Old Apr 19, 2003, 04:10 PM
eBird is offline
Find More Posts by eBird
Look! Up in the sky!
eBird's Avatar
Grand Junction, Colorado
Joined Jul 2002
Reliable method to give your SlowStick down/right thrust
Super simple & safe way to bend the fuse, doesn't cause it to kink.
Just cut the 2x4 with a gentle 3-5 curve, put in the vise with the fuse sandwiched inbetween, and presto, perfect curve with no kinks. Rotate the fuse and bend again if you want to add right thrust.
eBird is offline Find More Posts by eBird
Old Apr 19, 2003, 04:12 PM
eBird is offline
eBird's Avatar
Joined Jul 2002
In the vise...
Old Apr 19, 2003, 04:37 PM
turbojoe is offline
Find More Posts by turbojoe
M0unt@in M0del$ minion
turbojoe's Avatar
United States, AZ, Mesa
Joined Jul 2002
Now wait a minute. Thats TOO simple! We've got to complicate it somehow
Another addition to the "why didn't I think of that" file. Great job!
Joe
turbojoe is offline Find More Posts by turbojoe
Old Apr 19, 2003, 09:10 PM
eBird is offline
eBird's Avatar
Joined Jul 2002
Yeah, it is too simple, but more complicated than the "2 thumbs" approach which is "kinky" if you know what I mean
Pour on the coals on my latest SS and it just hauls, without pitchin' up... Love that aluminum fuse!
Old May 26, 2003, 12:28 PM
MooseFlyR is offline
Find More Posts by MooseFlyR
MooseFlyR's Avatar
Slingerlands, NY
Joined Feb 2003
eBird... had to search back for this thread to show someone. Must have been too simple or something as Joe said as it hasn't changed since I first noticed it. Just wanted to pop it back up front and also say that I tried this on a friend's stick (mine already had something else) and it works great! My next one will be done using this method as well. Great stuff!
Bob
MooseFlyR is offline Find More Posts by MooseFlyR
Old May 26, 2003, 03:10 PM
KillerWatt is offline
Find More Posts by KillerWatt
Colonial Heights, Virginia, USA
Joined Mar 2001
looks simple enough, but i just CAN'T bend my nice, straight metal fuse... but when i absolutley think i must have some motor offset, i just whittle out a short, crooked, hard balsa stick same size as metal fuse and find a good application for the normally unused black plastic joiner... it also extends the motor foward just enough so i can now place the heavy battery pack rearward, directly under the wing's CG point for least pitch inertia effects and with different shaped sticks, various offsets can be played with..... but if you've just gotta bend metal, that looks like a great method................. kw
KillerWatt is offline Find More Posts by KillerWatt
Old May 26, 2003, 03:58 PM
eBird is offline
eBird's Avatar
Joined Jul 2002
I had no problem bending my nice straight metal fuse, mental or otherwise.
No add'l weight, no "parts" at all, and I've got the down thrust that keeps it straight under full power.
I've since plowed it into the ground twice due to wind, hard enough to explode the motor mount, and the fuse is just fine.
The "bend mod" does not compromise the fuse strength at all.
Old Nov 04, 2003, 12:14 AM
eBird is offline
eBird's Avatar
Joined Jul 2002
I've had two requests now to resurrect this thread, so here it is.
Mine has been bent this way for 8 months now, and is still strong as ever.
Old Nov 04, 2003, 01:25 AM
Rogerdoger is offline
Find More Posts by Rogerdoger
Rogerdoger's Avatar
United States, CA, Clovis
Joined Apr 2002
down/right thrust
Thanks Steve,
This looks good and maybe I can even get it done to my SS.
Question,
I like the tendency for the plane to climb when going to full power. It sounds like this eliminates that, or does it? Maybe change it 1 to 2 degrees down and right?
Roger
Rogerdoger is offline Find More Posts by Rogerdoger
Old Nov 04, 2003, 01:51 AM
eBird is offline
eBird's Avatar
Joined Jul 2002
Roger, it'll still climb when you hit full power, just like a plane should. It won't, however, porpoise and climb straight up like it does without the down thrust.
Old Nov 04, 2003, 01:57 AM
ktoey is offline
Find More Posts by ktoey
San Dimas, 40 km east of Los Angeles
Joined Sep 2002
GWSCEO,
How about making a plastic plug with built-in right and down thrust ?
ktoey is offline Find More Posts by ktoey
Old Nov 04, 2003, 01:58 AM
Rogerdoger's Avatar
Joined Apr 2002
It'll Still Climb
Steve,
Thanks for the information. I have been flying electrics for just over two years now and really am limited in experience to the planes I have.
Thanks again for posting this thread. I'm sure I'm not the only one who will get good out from it.
Roger
Old Nov 04, 2003, 02:41 AM
Trikster is offline
Find More Posts by Trikster
Zoom, zoom...
Trikster's Avatar
Roseville, CA (Sacramento area)
Joined May 2003
The others are right, that is far too simple. Perhaps we need to make it harder by saying the blocks must be some composite material and the vise needs to be Lipo powered...now to find some wood...
Trikster is offline Find More Posts by Trikster
Old Nov 04, 2003, 04:05 PM
MooseFlyR's Avatar
Slingerlands, NY
Joined Feb 2003
Thanks for pulling this thread back up Steve. I've done 2 so far this way and it's the best.
I put a link to here in the penguin's SS help thread too.
Old Nov 08, 2003, 11:37 AM
BrunswickOH is offline
Find More Posts by BrunswickOH
Brunswick, Ohio
BrunswickOH's Avatar
Joined Aug 2003
That's a nice method, another thought is if you still have the black plastic piece for the "removable tail option" from your build. Cut the fuse about three or four inches back from the front (enough room to reinstall the motor) and put the cut section back on with the plastic part. Then apply some heat and bend down and right. Once you have it where you want it use epoxy to set it and take care of any gaps created fromt he bending plastic and you've get a perfect strong down right mod without having to bend the fuse. Just another method that doesn't take much thought or time as long as you still have that piece.
PS pay no attention to the kite string that is holding on my landing gear!!! it really does stay in place
BrunswickOH is offline Find More Posts by BrunswickOH
slowstick - need help doing down/right thrust mod fprintf Parkflyers 17 Aug 31, 2003 09:03 PM
How much down/right thrust in your Scorpio Hellcat? nhorianopoulos Parkflyers 1 May 07, 2003 07:16 PM
down/right thrust on the Slow Stick Fly Parkflyers 0 Oct 08, 2002 09:25 AM
Down and right thrust for Magic jlk Sport Planes 16 Jun 08, 2002 12:24 PM
How to install down and right thrust Jeff Meyers Electric Sailplanes 2 Apr 25, 2001 11:59 PM
