed in that plastic head assembly. So with the plastic head assy with Gaui double bearing mixer arms I got crazy blade flutter????? It turned out that the bearings in my plastic blade holders were slightly notchy. They worked fine with a turbo ace red w/16T on my 4G3 but the HP08-2 w/ 20T pinion needs smooth and perfect everything.
Good Luck, Don
dbennettya is offline Find More Posts by dbennettya   Reply With Quote
Old Nov 07, 2009, 03:07 PM   #1286
Thanks DK, I wound up taking the whole assembly apart at 2am mind you (I need 12 step meetings for heli addiction) and then I saw what you posted, ..popped the slider back into the plastic with a needle nose then Ca'd the metal to plastic, interesting it works better than new now... i like that!!
  • Name: CIMG0188.jpg
Description: Tail slider fix (revisited) for the next guy Tail slider fix (revisited) for the next guy 75.2 KB · Views: 129
Old Nov 07, 2009, 05:13 PM   #1287
Sweet. I had to do that with all of my G6's. They still flew fine without the fix but hey why take the chance? Now with the additional HS I am flying, everything has to be perfect and balanced.
Old Nov 07, 2009, 06:23 PM   #1288
Addicted - seeking help!
If you find a 12 step program, please share. I'll miss my wife and children, but this is getting out of hand .
jgupton is offline Find More Posts by jgupton   Reply With Quote
Old Nov 08, 2009, 12:48 AM   #1289
Hey guys this is what I do for a living and I still have errrr...mmmmm..."issues".
"My name is Darryl and I am a heli addict" LOL
Old Nov 08, 2009, 01:02 AM   #1290
Helicopters Annoymous (HA) - Manny is going to deprogram us by showing us youtube videos of hopped up 4g3's & 4g6's in fatal crashes followed by lipo fires. Coffee and cigarettes provided by wowhobbies.
New Product Walkera 4G6 and CB100 At RcHobbyHelicopter.com johnIn2SonAZ Micro Helis 541 Nov 13, 2009 10:22 AM
Discussion Walkera 4G6 first impression. ehirobo Micro Helis 124 Nov 07, 2009 05:39 PM
Cool a dream come true: new Walkera 4G6 - SD, Pitchtail 4G3 Size robZulu Micro Helis 773 Oct 28, 2009 03:25 PM
Discussion walkera 4g6 dkintx Mini Helis 1 Sep 01, 2009 08:22 PM
Discussion Walkera Lama2 mods. wufer Multi Rotor Helis 4 Sep 04, 2008 09:57 PM
Bored? Want to fight?
Join the RCGroups clan!
