| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#61 | |
#62 | |
I EAT RICE BURNERS
#63 |
Hi all,
My first posting to RC Groups, except for the test. Introduce my 4G6/mod. Replaced to HP08S+T14/XP-7A(Esc for HP06S/HP08S at Jade) mod, since the stock BL becomes extremely hot. That result is very good. Hovering times by normal ST mode(not 3D), 7 minutes by CJ 400mAh/20C batt, AUW 81.5g 10 minutes by stock batt 500mAh/15C, AUW 83.04g About my mod for XP-7A. This ESC can start up outrunner BL more smoothly than the stock. But it doesn't work with 4G6/RX2609, since the level of the throttle signal is low. I found the solution. It is simple and no cost. Remove one pull-down resistor on the XP-7A PCA, it gets to work very well. Refer to the attachment photos. Thanks |
#64 |
inventor of flames decals.
very interessting, Tipstar!
I would love to see a video of how the HP08 starts up with the 7A. and congrats to removing the resistor, this thing is so small, you almost need a microscope
#65 |
xp-7a is great with the hp08 and the hp06 but i use spektrum gear and dont have a clue on combination with wk electronics.
hp08 is a way more better motor compared to wk inrunner. i will install it on the 4g6 when i receive my 4g6. |
#66 | |
Of course, I am using a glass type magnifier. To remove is easy. But..,,To make restore is impossible to me. LOL |
#67 | |
I like the good efficiency of the outrunner BL. However, there is a fault, too. As Handle with care. of outrunner BL. Never turn the blade by hand should not be quick. Because of the lack of 4G6's tail gear teeth. I look forward to your mod. |
#68 |
I EAT RICE BURNERS
OK, I flew a pack this morning with the shimmed head. If I just scale or slow fly it I cannot notice a difference but if I fly it hard and make any sharp moves it is crisper. I can take it high and shoot it straight down and then yank the stick back and it shoots up and no tail boom strike. Plus I think the dampeners will last longer this way. I cannot believe nobody makes an aftermarket dampener for this heli.
#69 | |
http://www.rc-tek.com/us_store/mt802...lay-p2097.html |
#70 | |
Actually the Blade Cp has the stock O rings with 10 shims to give it basically no play at all when you were talking to my brother what he said is that he heard some people running bearings not that we were running bearings. On the Blade cp ever since I have been running alot of shims in there I noticed the dampers will last a very long time I can remember the last time I changed them. I hope it will be the same with these smaller helis. Were you running shims on the 2s 4g6 when I flew it? Did you add shims to them Now for next time
#71 | |
I EAT RICE BURNERS
Just kidding. Thanks alot for the shim link. I will be ordering today. The first heli I ever added extra shims to was my Blade Pro2. I modded it a little and it is sick for a brushed motor and the tail holds rock solid. The dampeners were getting destroyed. I cannot 3d so this is nothing like a Manny vid and the guy who works for me has shaky hands so WATCH AT YOUR OWN RISK-> http://www.rcgroups.com/forums/showthread.php?t=1088320 |
#72 | |
On a stock Blade Pro 2 I would start with 3 shims per side totall 6. I run 10 total on mine but my headspeed is way higher than stock so try that if you dont get a wobble put one more on each side if you do take one off each side but remember the tighter the head dampning the longer the dampers will last. |
#73 | |||
7 to 10 mins? thats hard to beleive!? especialy for a CP heli, unless u run small pinion and low throttle/pitch curve? well.. idk never ran these outrunner. 3 mins and everything in my g6 is on the edge of melting.. hehe here a short flight in my backyard
still all stock with the mods ive posted yet and low throttle curve.. ill try to record a new vid at the field this pm |
#74 | |
I EAT RICE BURNERS
I used some washers from my Trex 250 on my G6. Not sure what part # but they were in with the tail parts. I like the SJM washers you linked plus I might be able to use the bigger ones for shims for something else. |
#75 | |
Marty
Of cource when trying to accellerate the extra weight on the G6 eats more power so times drop considerably. |
| Thread Tools | |
| New Product Walkera 4G6 and CB100 At RcHobbyHelicopter.com | johnIn2SonAZ | Micro Helis | 541 | Nov 13, 2009 10:22 AM |
| Discussion Walkera 4G6 first impression. | ehirobo | Micro Helis | 124 | Nov 07, 2009 05:39 PM |
| Cool a dream come true: new Walkera 4G6 - SD, Pitchtail 4G3 Size | robZulu | Micro Helis | 773 | Oct 28, 2009 03:25 PM |
| Discussion walkera 4g6 | dkintx | Mini Helis | 1 | Sep 01, 2009 08:22 PM |
| Discussion Walkera Lama2 mods. | wufer | Multi Rotor Helis | 4 | Sep 04, 2008 09:57 PM |
