| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#16 |
He is probably using the 2801tx and that is how he is able to turn down the swash settings.
#17 | |
#18 |
just put 2 pack (stock and the 400mah 20c) and the tail held very well.. just as good as the stock setup...doing some hover and pitch pump in the kitchen but then.. im not the right pilot to test the capability of the heli, but tail held great.. the CF rod just feel stronger and stiffer.
lighter, stronger and the guide can be removed. my motor/esc become so hot burning hoti think the main gear would need a shim to make thing run abit smoother, someone else noticed that? things doesnt feel totaly smooth in the drivetrain and that seem to come from the main gear. if i lower main gear a hair.. things feel much better but still not perfectly smooth.. not sure whats up there.. and since we have no way to see how the gears mesh, it doesnt make things any easier.. |
#19 | |
#20 | |
#21 | |
Marty
The stock -05 motor does that, put in an -03 motor and the heli will have better performance and the motor will run cooler. The esc getting hot is why I tried different locations away from the rx. |
#22 | |
I EAT RICE BURNERS
#23 | |
#24 | |
Here are a couple of pics of my 2s 4G6. It is very, very powerful. Last edited by dkfuji; Sep 18, 2009 at 06:18 PM. |
#25 | ||
the more i run it the more it seem to become smooth, even put some grease on the gears.. made a big difference i think! before i use the grease i had drop the gyro gain value down to 65(out of the box) instead of the defasult value that was set to 75.. i had some very small/fast wags now since i added the grease. ive put back the gain to 75 and no more wag things run much more smoother idk if the grease really helped or if the gear did breakin in? but this is "smooth" now.. still run burning hot though ill check the temp next flights. Quote:
#26 | |
nothing to worry about really. no problem with the ESC on top, it doesnt toutch the canopy and the canopy been like that OTB. mb my groomets are a little off? anyways.. better be tight then loosy i guess |
#27 | |
I see. I've used D/R and switches. In Ele and Ail switches being up I have 35% expo +100% D/R and when then are down I have 60% for expo and 80% D/R. More or less same thing as you but I can decide upon which I want at the spot. BTW - Just now tried to flick those switches in flight and failed. LOL Oh, - there is another thing I've done for throttle - added a mix for +20% (which read really -20%) on spare (gear) switch. So when it is down I have lower HS in all three modes (Normal, Idle Up 1 & 2). |
#28 |
0.8mm Bullet Connector
hey DK, you were absolutly right about the pinion, disengaged the motor off the main gear and things was all smooth.
i though my motor/esc connectors was comming hot due to the fact that they were stacked over the ESC which become very hot. i moved the ESC on the battery tray and put the connectors as far as posible of anything. ran a pack.. connector were hot again, so i went ahead and shortened the .8mm bullet connectors and installed them on the motor/ESC. and wow, what a difference, head speed went up by a good amount.. funny thing is the the GF even noticed it and say mid flight "its me or your heli as more power than before?" i had not told her anything about the mod lost 0.8g in the process the .8mm bullet will only be warm after the flight more HS, more punch, less heat, less weight very nice mod! |
#29 |
just tryed the 400 mah 20c pack and it has some more power
but the connectors become hotter than i though, but not as hot as the stock one looks cleaner and less bulky too ![]() 87.75g instead of 88.6g |
#30 | |
Marty
I might get a second G6 and give up on the G3. There's just no consistancy, can work to get the tail holding and then the next day it's not. Still got a few more things to try before I give up... |
| Thread Tools | |
| New Product Walkera 4G6 and CB100 At RcHobbyHelicopter.com | johnIn2SonAZ | Micro Helis | 541 | Nov 13, 2009 10:22 AM |
| Discussion Walkera 4G6 first impression. | ehirobo | Micro Helis | 124 | Nov 07, 2009 05:39 PM |
| Cool a dream come true: new Walkera 4G6 - SD, Pitchtail 4G3 Size | robZulu | Micro Helis | 773 | Oct 28, 2009 03:25 PM |
| Discussion walkera 4g6 | dkintx | Mini Helis | 1 | Sep 01, 2009 08:22 PM |
| Discussion Walkera Lama2 mods. | wufer | Multi Rotor Helis | 4 | Sep 04, 2008 09:57 PM |
