Go Back   RC Groups > Boats > Submarines
Old Oct 23, 2009, 08:12 PM   #31
under construction
SilentHunter's Avatar
Originally Posted by Albion
Arrr but 9 out of 10 Aqua men say the fox is more streamlined underwater, the kilo only has a rounded bow cos it nuklear powdered
You got it! lol
The Kilo is actually in micrometer atom splitting scale,is like 1/71 or thereabouts
SilentHunter is offline Find More Posts by SilentHunter   Reply With Quote
Old Oct 23, 2009, 09:56 PM   #32
Originally Posted by nick_75au
#Maximum speed
* 10-12 knots surfaced
* 17-25 knots submerged
Propulsion: Diesel-electric 5,900 shp (4,400 kW)
16 knots (18 mph; 30 km/h) surfaced
15 knots (17 mph; 28 km/h) submerged
9 knots (10 mph; 17 km/h) snorkeling
5400 Hp 4027 Kw
Interesting comparison
Nick
I'm assuming first figures are first for Kilo second for Foxtrot.
If so then thats the diffinitive answer to Aquas rounded bow rant , sorry for taking this of tangent. Similar power outputs, the boat type bow slightly faster on surface, rounded bow faster underwater, where it counts.
Albion is offline Find More Posts by Albion   Reply With Quote
Old Oct 23, 2009, 10:27 PM   #33
Tygum Lagoon Terror
nick_75au's Avatar
Had to look it up, to prove it to myself, the Kilo has a substantially greater displacement as well with only a modest increase in power.
Yes I think the point is settled for me.
"I like that retro look compared to the Kilo's larger streamlined hull."
same for me,
Nick
nick_75au is offline Find More Posts by nick_75au   Reply With Quote
Old Oct 24, 2009, 06:18 PM   #34
Shanghai'd Expat
herrmill's Avatar
Send a message via AIM to herrmill Send a message via Yahoo to herrmill
Rick sent in some photos of the final stern work before completes the hull plating.
  • Name: fox 027.jpg
Description: Project 641 final stern shape Project 641 final stern shape 70.1 KB · Views: 28
  • Name: fox 028.jpg
Description: Project 641 final stern shape Project 641 final stern shape 86.0 KB · Views: 24
  • Name: fox 029.jpg
Description: Project 641 final stern shape Project 641 final stern shape 64.1 KB · Views: 35
  • Name: fox 030.jpg
Description: Project 641 final stern shape Project 641 final stern shape 105.9 KB · Views: 31
herrmill is offline Find More Posts by herrmill   Reply With Quote
Old Oct 24, 2009, 07:26 PM   #35
Shanghai'd Expat
herrmill's Avatar
Boy, does this guy work fast!
  • Name: fox 033.jpg
  • Name: fox 035.jpg
  • Name: fox 036.jpg
Old Oct 25, 2009, 05:22 AM   #36
Is it me?
Akula971's Avatar
Send a message via MSN to Akula971
From what I remembered the Kilo is a Diesel Electric Albion. They changed the hull shape away from the XXI type because the Russians have always thought that the German boats had insufficient reserve buoyancy. A large double hull helps resolve this. It has the nice rounded shapes because it is hydrodynamical a better shape requiring less power to push it through the water. There comes a point where extra revs/power does not produce extra speed only extra noise. It would be interesting to compare the hulls for their CW values. It could also be tested on the models too. Now that would be interesting. Similar battery packs, similar motors, compare speed and endurance of a model Kilo and a model Foxtrot.
Akula971 is online now Find More Posts by Akula971   Reply With Quote
Old Oct 25, 2009, 05:37 AM   #37
Tygum Lagoon Terror
nick_75au's Avatar
Hi Akula,
I sort of drifted off topic due to a now banned poster and his assertion that the sharp bow was more efficient in a different thread. I saw the two hulls next to each other and looked up the stats out of curiosity, noticing the similarities in power. I'm sure Albion is well aware of the Kilos propulsion plant
Nick
Old Oct 25, 2009, 07:00 AM   #38
Is it me?
Akula971's Avatar
Is it the "happyman" that has been banned? or is he just away?
Old Oct 25, 2009, 07:12 AM   #39
Shanghai'd Expat
herrmill's Avatar
I believe a long holiday.
Speaking of propulsion systems, Rick's already got parts ordered for the Foxtrot's triple screw twin piston ballast system. Not sure at this point who all wants 2 or 3 working screws - several of us who have other similar sized subs like the idea of having a 2.5" twin screw system to switch among our small, but growing fleets.
Old Oct 25, 2009, 08:03 PM   #40
Mostly harmless
Capt_Christo's Avatar
I'll go for the 3 screw if room allows.
Capt_Christo is offline Find More Posts by Capt_Christo   Reply With Quote
Old Oct 25, 2009, 09:10 PM   #41
3 screws sounds good. i had considered a twin motor design, and then a pulley / belt linking one outer screw to the centre screw. But if a single motor with three geared outputs can be made then why not. As Andy said earlier (here or somewhere else??) the centre screw pushing water over the rudder is going to help with turning, so it really needs to be more that just eye candy
Old Oct 25, 2009, 09:48 PM   #42
Shanghai'd Expat
herrmill's Avatar
It would be twin motor setup with gearbox mounted on the bulkhead.
Old Oct 26, 2009, 10:48 AM   #43
under construction
Im going for the 3 screw setup, powered by a 480 motor and about 3.5:1 reduction. Im waiting for the spur gears to arrive from sdp-si Keep in mind the screws are only about 20-25mm in diameter.
Yes I like the fact that with 3 screws working, not only will it be more responsive in turning and pitch, but of course scale as well.
Old Oct 26, 2009, 11:05 AM   #44
Superb
Old Oct 26, 2009, 01:09 PM   #45
Looking good!
Won't these ships be very noisy in real?
With 3 props you can hardly expect it could be quite.
Greetings Josse
tweety777 is offline Find More Posts by tweety777   Reply With Quote
Discussion 1/72 scale Civil War Monitor Kit The Seer Scale Boats 2 Feb 28, 2009 04:07 PM
Wanted 1/72 plastic SU-34 kit? Tram Non R/C Items (FS/W) 0 Oct 20, 2008 12:43 PM
Question 1/72 Foxtrot Interest herrmill Submarines 0 Mar 27, 2008 03:13 AM
Wanted Dumas 1/72 Monitor & Virginia combo kit or bigger scale takevin Boats (FS/W) 0 Dec 11, 2007 10:57 PM
Barnstormer Boats 1:72 scale LA Class kit review. Nemo Submarines 8 Mar 21, 2007 08:51 AM
Bored? Want to fight?
Join the RCGroups clan!
