Old Sep 17, 2009, 01:25 PM
Stomp560 is offline
Find More Posts by Stomp560
aka Scott
Central FL
Joined Jul 2009
Originally Posted by dkfuji
No you are correct. The 4#3b has dogbones that connect to the swash. I think the best way to do it would be to push out the plastic insert (causing your own swash separation) and inserting the one from the CB100 swash. A little CA and the swash will be good to go. I have not tried it, but I know that insert does pop out since I have done it with a crash. LOL.
Funny, I was thinking the same thing as my 4G3 alu swashes have always seperated with no effort while flying, (I use a plastic one now exclusively) But never had it happen on my 4#3B, but was thinking maybe seperate them and swap em!
Did you take those last pics with the camera you had issue with? Those look fine, was it just a setting? I PM'ed that info on the recall just the same, maybe not the issue you have, but great to jump on it for free repair if it is!
-Scott
Stomp560 is offline Find More Posts by Stomp560
Old Sep 17, 2009, 01:26 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
Originally Posted by queadlunnrau
dkfuji,
I have a question for this over the MSR. I have the MSR and LOVE IT. So far after a couple of weeks of constant daily flights I have only had to replace the blade grips.
What in the CB100 have you had to replace besides the canopy and the main blades?
I LOVE the MSR and love how it can take a crash like no other, the price and beauty of the CB100 is VERY alluring and wonder when compaired to the MSR how costly is it in a crash?
I have only replaced 1 mainblade. The rest of the heli seems to be pretty solid and no other damage. I have bounced off the garage door frame, bushes, and cement stairs and it still comes back for more. The best thing is, like the MSR, if you get out of shape, all you have to do is get off the cyclic stick and give it throttle and it goes back to a stable hover. Pretty cool. Also, should you mess up the E-flite 5in1 servos you have to spend buckies on a new board. On the CB100 you can just replace the servo. Actually, they are really 2 different classes of helis anyway (IMO). The CB100 is more like a real RC heli (possible mods) and the MSR is a really good flying plaything (no mods really possible at this time). I do love both of them, but my MSR is now just sitting.
dkfuji is offline Find More Posts by dkfuji
Old Sep 17, 2009, 01:37 PM
mrschultz02 is offline
Find More Posts by mrschultz02
Marty
mrschultz02's Avatar
USA, PA, Media
Joined Aug 2008
Different sizes on those for the swash bearing, so you can't swap parts. Was thinking about doing a FP G at one point so that's why I know... Even the ball that goes around the main shaft is a different size, so can't swap that either...
mrschultz02 is offline Find More Posts by mrschultz02
Old Sep 17, 2009, 01:45 PM
Marty
USA, PA, Media
Joined Aug 2008
That's what I wanted to hear, might get one to practice nose in, as soon as someone starts selling a barebones kit. The UFO8 is nice for training since you can pick up the tilt so easy, but once you really loose it it's going down, although with a few key upgrades it would be nearly indestructible...
Old Sep 17, 2009, 02:20 PM
humveeflyer is offline
Find More Posts by humveeflyer
heli addict
humveeflyer's Avatar
Ohio
Joined Nov 2003
I would like to know how it comes out of FFF. I see that the new CB180Q sometimes has a problem like a coax coming out of FFF where it will flutter and drop. That is one thing that I appreciate about the msr is that it transitions very well.
humveeflyer is offline Find More Posts by humveeflyer
Old Sep 17, 2009, 02:25 PM
lazer155 is offline
Find More Posts by lazer155
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
Could that be an effect of the beller hiller mixing head? The msr doesnt mix but the cb100 does.
lazer155 is offline Find More Posts by lazer155
Old Sep 17, 2009, 02:26 PM
dkfuji is offline
The OC, California
Joined Feb 2007
-Scott
Yeah it is the same camera. They look fine now. Adjusted the white balance per Mrschultz suggestion and seems to have worked.
Old Sep 17, 2009, 02:28 PM
dkfuji is offline
The OC, California
Joined Feb 2007
Bummer. It seems I will have to tear one apart to figure this all out for a bolt-on 4#3b mod. Darn it...LOL
Old Sep 17, 2009, 02:51 PM
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
I see wowhobbies sells them but where are the spare parts?
GiantScale is offline Find More Posts by GiantScale
Old Sep 17, 2009, 03:07 PM
queadlunnrau is online now
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
Seems like I will have another heli in my fleet soon.
I have a couple of other questions if you have time, it's hard finding other reviews on this new heli.
What's the flight time you were getting when it was stock?
Faster or slower then the MSR?
Did you get fries and a coke with it?
queadlunnrau is online now Find More Posts by queadlunnrau
Old Sep 17, 2009, 03:15 PM
dkfuji is offline
The OC, California
Joined Feb 2007
It comes out of FFF very nicely as long as the wind conditions are still. If not, the self stabilization tries take over and the heli wobbles a little coming out of the turn. I have turned down the gyro gain to smooth the transition out a bit. With no wind she transitions very well. I am moving the balls to the outer holes on the servo arms to get more travel for outdoors. So far, any changes has not effected the stability one bit. It will always go back to a stable hover. Not bad.
Old Sep 17, 2009, 03:25 PM
dkfuji is offline
The OC, California
Joined Feb 2007
I am getting over 6mins with the stock 500mah pack. There is still 3.94 left in the pack so my guess is if you do some nice circuits you could get almost 8mins out of the pack.
Faster or quicker? This is where I mentioned different classes of heli. The MSR only weighs 1oz (28g) versus the CB100 at 60+g. Also, the MSR is smaller in overall length and blade diameter. As a result of all these factors, the MSR is "faster" than the CB100. However, the CB100 is more manageable doing figure 8's since it is smooth no matter what direction you turn. The MSR is a little twitchy going left.
Yep. I got fries and a diet coke with it. To go. LOL.
Old Sep 17, 2009, 03:41 PM
Luck is my skill
Joined Jun 2009
Thanks for the reply.
Damn WTH is up with RC helis? It's more addictive then cigarettes. I seriously cannot get enough ... Hell I woundn't mind slapping a co-workers ass to get fired to fly them more ... but then again I couldn't support my addiction then.
Old Sep 17, 2009, 04:34 PM
sebtomato is offline
Find More Posts by sebtomato
SRB Quark, CB100, V911, Hub X4
London, UK
Joined Feb 2009
Originally Posted by Balr14
No expo settings?
No expo, no end points, just reversing.
sebtomato is offline Find More Posts by sebtomato
Old Sep 17, 2009, 04:53 PM
suraki is offline
Find More Posts by suraki
Joined Jan 2009
Funny you say that I actually quit smoking so I could have more money for helis. Added $55/month to my budget and my wife never complains anymore.
suraki is offline Find More Posts by suraki
What are the little wires in my Lipo Kokam 3s3p? lempert Batteries and Chargers 1 Aug 18, 2004 06:54 AM
I held Babe Ruth's bat in my hands yesterday NewbieX Life, The Universe, and Politics 8 Feb 01, 2004 11:40 AM
Wemotec MC-001 Micro Fans in My Hands !!!! EAMRC Electric Ducted Fan Jet Talk 35 Jul 06, 2002 05:30 PM
How hot can my receiver get in my Aspire Ripley Modeling Science 4 Jun 25, 2002 01:58 PM
