Old Sep 16, 2009, 06:45 PM
dcskinx is offline
Find More Posts by dcskinx
Joined Apr 2007
7.4V Lipo to replace 6V NiMH
Hi, I'm just after some advice on batteries. I have a truck, and use 4xAA's as the power for the receiver. I want to know if I can replace the 4xAA's with a 7.4V 800mAh 2-cell Lipo (Battery that came with a E-flite heli) and use that as power for my receiver. Thanks
dcskinx is offline Find More Posts by dcskinx
Old Sep 16, 2009, 07:22 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Generally RX or receiver and servo can only take up to 6v in power input. they normaly have a input range of 4.8v-6.0v and the reason for this is this, 4.8v from 4 rechargeable 1.2v AA cells and 6.0v from 4 alkaline 1.5v AA cell.
If you want to use a 2s lipo 7.4, well 7.4 volt is average and a fully charge 2S will be 8.4v way to much for you're electronics designed to be power at the most with 6.0v
If you must then you are going to need a voltage regulator to drop it down.
freechip is offline Find More Posts by freechip
Old Sep 16, 2009, 07:52 PM
marc1 is offline
Find More Posts by marc1
I will be an angry old man!
marc1's Avatar
Canada, MB, Division No. 9
Joined Apr 2007
4 cell nimh is considered 4.8V nominal, 5.8V fully charged
5 cell nimh is considered 6V nominal, 7.3V fully charged
A servo spec'ed for 4.8V is designed for 4 cell nimh (5.8V max), a servo designed for 6 V is compatible with 5 cell nimh (7.3V max). But hey, don't take my word for it, call Hitec / Futaba / JR yourself.
A fully charged 2 cell lipo is 8.4V, probably too high for most 6V rated servos, however, a 2 cell A123 is 7.2V, same as a 5 cell nimh, so that would be a good alternative.
As for your 4 x AA, are they alkaline or rechargeable? If alkaline, you have 6V max, can you find the specs for the servo and receiver in the truck?
Most modern receivers can operate up to 7 - 9.5V, again check the specs on your equipment.
Another thing to keep in mind is that the higher the voltage, the higher the current that will be drawn by the servos.
marc1 is offline Find More Posts by marc1
For Sale Duralite 1050 7.4v Lipo and Balancer Module NIP badbill Aircraft - Electric - Airplanes (FS/W) 2 Jul 27, 2005 07:51 AM
FS/ (3) 7.4v lipo 600mah shifter5 Aircraft - Electric - Airplanes (FS/W) 0 Oct 02, 2004 08:51 PM
7.4v lipo vs 11.1v lipos rikhye Power Systems 1 Jul 29, 2004 04:38 PM
Yippee! Went from 7.4V LiPo to 11.1V. What a difference! ManWithNoName Batteries and Chargers 30 Jun 25, 2004 05:46 PM
can i combine 2 7.4v lipo's to make 14.8v? jeff262 Power Systems 2 Dec 26, 2003 10:30 PM
