I buy wire here: http://www.mcmaster.com/#metal-wire/=grmdrd (McMasterCarr's website makes it hard to link to the direct item). You want "spring temper" and I've used either the stainless steel or plain ol' steel (but keep dry). You can buy a lifetime supply for $20.
Latest blog entry: Testing..
Charles is right - belongs on the shelf
Tim |
http://www.smallparts.com/s?savedSea...4431&x=0&y=141 How 'bout some Titanium to bling your DLG?
OK guys since you have wire to waste, try this please...back in the day, I used to straighten coiled #9 and #11 wire with this method but it wasn't hard steel...I would do 50 feet at a time.
Take a 3.5 ft piece and secure one end in a vise-grip. Attach the other end to a hand-held variable speed drill with a screw-eye or bent nail or whatever. Pull the wire straight and spin the drill. It may only take a couple of revolutions. You'll have to experiment. Cut off the bent ends. Your wire should end up perfectly straight. Mine did. ![]() Let us know if it works. John
Or make a 3 wheeled straightener. Similar to how the big wire manufacturing guys do it.
The three wheels are in a flattened triangle, the two bottom ones are fixed, and the top one, between the bottom ones, is adjustable up and down. The top wheel is set so it stresses the wire in the opposite direction of the curl. The "fun" part is setting the wire, and the top wheel, and keeping the wire from rotating while being pulled through the straightener.
I have done this with larger wire and it was not a fun task. cant imagine trying to keep that small of wire in the correct orrentation.
for the wheels we used screen door rollers. if you could find a way to unspool the wire into the straightener you would be golden. is the spool a loose spool or is it on a spindle of some sort? Alan Quote:
| Thread Tools | |
| Flying at the Chandler Bowl | AZ_Astro | Club Talk | 799 | Aug 01, 2009 06:23 PM |
| Discussion DLG flying at the Chandler Bowl | Throwdown | Hand Launch | 16 | Jun 12, 2008 06:23 AM |
| Flying at the Chandler Bowl V3 | Drivie | Club Talk | 542 | Jun 12, 2004 03:18 PM |
| Chandler Bowl Channels Used | AZ_Astro | Club Talk | 13 | May 13, 2004 04:48 PM |
| Flying at the Chandler Bowl V2 | Drivie | Club Talk | 848 | Feb 12, 2004 12:26 PM |
