Old Sep 17, 2009, 02:34 PM
rcpinoy is offline
Find More Posts by rcpinoy
Joined Feb 2009
Build Log
Thumb Wing Glider - Alula-ish DIY Glider
Hello guys,
I just thought I should share the glider i'm building, based on Alula, I owned one but it's almost ready to retire, and I dont want to spend another $80+ for a new one. I thought of making one out of foam and parts laying around to save cost. So, let's just call this one a "Thumb Wing" Glider, If you know what Alula means, you know what a thumb wing is. I thought of making a SAL (non powered), and Electric version.
Uploaded are drawings, templates and some photos... I'll be uploading more and keep you guys posted of the progress.
Tell me what you guys think.
-rcpinoy
rcpinoy is offline Find More Posts by rcpinoy
Old Sep 17, 2009, 07:28 PM
tduro is offline
Find More Posts by tduro
If it wasn't for the foam
PA
Joined Dec 2004
Rcpinoy, nice job on the illustrations. I was obsessed with alula clones for a while. You'll find my info here: http://www.rcgroups.com/forums/showthread.php?t=627593
My first one was a sloppy build, but flew great. My second one was a precision build (for me anyway) and flew like crap. The issue, which I never resolved, was extreme vibration on the elevons at high speeds, which severely limited the launch. I even replaced the elevons with stiff balsa - no improvement.
I've since moved onto other things. Best of luck to you and your project! I'll be checking back to see your progress!
tduro is offline Find More Posts by tduro
Old Sep 17, 2009, 08:05 PM
dean_85 is offline
Find More Posts by dean_85
Alberta, Canada
http://alain.zutter.free.fr/Ailes/salAZ/index.html
dean_85 is offline Find More Posts by dean_85
Old Sep 17, 2009, 08:35 PM
tduro is offline
PA
Joined Dec 2004
Originally Posted by dean_85
Yep, That's what got me started!
Old Sep 17, 2009, 11:02 PM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
rcpinoy, nice re-design. Did you make an airfoil for the wing?
Kevin.
RCDad is offline Find More Posts by RCDad
Old Sep 18, 2009, 11:29 AM
j2m2t2 is offline
Find More Posts by j2m2t2
j2m2t2's Avatar
AZ
Joined Feb 2007
Any idea for CG?
j2m2t2 is offline Find More Posts by j2m2t2
Old Sep 20, 2009, 04:51 PM
Modarius is offline
Find More Posts by Modarius
"Watch out for...CRUNCH!!
United States, CA, Sacramento
Joined Jul 2008
anything more? I printed out the plans and have the wings cut out.
Modarius is offline Find More Posts by Modarius
Old Sep 20, 2009, 05:09 PM
j2m2t2 is offline
j2m2t2's Avatar
AZ
Joined Feb 2007
My progress.
Old Sep 20, 2009, 05:14 PM
Modarius is offline
Joined Jul 2008
How is the tail attached? Its hard to tell by the pictures. Thanks
Old Sep 20, 2009, 05:16 PM
j2m2t2 is offline
j2m2t2's Avatar
AZ
Joined Feb 2007
Not attached yet. Not sure what to do with it yet.
Old Sep 20, 2009, 05:36 PM
Modarius is offline
Joined Jul 2008
Well in the 3d model it looks like its part of the fuse, sandwiched in between the outer layers of the fuse.
Old Sep 20, 2009, 09:47 PM
j2m2t2 is offline
j2m2t2's Avatar
AZ
Joined Feb 2007
OK here it is ready to go. Just under 6oz with 2s 460. KFm-2
CG appears to be 3inches from leading edge. Ill find out at maiden for sure.
Thanks for the plans.
Old Sep 20, 2009, 09:53 PM
Modarius is offline
Joined Jul 2008
Cool! I like the paint job. Are you going to launch it SAL or by a bungee or by some other method?
Old Sep 20, 2009, 09:59 PM
j2m2t2 is offline
j2m2t2's Avatar
AZ
Joined Feb 2007
Im going SAL.
First plane of this type. I will be looking for slopes also.
Old Sep 20, 2009, 10:45 PM
rcpinoy is offline
Joined Feb 2009
Hi j2m2t2, wow man! you are quick...i'm currently travelling but will post my progress in a few moment....
CG is 30mm from LE, for a start... you can increase it as you get comfortable.
Originally Posted by j2m2t2
Any idea for CG?
S-1 electric flying wing glider Mike Stamos Product Announcements 0 Jul 01, 2003 12:57 PM
Zagi THL or Zagi LE or any other epp wing glider Nik-rc Aircraft - Sailplanes (FS/W) 3 Jun 12, 2003 10:28 PM
WTB: Zagi THL or Zagi LE or any other epp wing glider Nik-rc Aircraft - Electric - Airplanes (FS/W) 3 Jun 07, 2003 03:04 PM
F3 Delta Wing Glider emoone Foamies (Kits) 12 Jan 06, 2003 07:31 PM
My Mini E-Wing Glider Slow Riser Hand Launch 1 Sep 03, 2002 09:45 PM
