Old Sep 15, 2009, 11:00 PM
medicus is offline
Find More Posts by medicus
The Midwest
Joined Apr 2008
Video
Maiden Flight of 41" Edge 540
Something is out of wack with the plane, and I've gotta figure it out. It flew terribly. I was glad I got it back down in one piece though. I did balance it before flight and had everything centered, unless something went out right before I flew it, I'm just not sure what happened.
medicus is offline Find More Posts by medicus
Old Sep 16, 2009, 12:27 AM
Low Pass is offline
Find More Posts by Low Pass
Some epoxy & it flies again...
Low Pass's Avatar
Santa Cruz, California
Joined Sep 2008
Well, I think you should go for much less throttle at take off. It reacted very violently. Later you reduced the power and it was time for trimming. I try very slow rounds first to trimm it straight and horizontal.
Try to find out, if the CG is right, by going into a dive; see, if it recovers or goes even more down.
Also reduce the low rate ranges until it flies.
Low Pass is offline Find More Posts by Low Pass
Old Sep 16, 2009, 01:26 AM
medicus is offline
The Midwest
Joined Apr 2008
CG according the the manual is right, but it'll be a few days before I can flight test CG again. Ranges have already been reduced... I normally wouldn't have had so much throttle, but our take off strip had cracked, and I was trying to give it enough umph that it'd lift off prior to the crack. Oh well.
Thanks for the advice... here in a few days (when I get the guts to do so again lol) I'll probably post a 2nd flight video.
Old Sep 16, 2009, 03:13 AM
badpilotto is offline
Find More Posts by badpilotto
BadPilot
badpilotto's Avatar
United States, IL, Custer Park
Joined Nov 2007
That problem looks twofold to me. 1) the CG in the manuals are not always correct depending on the manufacture and 2) control throws look high which could account for the over controlling of the plane. When I build a Brio it flew like that and it was due to CG, high throw of control and the canopy not being seated properly.
I think Low Pass's comment was spot on, "by going into a dive; see, if it recovers or goes even more down."
Good luck, I know you will find the answer and solve this small problem.
John
badpilotto is offline Find More Posts by badpilotto
Old Sep 16, 2009, 12:35 PM
MTDV is offline
Find More Posts by MTDV
Software always has bugs
United States, TX, Missouri City
Joined Nov 2008
That scared me at first...
It seems to me that you had a nose heavy. I would try to fly it as much as horizontal as possible and let it glide to test the CG, or try with Low Pass's way.
Other thing is to use the exp for input. I found that was a nice feature to have. Otherwise, use the dual rate for test flight.
It's a nice plane and very touchy with input
MTDV is offline Find More Posts by MTDV
Old Sep 16, 2009, 01:22 PM
Rengine is offline
Find More Posts by Rengine
'Cobra Fan - P-39 & P-63
Rengine's Avatar
Fort Collins, CO
Joined Aug 2004
Whoa!
Scary flight - I've had those - seems like you never did get it totally under control...yeah - I'd agree - reduce your rates (I fly with 35-40% expo on rudder & elevator, maybe 25-30% on aileron - this REALLY smooths things out until stunt time) and move CG 1/4 inch forward for next flight....just my thoughts....
...and that's the cutest lil' runway I've ever seen! I gotta make one of those for my back yard.....
Rengine is offline Find More Posts by Rengine
Old Sep 19, 2009, 03:10 AM
medicus is offline
The Midwest
Joined Apr 2008
Originally Posted by Rengine
Whoa!
Lol thanks... it's a fun runway. But, it needs some repair work because of a flood that happened over the spring.
The wind has been KILLER here lately, so I haven't gotten to even consider putting it back in the air.
You are correct, I never did get it under control, or what I would feel like was control at least.
Anyway, I promise, I'll be posting a new video when I take these suggestions into consideration and fly again.
Old Sep 23, 2009, 04:30 PM
medicus is offline
The Midwest
Joined Apr 2008
All right... the plane flew again today. I'll post the video here in a few hours. I have to do some other things before I start messing with fighting the camera to get the video on my computer again. 100% too nose heavy. I would put it in a dive and it continued in the dive... if I let go of the sticks at level flight, it would go into a dive and continue to go more into a dive. It never showed any signs of leveling out whatsoever, so I guess I'm going to have to play with the COG on this to figure out where exactly it should be.
