Old Sep 15, 2009, 10:11 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Wing to fuselage servo connections, what do you use?
I've fiddled around a bit with dual servos in a wing being connected to the Rx both at the same time using a small 4-pin Deans connector. Any other ideas?
How about 4 and 6 servo wings? What do you use? Does someone make something just for this purpose?
GregG is offline Find More Posts by GregG
Old Sep 15, 2009, 10:36 PM
carpetbomb is offline
Find More Posts by carpetbomb
finger slicer
carpetbomb's Avatar
Southern CA.
Joined Mar 2009
4 servos a wing = Multiplex 6pin connectors: http://www.soaringusa.com/products/p...ategory_id=352
4 + servos a wing = DB9 connector
http://www.computercablestore.com/DB...ema_PID92.aspx
http://www.computercablestore.com/DB...ale_PID94.aspx
mike
carpetbomb is offline Find More Posts by carpetbomb
Old Sep 16, 2009, 04:19 AM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
I have been using the gold plated RS232 / DB9 connectors from a PC store. People warned me that they won't last and only have a connection life of 100 cycles. They are not self cleaning and so the contacts could get dirty over time.
So far so good but just to be sure i won't have any problems in future i am changing over to what the Germans are using. With thanks to Heiko for sharing this information!!!
You will want the gold plated RM 2.54 mm size and 2 wide strips. Cut them down to how many pins you need (8 for Avionik B wings). Note that these connectors have the same spacing and pin design as most RX'es.
Search for part numbers;
Male
744042 - 89
Female
741191 - 8B
On http://www.conrad.com/ in your country.
Don't think they are in the USA but i am aware the USA team pilots use the polarised Deans 6 pin connectors?! They are equal quality or better, just no more then 6 pins.
Joe
jjmouris is offline Find More Posts by jjmouris
Old Sep 16, 2009, 07:02 AM
Rob AR is offline
Find More Posts by Rob AR
Go on just 1 more beer then
Rob AR's Avatar
Bournemouth Intl, Great Britain (UK)
Joined Aug 2004
Ashlock
Or if like me you hate soldering to tiny little plugs and prefer Crimping.
http://www.thunderboltrc.com/ashlok/AshlokInfo.html
You can go from 1 to 6 servo connectors & once you have bought your crimping machine you can then also make all your own extension/servo leads as well.
The Crimper and Ashlock connectors are probably one of the most useful tools I have bought.
Rob
Rob AR is offline Find More Posts by Rob AR
Old Sep 16, 2009, 09:50 AM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
RC Harness
Greg,
Or, if you are really lazy, like me, you can try these... PnP...
http://www.soaringusa.com/products/s...ategory_id=352
1.5, 2, 2.5, 3, 3.5Meter. Also in 2pc wing version as well...
Best,
Bob
Bro is offline Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Old Sep 16, 2009, 11:23 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Deans 4-pin for 2-servos,
MPX for 4-servo.
Never had a 6-servo, so MPX work for me BUT I am considering switching to DIN for future models, and making them plug in "automatically" (too much push/pull force required to do this with the MPX plugs)..
..a
Old Sep 16, 2009, 12:29 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
I recently got some of these for a UAV project.
There are tons at www.halted.com.
Cheap too!
B
Male
744042 - 89
Female
741191 - 8B
Joe
fly_boy99 is offline Find More Posts by fly_boy99
Old Sep 16, 2009, 02:00 PM
dogshome is offline
Find More Posts by dogshome
dogshome's Avatar
Joined Dec 2006
I've used Multiplex, but given a choice on future models I'd use a 9-pin D if it fits. The Multiplex are smaller. The quality is better on any D connector though.
P.S. D connectors come in several grades from 'nasty' to 'bombproof'.
dogshome is offline Find More Posts by dogshome
Old Sep 16, 2009, 05:31 PM
Mike Seale is offline
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
I've never used D connectors because when I looked (many years ago) the specifications all indicated that they were manufactured for 100 or so insertions only...ie, not exactly a tight fit after time. So can you point us towards a 'bombproof' one please?
Mike Seale is offline Find More Posts by Mike Seale
Old Sep 16, 2009, 05:32 PM
flying evader is offline
Find More Posts by flying evader
Back in the game
flying evader's Avatar
United States, TX, Frisco
Joined May 2006
I bought an absolute that was built with a serial type connector for wing connector.. The wings were joined (not 2 piece). You put the wing in place, put the bolts and ready to go! not sure who did this but it's beautiful and hasn't failed after several years of abuse..
flying evader is offline Find More Posts by flying evader
Old Sep 16, 2009, 05:39 PM
finger slicer
carpetbomb's Avatar
Southern CA.
Joined Mar 2009
I did something similar with my Absolute, but I used MPX connectors. When I plug the two wing halves together they're joined via an MPX connector. There's an additional MPX male connector in one of the wings. I didn't make it plug & play at the fuse, though.
I wanted the ability to have a little slop on that connection to allow more room for batteries, and to not stress that connection point.
Came out pretty good!
mike
Old Sep 16, 2009, 06:06 PM
rcelectfly is offline
Find More Posts by rcelectfly
rcelectfly's Avatar
San Diego, CA, USA
Joined Nov 2001
Joe
Joe,
Deans does make connectors with more than 6 pins.
Chuck
rcelectfly is offline Find More Posts by rcelectfly
Old Sep 17, 2009, 02:39 AM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Originally Posted by rcelectfly
Joe,
Chuck
8 pin here:
http://www.radicalrc.com/shop/?cart=3078411&cat=56&
la528it is offline Find More Posts by la528it
Old Sep 17, 2009, 06:28 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Not all D-connectors are equal:
http://www.rcgroups.com/forums/showp...1&postcount=20
..a
Old Sep 17, 2009, 03:28 PM
jattamasso is offline
Find More Posts by jattamasso
jattamasso's Avatar
Coimbra, PT
Joined Dec 2005
The Multilpex plug is hard to beat regarding servo installation. Here my Kamelot:
Hope this helps
Rui
jattamasso is offline Find More Posts by jattamasso
What Do You Use For The Servo Links??? Minimole Micro Helis 5 May 12, 2005 05:01 PM
What do you use as a weighted bar for your wing core cutter ? NetForce2K Foamies (Kits) 1 Jul 26, 2002 07:27 PM
Looking for a small battery connector. What do you use ? RonJ Parkflyers 18 Jul 12, 2002 10:04 PM
What do you use most..... planematt Electric Plane Talk 4 Oct 01, 2001 10:48 AM
What do you use for an end insulator on a foam cutter? AW Power Systems 8 Jun 20, 2001 10:49 PM
