| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 | |
Regards Flash |
#47 |
The Cover was Damping a resonance frequency that quelled (Kept it Happy)the Gyro.
Now you have interaction with the Gyro. -JohnW |
#48 |
Yep as John said...
When I removed the rx cover on my g (when running wk gear) the tail went mad even with high quality gyro tape....refitted the cover and used automotive mounting tape (very similar to the stock) and was fine again. Dkfuji....that was one nice flight. Setup accounts for some of the heli's flight characteristics but man does Manual have a good set of well tuned thumbs...damn! Amp |
#49 |
changed the pinion and put a new set of main blade, run better than new now!! (really better)
even repaired and balanced the set ive had a crash with would just act funny. and the new pinion make things run much more smoother, back to stock gyro gain w/o any wags, feel i could even bump it up a little. cover still out and mounted on gyro foam tape.
#50 | |
#51 | |
Marty
That clear heat shrink on the ESC is pretty heavy for its size, probably will take mine off soon on the G6 along with the rx cover. Also from the factory there's usually big blobs of solder on the battery wire connections, way more than what's needed. |
#52 | |
Pushing 400hp in her. Sweeeeet. Plus its got loads of room for my mobile heli shop. LOL.
#53 | |
I EAT RICE BURNERS
#54 | |
Man with all that 3d on top of test flights, my motor bearings are already gone. Had to drop in a new 003 motor in it. Probably the cause of the thermal shut-down during Manny's earlier flight. Next time its all out or nothing!!!
#55 | |
I EAT RICE BURNERS
#56 | |
#57 | |
Marty
Just got another 2-3 grams lower: |
#58 | |
#59 | |
Marty
With the 500mAh 15C batt it's 86g. Edit: Wonder if boca bearings would be better on the motor? Bearing measurements: 1.5 mm ID 4 mm OD 2 mm width I have 2 of these bearings in my bag of 4#3 bearings, have no idea why or where they came from. The 4#3AB main shaft bearings are the same ID and OD but 1.2mm wide. Last edited by mrschultz02; Sep 21, 2009 at 01:24 AM. |
#60 |
I EAT RICE BURNERS
I shimmed the head and it is nice and stiff. Flew one pack but it is dark in the backyard. Flies real nice and the blades track perfect now. Last time I tried to shim it I used bearings instead of the factory Walkera spacers and the screws loosened up cus they must not have been able to be tightened all the way. Here is a pic of the shims and the new heli trasporter from Harbor Freight. Wonder why Manny never mentioned anything about shimming the 4G3 or 4G6. I assume he had to put extra shims in the SICK B/L Blade CP Pro to stiffen the head.
| Thread Tools | |
| New Product Walkera 4G6 and CB100 At RcHobbyHelicopter.com | johnIn2SonAZ | Micro Helis | 541 | Nov 13, 2009 10:22 AM |
| Discussion Walkera 4G6 first impression. | ehirobo | Micro Helis | 124 | Nov 07, 2009 05:39 PM |
| Cool a dream come true: new Walkera 4G6 - SD, Pitchtail 4G3 Size | robZulu | Micro Helis | 773 | Oct 28, 2009 03:25 PM |
| Discussion walkera 4g6 | dkintx | Mini Helis | 1 | Sep 01, 2009 08:22 PM |
| Discussion Walkera Lama2 mods. | wufer | Multi Rotor Helis | 4 | Sep 04, 2008 09:57 PM |