I also have a maiden flight of a P51 to show too. It's pretty funny. My dad put in like 100+ hours building this kit... his first kit ever, and he's got some time in the garage again after his first flight lol.
Old Sep 24, 2009, 04:26 AM
BadPilot
badpilotto's Avatar
Joined Nov 2007
medicus,
Looking forwards to both vids.
Thank
John
Old Sep 25, 2009, 12:44 AM
Low Pass is offline
Low Pass's Avatar
Joined Sep 2008
medicus, looking forward to see it.
well, I had the Ultrafly P-51 once with retracts and flaps. It took me 2-3 months to get it ready. The first flight ended up in a nose dive into the cement. 3 month later, all pieces were glued together again, the same happened again. I made a scratch built copy from cell foam and calculated the CG here: http://adamone.rchomepage.com/cg_calc.htm. It urned out the CG should have been almost an inch backwards compared to the manual.
What happened in both flights: First, level flight was ok. Then I tried a loop, it flipped over and went into a dive. Trying to get the nose up resulted again in a flip and the next dive etc.
Since then I recalculate the CG with each new plane just for safety. My scratch built P-51 still flies great.
Anyway, isn't that part of the fun? Building a plane in the garage for months, flying it, repairing it, flying it , repairing it,.....
Old Sep 25, 2009, 07:13 AM
MTDV is offline
Joined Nov 2008
Yeap, that's the ultimate fun of this hobby.
Old Sep 26, 2009, 03:04 AM
BadPilot
badpilotto's Avatar
Joined Nov 2007
Low Pass and MTDV,
Your both right build, fly, and repair. I like to figuring out what is wrong with my planes and fixing it to fly better.
Old Sep 26, 2009, 09:03 PM
medicus is offline
The Midwest
Joined Apr 2008
Ok, I know I said I'd upload videos, but I've been having a lot of issues with the camera. When I finally got to where I could upload the videos, I actually watched the videos for the first time, and a lot needs to be edited out as to not give viewers a really upset stomach.
Thanks for that link... I'll be checking that out soon too.
Anyway, I don't have video of today's flight, but I ended up adding almost 20 grams of weight to the tail which ended up moving the COG back over an inch from what the manual stated... the plane flew beautifully compared to how it has been. Granted, it wasn't perfect by any means, but I was actually able to control it well and I started doing a few tricks/inverted flight without even having a high throw rate and it all seemed to be coming together. I'd say after another 2 battery packs, I'll have this thing fine tuned, and hopefully I'll have several videos to eventually post. I don't like that I ended up having to add so much weight to the tail. I moved everything I possibly could back as far as I could too, and even rigged up the battery cage so the battery is really far back as well. It's just still needing something. I'd like to be able to eventually get the extra eight off, since I really hate the "dead weight" I've had to add, but we'll have to see. Tomorrow, I'm going to do some editting and try to get some videos up for sure. Hopefully the wind will cooperate and I can put up a new video of the improved flying characteristics as well.
Old Sep 27, 2009, 02:49 AM
BadPilot
badpilotto's Avatar
Joined Nov 2007
medicus,
Will be standing by for the video, is it done yet? How about now? JK.
That is strange that you had to add weight to the tail. Most planes (as we all know) usually need nose weight or are too tail heavy. In the video it looked tail heavy by the way you could not really get it under control.
There was one plane I built (I cannot recall the name) that needed more weight in the tail and if I didn't read RCG review prior to building I would have had to do the same, add weight to the tail.
John
Old Sep 27, 2009, 01:42 PM
medicus is offline
The Midwest
Joined Apr 2008
All right, I had to make a new thread to upload a new video... so here if you want to see the new video...
http://www.rcgroups.com/forums/showp...16&postcount=1
it's there.
Sold Extreme Flight 45" Edge 540 jadamian75 Aircraft - Electric - Airplanes (FS/W) 3 Feb 27, 2009 05:51 AM
Sold Custom Extreme Flight 45" EDGE 540 - Blue/Silver Fliprob17 Aircraft - Electric - Airplanes (FS/W) 11 Jan 30, 2009 03:36 PM
Discussion E-Flight 450 on Edge 540 BP derdude 3D Flying 4 Nov 10, 2008 03:57 PM
FancyFoam Edge 540 maiden flight.. some questions snowball1288 Foamies (Kits) 1 Dec 29, 2004 08:56 PM
Radical Edge 540 Flight Report ToddL Sport Planes 72 Dec 22, 2001 12:34 PM
