Old Dec 16, 2010, 12:39 PM
shhhhh! is online now
Find More Posts by shhhhh!
Yes..ok..maybe..lol.....
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
Jon....someone will chime in here soon...I think I did 1 3/4 inches..but can't remember for sure...George?? Charlie?? Dirk???
shhhhh! is online now Find More Posts by shhhhh!
Old Dec 16, 2010, 01:24 PM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Thanks Dave. If it matters (and I'm sure it does) I'm using D60s for ailerons and ds285s for the tail. I guess all four in the pod if I can figure out how to fit them.
jfinch is offline Find More Posts by jfinch
Old Dec 16, 2010, 02:29 PM
like.2.fly is offline
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
Jon, from what I recall in talking with George, Charlie, and others (correct me if I'm wrong guys); cut the boom off right in front of where the original pre-cut notch for the vert fin starts. This will probably amount to about 1.5" - 2" in length. Use that notched piece you cut off as a template for re-notching the remaining boom. You will now have to ream out the horiz stab v-mount such that it can slide far enough forward on the now larger diameter boom. After gluing the vert fin on, wrap a couple turns of spectra string around the boom just in front of the fin and CA in place to reinforce and prevent further splitting.
IMHO putting your aileron servos in the wings is much easier. Trying to put them in the B2 pod will greatly complicate the build, make wing removal more difficult, and not buy you much if anything in performance.
like.2.fly is offline Find More Posts by like.2.fly
Old Dec 16, 2010, 02:47 PM
cptsnoopy is online now
Find More Posts by cptsnoopy
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Pretty much what Mike said ^^^. I mark where the tail V-mount fits before modification. Then I ream it out and try to get at least 1 and 5/8" and no more than 2" further forward without splitting the V-mount. Then I push the V-mount onto the boom to where it will be glued (later) and mount the tail. Then I mark the boom about 1/4" behind the trailing edge of the tail and make that the front edge of the new rudder notch. Then I make sure there will be the correct amount of boom behind that mark for the rudder and cut the remainder off. That normally is around 1/4" in front of the original rudder notch. Then you can take and split that small section you have cut off vertically into two halves and use them to mark out your new notch further forward.
Ok, confused yet? Pictures would really help but I don't have any of that process.
Charlie
cptsnoopy is online now Find More Posts by cptsnoopy
Old Dec 16, 2010, 02:49 PM
jfinch is offline
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Yeah, I'm not all that excited about having to hook up the aileron linkages every time I take it out. I may reconsider putting all 4 servos in the pod.
Old Dec 16, 2010, 03:01 PM
jfinch is offline
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Great exlaination charlie.
I didn't look in the little baggie of goodies that came with the kit, but if aileron servo covers are in there I'm going to cut into the wing
Old Dec 16, 2010, 03:29 PM
Joined Jul 2004
If a B2...would definitely put the servos in the wing...That's what all the Az guys did..
Jon...if you need some servo covers..well you make really good ones..!
Old Dec 16, 2010, 03:35 PM
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
I have always used the skin that I cut out as the cover. I usually try to "block" up the servo if possible so that when the original skin is laid back down on the servo it is flush with the wing. Then the normal tape around it.
Charlie
Old Dec 16, 2010, 08:26 PM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
SO there are only 5 of us from AZ going to the JEM next month? My dad was talking about carpooling and such, but if no one else goes, there's not really much of a reason.
carlsoti is offline Find More Posts by carlsoti
Old Dec 16, 2010, 09:04 PM
BavarianCharles is online now
Find More Posts by BavarianCharles
Follow me to sink!
BavarianCharles's Avatar
85045
Joined Oct 2005
JEM
BavarianCharles is online now Find More Posts by BavarianCharles
Old Dec 16, 2010, 09:18 PM
carlsoti is offline
carlsoti's Avatar
Joined Jun 2008
The JEM is the John Erickson Memorial contest in/at Long Beach/ElDorado park. Prior to his unexpected passing, it was just the first ElDo monthly contest of the year. From what I've read, he a fantastic pilot, and in general an all-around great guy.
Old Dec 16, 2010, 10:01 PM
Follow me to sink!
85045
Joined Oct 2005
I'm signed up for the JEM, and so is Tucson Dave
Old Dec 18, 2010, 07:45 PM
proppy jon is offline
Find More Posts by proppy jon
Original Bloody Spadder
proppy jon's Avatar
phoenix
Joined Jul 2004
pics from our contest had a great time looks like the monthly contest will be on the second sunday of the month great job guys donnie george??
proppy jon is offline Find More Posts by proppy jon
Old Dec 18, 2010, 07:56 PM
rcgeorge is offline
Find More Posts by rcgeorge
usaf3kteam
rcgeorge's Avatar
United States, AZ, Arizona City
Joined Sep 2005
Nice John thanks
rcgeorge is offline Find More Posts by rcgeorge
Old Dec 19, 2010, 11:42 AM
Hohokam is offline
Find More Posts by Hohokam
Joined Nov 2010
contest pics.
Just a few of the pics. I shot the other day.
Hohokam is offline Find More Posts by Hohokam
Flying at the Chandler Bowl AZ_Astro Club Talk 799 Aug 01, 2009 06:23 PM
Discussion DLG flying at the Chandler Bowl Throwdown Hand Launch 16 Jun 12, 2008 06:23 AM
Flying at the Chandler Bowl V3 Drivie Club Talk 542 Jun 12, 2004 03:18 PM
Chandler Bowl Channels Used AZ_Astro Club Talk 13 May 13, 2004 04:48 PM
Flying at the Chandler Bowl V2 Drivie Club Talk 848 Feb 12, 2004 12:26 PM
