Old Sep 27, 2009, 06:02 PM
Modarius is offline
Find More Posts by Modarius
"Watch out for...CRUNCH!!
United States, CA, Sacramento
Joined Jul 2008
So the KF height is the same as the wing thickness?
Modarius is offline Find More Posts by Modarius
Old Sep 27, 2009, 06:33 PM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Originally Posted by j2m2t2
Wing is 9mm 1.9# and Step is 9mm 1.3# 50% of wing
KFm2 with a single step on the top?
DaOldGuy is offline Find More Posts by DaOldGuy
Old Sep 27, 2009, 06:41 PM
Modarius is offline
Joined Jul 2008
Would you happen to know the COG in percentage? Never mind I calculated it to be ~13%
Old Sep 27, 2009, 10:04 PM
j2m2t2 is offline
Find More Posts by j2m2t2
j2m2t2's Avatar
AZ
Joined Feb 2007
KFm-2 single step on top same thickness 9mm.
j2m2t2 is offline Find More Posts by j2m2t2
Old Sep 27, 2009, 11:43 PM
j2m2t2 is offline
j2m2t2's Avatar
AZ
Joined Feb 2007
Are you building? What foil?
Old Sep 27, 2009, 11:47 PM
Modarius is offline
Joined Jul 2008
Yes, I have everything but the tail cut out of foam board. I'm going the KF 2 route because of the simplicity. The problem is that when I calculate the size of the KF spacer it comes out to be a negative number. All of the info for my wing can be found on This Thread
Old Sep 29, 2009, 10:17 AM
j2m2t2 is offline
j2m2t2's Avatar
AZ
Joined Feb 2007
Ive been doing some reading and believe that my prop is causing a significant amount of drag. What Im not sure is if this will cause the nose to dip?
Anyway Ill know hopefully by this weekend as Ive got a spinner and folding 7x4.5 from bp coming.
Old Sep 30, 2009, 11:16 PM
rcpinoy is offline
Find More Posts by rcpinoy
Joined Feb 2009
New Build - with airfoil / dow blucor foam
Now working on a new build, using 1/4" blucor fanfold foam,
I dont have a hotwire bow yet.
I folded the wing to to easily form an airfoil, no ribs.
this will be my non-electric version and hoping she'll fly well, but will also build an electric version using the same power specs.
I'm a little slow on the build (I can only work on this after work) , Hope to finish before the weekend so I can fly it...
rcpinoy is offline Find More Posts by rcpinoy
Old Sep 30, 2009, 11:52 PM
j2m2t2 is offline
j2m2t2's Avatar
AZ
Joined Feb 2007
That looks good so far. I too will build a non powered with a foil from FFF. I was thinking of laying the FFF over some EPP with a spar to form clark Y or going your route, Ill wait on your progress.
Ive got my BPhobbies spinner and Ill be flying hopefully by the weekend.
Old Oct 01, 2009, 10:02 AM
rcpinoy is offline
Joined Feb 2009
Goal is to make this easy and simple... So... I decided to just use a foam spar, one infront near the LE and one near the TE. I didn'use ribs since the foam is stiff enough to hold its shape.
For the front spar, I cut the end of it (tip side) to an angle, so the wing bottom/top would meet together at the tip. I did raised/bent the wing tip to form a washout during glueing. It worked as expected.
Amazingly the wing actually developed a small dihedral caused by the angle cut on the front spar, which makes the top wing to pull the bottom.
The two foam blocks in the middle is for servo mount, and is now close to the LE. The CF is moved down from its original position, to trade with the servo weight, each of my micro servo weights 9g, so lets make use of it, forward swept wing needs to have most of its weight infront.
The spars and the stiffness of the FFF is already enough to hold the entire wing, so moving the CF away from its original position away from the CG is fine.
More to come...
Old Oct 03, 2009, 07:36 PM
j2m2t2 is offline
j2m2t2's Avatar
AZ
Joined Feb 2007
OK after alot of reading and discussing the KF foil I decided to redux my thumb wing. The 9mm EPP was too thick according to the experts, so here is the FFF version still with the KF2 and 1/8 inch spacer.
Maiden tomorrow then maybe some color.
Old Oct 03, 2009, 10:47 PM
rcpinoy is offline
Joined Feb 2009
Nice!. is your spinner from bphobbies?... is it balanced when you got them?
by the way, can you show how you made the removable tail?
Mine is permanent, (wont really stay permanent , but broke twice on landing, i keep reglueing. I think I need to make it removable so I can keep making another one if it broke.
Thanks!
Old Oct 03, 2009, 11:33 PM
j2m2t2 is offline
j2m2t2's Avatar
AZ
Joined Feb 2007
Thanks!
Yes same spinner and no it was not balanced. I played your game with the sand paper.
Here is the tail pic from the original thread. Someones good idea, not mine, works great.
Old Oct 04, 2009, 09:03 PM
rcpinoy is offline
Joined Feb 2009
Here is how I did my removable tail, with an adaptor, so I can try different tail configurations.
Also, I'll use this tail configuration in the picture. On my old thumb wing, the original tail design would hit the ground most of the time during landing since it is lower than the belly. its my fourth time breaking/reglueing it. So, I did raised the new tail up this time.
Old Oct 04, 2009, 09:55 PM
j2m2t2 is offline
j2m2t2's Avatar
AZ
Joined Feb 2007
Looks great rcpinoy. I like the tail design. Mine drags the tail also but Ive yet to damage it.
I flew today in 18mph winds, no slope I thought better of it but I said what the heck. The glide is unbelievable however the weight is not optimal for those conditions.
I changed the fuse again, I struggle with fuses, I don't know. Here is a pic after the flight, slight wing damage but nothing some hot glue couldn't repair.
S-1 electric flying wing glider Mike Stamos Product Announcements 0 Jul 01, 2003 12:57 PM
Zagi THL or Zagi LE or any other epp wing glider Nik-rc Aircraft - Sailplanes (FS/W) 3 Jun 12, 2003 10:28 PM
WTB: Zagi THL or Zagi LE or any other epp wing glider Nik-rc Aircraft - Electric - Airplanes (FS/W) 3 Jun 07, 2003 03:04 PM
F3 Delta Wing Glider emoone Foamies (Kits) 12 Jan 06, 2003 07:31 PM
My Mini E-Wing Glider Slow Riser Hand Launch 1 Sep 03, 2002 09:45 PM
